Everything posted by softscoop
SUPERB MK2 1.6 ESTATE REVERSE AUDIBLE ALERT
Disconnecting the speaker will totally disable the entire system unfortunately. Can you post a picture of your instruments and radio setup?
Fabia Mk1 with Factory Sat Nav/Maxidot
Nice find. That looks like one of the most comprehensively specced cars I've seen. The only thing I can think it's missing is leather, which I don't even think was a an option in 2004 anyway. Bit pricey though!
Temperature Guage
Is your car a dsg? It's quite common that the inline thermostat to the oil cooler for the gearbox can stick open, causing the above symptoms.
Tyres any recommendations
What is your budget?
Help sourcing a wheel speed sensor.
Autodoc list plenty of different manufacturers with that part no, including ATE https://www.autodoc.co.uk/car-parts/oem/wht003858a
- How Does Light Sensor Correction Work
Another Boot Gas Strut Mystery
Is yours an estate or hatch?
Interior Door Handles
That looks like a vast improvement
Cracking in between the treads (long ways) - is it safe to drive?
Yes the date of manufacture is part of the DOT code: It's in a 4 digit format 2 digits for the week, and 2 for the year. https://www.kwik-fit.com/tyres/information/tyre-age#:~:text=The four-digit tyre age,represent the year of manufacture.
Hello, is it me you’re looking for??
Hey up! It's been a while. What are you driving these days?
Selling Privately: Marketplace, AutoTrader, Ebay or Gumtree?
When I sold my Octavia last year, I listed it on Autotrader as well as Facebook. It also was drivable with plenty of MOT, but had faults that would need fixing before the next one. As you said, marketplace resulted in lots of daft questions or "is it still available" without any further interest. I priced it to sell. Not silly cheap, but slightly cheaper than the difference between the parts and what it would be worth without the faults. I took a deposit within 1 hour of it being live on autotrader, and was collected later the same day. It didn't cost anything to list, as you get a free 1 week listing if it's under £1000, which I assume your A4 also will be?
Anyone own a mk2 octavia sport??
Ok, so I think I have found one. This place says they have 5 in stock but it is €38.74 + €13.44 postage to UK. https://alvadi.cz/en/original/16710058-FAA610012-VAG?sv=5
Wow this really is a challenge. I found it listed for sale here: https://www.autokelly.cz/Product/VAG-FAA610012/11922992 But it states: Available in: 0 branches Not on the central stock Looking at the pictures of the item, it looks like that earlier part no you found was correct "1Z0 807 449" This literally returns 0 results on Google. Looking at the pictures, it looks like a low volume, low quality plastic part. I can't find anywhere that has it listed as in stock.
DSG oil change, proof it's done
5 litres is the normal amount to order when doing a DSG oil change. Usually around 4.3L is drained when undoing the bottom plug, and was around that when I last did mine. If they're only draining 2L, then either the box was very dry and probably would be broken at that point, or it wasn't a wet DSG box.
PD170 TDI Coolant Hose Part Numbers
Have a look here: https://skoda.7zap.com/en/cz/octavia/oct/2007-419/1/121-121052/
Soundproofing My Fabia
One other thing to look at is what about your tyres? Different tyres can have a huge amount of difference between how noisy they are.
Well well, another one has shown up: LN04 AVJ https://www.facebook.com/commerce/listing/1182966285785791 Nicely specced. Xenon, sat nav, sunroof
Ok, I've done a bit more detective work on this. Part no FAA 610 002 is the lower rear bumper spoiler with "Sports suspension kit" This website lists the spoiler, and in the description is the below Replacement cap for towing eyelet art. FAA610012 This corresponds with no 7 on the above part diagram (trim for bumper tow hitch)
Are you 100% sure the part no starts with 1Z0 ? I would be very surprised. The part nos on the Mk2 Octavia are split into 3 groups. Each start with : 1Z0 is generic to the entire Octavia range. 1Z5 is used on parts specifically for the hatchback 1Z9 is used on parts specifically for the estate (combi) As the Sport was only ever sold as a hatch, I would expect the cover to start with 1Z5. Looking at the parts catalogue, there is no different part listed for the for Sport model. Given that you have tried the scout and the regular cover, looking at your pictures of the bumper, will the vRS cover fit? Looks different to the scout trim. https://www.skoda-parts.com/spare-part/1z5807441a-towing-lug-cover-rs-14080.html This is the catalogue for the vRS, which shows the different part.
There is one being sold on eBay at the minute which looks like it has the cover in place. Might be worth getting in touch with the seller and see I'll they'll help you out by having a look at the cover for a part no. https://www.ebay.co.uk/itm/304481635069?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=BXpsMDiVS5-&sssrc=2349624&ssuid=&widget_ver=artemis&media=COPY Actually scrub that one, looking again it's a regular Ambiente where everything on the bumpers has been colour coded.
Washers and spray nozzles
Ah yes well spotted.
Can you not get hold of the correct ones locally? When I had my preFL Octavia I had to replace one of them. I bought a genuine one which wasn't expensive at all. Part no 1Z0955985
Octavia 1Z pre-facelift wagon water leakage on pillar
Has your windscreen ever been replaced? The pillar trim comes off easily, but with your airbag, disconnect the battery, pop off the airbag cover and unscrew. Then the trim pops off with clips. You might then get a better picture where the water is coming in.
What is this insulation cloth part called/part number? It separates the engine from the cockpit.
https://skoda.7zap.com/en/cz/octavia/oct/2010-663/8/863-863020/#23 Item 23. 1K0863993 The correct suffix for your vehicle depends on the model year.
Superb 2 - 2011 factory towbar
The key lock should just prevent it being stolen, the functionality of the towbar should be exactly the same with it locked or unlocked. I very much doubt you will break the towball with a hammer. A 750kg unbraked trailer will put much more force on it than you could do.
