tetley
Everything posted by tetley
  1. As no one else has replied... Firstly, give the sensors a good clean. Dirt on the sensor can send them haywire. VCDS can identify sensor faults - maybe Christmas can justify the purchase. VCDS can also "uninstall" the rear parking sensors module from the installation list. The module itself (on my hatchback) is in the boot mounted on the LHS behind the side covering. I expect the estate/combi is the same as the floor pan is identical on both models. Without VCDS I would unplug the module from the loom.
  2. Stupid question but is ATA Confirm ticked in the Maxidot display?
  3. 0.5mm2. BR is the universal wire colour for earth. The 11 in the box is to fuse 17 in the E Box. Which would be the engine compartment fuse box. The other end of the fuse is connected to the car battery, so is a permanent live.
  4. I'm guessing that's 1.0mm2.
  5. I had rain water entering the boot through the seals for the rear lights lenses. I removed the lenses cleaned the seals and refitted. The boot has been dry since. Worth cleaning and refitting even if water ingress is from elsewhere as they were very mucky.
  6. I am not sure exactly what you mean. The switch mechanism is part of the light unit. How do you know the light is on if the glovebox is closed?
  7. The MDI is/was a propriety USB port as an option on VAG group cars. On my car I have the MDI cable to USB female. https://www.ebay.co.uk/itm/287319846346 Plugged into that I have a 500GB HDD that contains all my music files. Works great. I have seen an MDI to bluetooth receiver if that works for you. https://www.ebay.co.uk/itm/356780893277 You can get iPod cable adapters as well.
  8. When removing the glovebox in my Octavia I disconnect the earth terminal on the battery to prevent air-bag errors from occurring. Might be of use to someone who does not have VCDS.
  9. No. It's when the headlamps turn into a corner. You know if it's fitted as the headlamps will move in then out and then up and down when lights are switched on. As for the OP. I have no idea how they work.
  10. I just pulled down with my fingers. It slid straight out with no resistance. Why it could be stuck, I just don't know.
  11. Looking at the video the lever has to be pushed in before turning. Probably why I never got it to lock properly. I must admit I spent a good hour fiddling with that lever. @jaosef Good luck👍. Didn't know you were doing it now.
  12. Here you go.......
  13. It's for when you remove the bearing pin as part of the drain procedure, so the gearbox selector does not move out of position. When I did the gearbox oil change, I removed the bearing pin and held it in my hand as the oil drained then carefully reinserted. The lever used to lock the gearbox is plastic so I was not 100% sure the selector had been successfully locked in position. As long as nothing is moved gearbox wise with the pin removed it should be OK.
  14. CamScanner 06-05-2026 16.48.pdfCamScanner 06-05-2026 16.46.pdf These are the PDF instructions from the workshop manual for the MDP 6 speed gearbox.
  15. I did my gearbox oil for the fist time earlier this year. On my MK2 1.8 TSI you drain the gearbox via the drain plug as you have indicated and by removing one of the "fork bolts". You have to lock the gearbox in position first by moving a plastic locking lever under the air filter box. To fill remove the reverse light switch then using a max 10mm OD tube pushed into the hole a measured amount of oil. This is because the gearbox is mounted at an angle and the fill hole is now below the oil level. My MDP gearbox is 2.3 litres of oil when built but is 1.9 litres when draining and then filling. I suspect yours is the same.
  16. Is the engine running when this happens? With the engine off does the pedal stop at the normal/higher position? When in motion does the pedal stop at the normal/higher position? If so it is normal and you never have noticed before. @Alasdair1 asked the same question a while back, so I thought he would remember. Can everyone confirm this.
  17. On my MK2 FL L&K 1.8TSI I had to remove the carriers to get the discs off. It took an entire day to undo the 2 carrier bolts (2 days to do the rear discs) so if the discs could be removed without removing the carriers I would have done it.
  18. This is the 2009 sales brochure for the MK2's including the limited edition VRS. brochure_octavia.pdf
  19. Do both fobs lock and unlock the car? That alone would tell me the cluster has been cloned.
  20. Maybe speak to that auto electrician again. Both clusters should now start the car if the replacement cluster has been properly cloned.
  21. Simply NOT true. I don't know where your getting your info from but it's wrong. I had my own PETROL cluster replaced with a replacement DIESEL cluster AND of a later version - originally 1Z0920943F SW:03 to a later 1Z0920943S SW: 06. The EEPROM data and software are not the same thing. The later software includes newer bluetooth icons and now displays the message "Press Clutch To Start" but that has no effect. I can still start the car without pressing the clutch as before. The cluster also now supports Maxidot TPMS but again won't work if activated. I got retired forum member @Eddie-NL to do mine. He even changed the part number to the correct revised part number. I don't know all the exact details how he did it but BOTH keys were correctly coded to the car even though the spare was 200 miles away.
  22. "Safelock prevents people breaking a window and reaching in to operate an internal door handle. When enabled, the car doors can't be unlocked from the inside, so there is a safety risk for any passengers who remain in the car if the driver gets out and locks the doors." https://www.trocforums.co.uk/threads/please-check-safelock-vehicle-wallet.3533/
  23. You could use a cloning service instead of trying to obtain SKU/PIN codes. Probably cheaper as well. https://jccars.co.uk/instrument-cluster-repairs-programming/ Half way down the page:- "Our VAG cluster cloning service can be used if you have a faulty Instrument cluster on your vehicle, for example it may be water damaged or have a blown component. If you are looking to replace the cluster on these vehicles you may be aware that you cannot simply remove one from another vehicle & install it onto yours as the cluster is ‘Locked’ to a different vehicles electronic / immobilizer system and the mileage will be incorrect. We have the solution! Simply send us your original (Faulty) cluster & the donor (Replacement) unit & we will transfer the data from your original to the replacement enabling the used unit to work on your vehicle with no further programming necessary. Once the donor unit has been programmed (Cloned) the coding of the unit will be correct & the car will start & function as it should. The mileage display will show the correct mileage of your car & your key data will be transferred – The central locking etc will be unaffected & operate correctly. We do NOT need the PIN code from your vehicle or the donor part to do this operation – We are able to clone these units even if you have ‘No communication’ with diagnostic tools – Your vehicles immobilizer PIN code, Component security number & MAC code is supplied to you at no extra cost with this service."
  24. Mines on 46K with full MOT and servicing history to back it up.
  25. Very possibly. Why else desolder the EEPROM? The mileage is also stored in the ECU and some other systems. See here for using VCDS to check https://www.ross-tech.com/vcds/tour/EDC-15-Mileage.php If it's for a petrol car (I think it is - as it looks to be petrol), yes but check first. Software version is good. I've been over to see them and they are a good help. Phone is 07753 912720. VCDS can do the coding but you will need both SKU immobiliser code (PIN) from the old and the new replacement clusters. VCDS can NOT retrive these codes. You will need to find a specialist who can. See here: https://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Immobilizer_Swapping_(Instrument_Cluster) for instructions on swapping instrument clusters with VCDS.
