softscoop
Everything posted by softscoop
  1. A mk1 Fabia will not have a silica bag in the coolant. I presume that the fans work on all 4 speeds?
  2. I think most have missed that the OP has a Greenline, so will already have 16" wheels as standard. If your wheels are corroded, you'd probably be better off simply looking to get your existing wheels refurbished, rather than sourcing other wheels and then having modified wheels, which dependant on your insurer could make a difference to your premium.
  3. Most of the guides you are reading are for the newer generation MQB cars. As said, pretty sure it's not possible with the PQ35/PQ46 platform cars.
  4. There are plenty of sellers on Ebay who can get the PIN from the radio serial no.
  5. You won't need to upgrade the gateway on a 2011 car. You only need to do that on anything pre 2008. On the earlier cars with the older gateway fitted, the newer radios would never fully power down so would drain the battery.
  6. Is it on the inside or the outside of the screen?
  7. If your profile is correct, and this is a 1.6 Petrol Octavia, then it can't be a DPF issue. DPF is diesel particle filter, so you don't have one. Exhaust light could come on for a variety of faults, only way to know is to scan it and read the fault code. If you can't find a local member with VCDS, most independent garages should have the equipment to read fault codes, much much cheaper than main Skoda dealer prices.
  8. Classic symptom of the thermostat being stuck open allowing the coolant to flow through the radiator before it's even luke warm. First port of call is the small inline thermostat on the oil cooler to the DSG gearbox. They are dead easy to change DIY, should take about 30 minutes.
  9. The "button" is a reminder light if you switch the passenger air bag off with the key switch in the glovebox.
  10. Mine does this on the odd occasion. Usually the mirrors stop folding when holding the lock button. When I unlock it after, all 4 windows drop about 1". Put the ignition on, roll all 4 windows all the way down, then all the way back up to the top. Once at the top, click up once on each window control again. That resets the limits and sorts it out.
  11. These are still turning up. Cheap Elegance here. Shame about the general condition EU56 VZP https://www.facebook.com/marketplace/item/518162480327205
  12. This video gives you a great overview of how a clutch works. Thi
  13. If there is an increase if revs without the road speed increasing at the same rate, then suddenly the revs dip and match the gearbox/road speed, the clutch is not able to transfer all of the power from the engine into the gearbox. Whether this is because the friction plate is worn, contaminated with gearbox oil or the pressure plate isn't providing enough clamping force I can't tell you. Get yourself over to another independent garage for a second opinion.
  14. That sounds like a slipping clutch. I assume you have a manual gearbox?
  15. The Pd105 doesn't have a DPF in the first place.
  16. Which ever viscosity of oil you choose, make sure it's either 505.01 or 507 rated, otherwise you will end up with camshaft problems.
  17. Unless you have retrofitted direct TPMS, there are no sensors in the wheels. It's all based on the speed readings from the ABS sensors.
  18. Even better than copper slip would be Ceratec. https://www.eurocarparts.com/p/pagid-ceratec-brake-lube-75ml-grease-526770250 https://mintex.com/copper-slip-vs-ceratec/?lang=en-gbr
  19. That wheel is for a mk3 Octavia, which is not compatible. From my limited knowledge on the subject, you need to find a multifunction wheel from a vehicle on the same architecture/platform. MQB parts from the mk3 Octavia aren't compatible with the PQ46 platform of the MK2 Superb. I have seen others fit the wheel with paddles from the MK2 Octavia.
  20. Genuine DSG fluid from Skoda/VW is around £20 a litre. You can get 5L of DSG oil to the same specification from other oil manufacturers for around £40 https://www.amazon.co.uk/febi-bilstein-39071-direct-gearbox/dp/B00FZGK4G4 Looking at the breakdown of the other items, I would say it has been serviced properly at a very reasonably priced garage.
  21. Have a look here https://www.youtube.com/watch?v=eeOoDJuhSx8
  22. It seems that Skoda have stopped doing the flip up rear bases a few years ago. Looks the same on the Superb too. A great shame as it meant you could have a totally flat floor, much more useful when loading long flat pack items etc.
  23. That was on the vrs. The elegance that the OP is looking at will be a PD140 which won't have a dpf.
  24. If it's a PD engine, unless it's a 4x4 then it won't have a DPF fitted.
  25. How did you get on with your warranty claim? Generally 6000k bulbs emit less light than decent 4300k bulbs, and with cheapo bulbs, no 2 bulbs are going to perform the same leaving such a wide variation in quality and brightness etc.
