Seeking replacement Head unit Display Screen
pab567 will get in touch and assist with all those questions.
12v battery low
Have you monitored the battery voltage under various conditions - ignition off, ignition on, just after starting, while driving several minutes after starting and while braking? Those measurements will give clues whether the Battery Management System is working correctly. I use something like this in the 12V socket LED Voltmeter USB
the truth about electric cars
I've always been puzzled why the Type Approval regulations specify brightness of the indicators, but say nothing about their proximity to other (brighter?) lamps which make them more difficult to see? They've allowed form (design & aesthetics) to override function (visibility) IMHO.
OT slightly but: Some of the worst examples of barely visible rear indicators are where the indicator is a iny amber dot surrounded by the brake and side lights, and yesterday I saw a car where the front indicator is in the same lens as the halogen DRL so all you see is a slight increase in the amber/orange light.
According to this road transport accounts for 15% of global CO2 emissions, so while it's significant it's not the major source.
- Octavia 2015 1.6TDI error: start-stop system
DPF ON CAR CLEAN ADVICE XX
Module 13 is the ACC radar???
Car Bluetooth not working after using Android Auto flash drive on the car
I really think you need to find someone locally with either OBDeleven or VCDS and ask them to do a scan for you.
What scanner did he use? A non-specific VAG scanner is unlikely to detect faults in the infotainment system, as they are often restricted to critical systems such as engine, ABS, transmission, etc.
Refilling Air Conditioning Refrigerant — How Difficult?
When done properly the refrigerant usually also contains an ultra-violet sensitive dye (as well as the oil for the compressor) that can be used to help locate leaks.
Octavia 2025 SEL - Front heated Windscreen
That's correct on the Mk4, the heated screen has an all over film not the individual heated elements. As the screen heats then I'd suggest that even though it's not a Skoda branded screen it's a proper replacement.
To save more guessing it might be an idea to post a fault code scan of 5F made with either OBDeleven or VCDS.
- DAB Radio has weak/no signal
@pab567
Most members of this site are not representative of the car driving population of the UK, which you seem to keep forgetting. Most UK residents do not have solar on their homes, and even less have solar with batteries. A significant proportion do not have driveways so cannot be sure of parking within a cable reach of their home. Taking all these factors into account there is a large percentage who will be dependent on public chargers, so the cost and UK wide availability of public EV charging is what is limiting EV take up.
Head Unit display failure !!
So that's a 14 reg not an H reg!!! HJ is the location it was registered - the Bournemouth office. 14 is the 6 month period it was registered March 2014 to August 2014. VDD is the "random" letters specific to your vehicle.
I'm puzzled by 2014 being H reg? In the UK a 2014 would be either 14 or 64 reg? Or are you not in the UK?
2016 Škoda Octavia KESSY Stopped Working
I suggest getting a good diagnostics scan done, with OBD11 or VCDS, which will likely show a problem with the sensor in the drivers door handle.
- Legal H7 led mk3 ŠKODA
Infotainment issues 13.1
Please post only in English.
- Increase in road tax
For that to happen two things need to be in place first IMHO 1) the huge difference in cost per kWh between public and home charging needs to reduce drastically or even disappear 2) the number and locations of public chargers needs to increase hugely in ALL areas not just the current hot spots.
- Mk3 to buy or not
