Everything posted by Awesam
Because he's old and bored! 😝
DCC worth searching for, or fit Koni Special Actives?
I've got a L&K Estate 280 and have upgraded to B16's with DCC. My ride height is lower than the Sportline version about 10mm. I keep them mostly in comfort its the best to soak up most of the imperfections in the road, Normal can be a bit firm/uncomfortable if the road is bad. The best shocks I would say are KW's as they their comfort and performance levels are amazing.
**SOLD** Fabia VRS 2005 173k Miles
Still Available?
272 Superb OPF stageIII
Pm me some details please! 😁
Great to heard that. You've been running at stage 3 nearly 2 years now? Have you had many issues? Also what did you do with the Supersprint rear mufflers?
Skoda Superb Sportline with Chrome Grill?
Bridgestone Potenza are a noisy tyre and horrible grip levels in wet/cold weather. Great in the summer though. Yes Skoda did skimp on the sound insulation in the Superb however I've added some and it's a big improvement. I will be upgrading to 19s and planning to get some Goodyear Assymetric 6
Clunking and creaking from rear suspension
Yeah, that's not going help! A way to check is apply loads grease to the front and rear anti-roll bushes and see if that makes a difference
The rear clunking could be the rear drop links or bushes needing replacing. The front creaking is very common and is caused by the top mount bushes, it's across the MQB range of cars. The potential solution is to use Audi TTRS 8V top mount bushes.
It maybe there was damage to the grill as the bottom trim in the bumper is still black along with the side trims as well as the mirrors.
DCC Slider adjustment option mod
The issue is no one in the UK is doing this mod yet! There has been quite done in Australia though.
Was quoted £180 for a new bcm fitted and you can buy a 2nd hand DCC controller from ebay from £60+
Help Superb 280BHP Engine Light Flash and ECU Light On, No Codes Stored
Could be a coilpack on its way out hopefully thats all.
A throttle controller is probably the best simplest upgrade on the Superb. It's a 2nd hand bargain.
***Sold*** - Skoda Superb 280 Estate Sportline DSG for sale
Not much out there which can offer what the Superb does! If only there was a RS version! 😆
Offside front and rear water ingress
- Offside front and rear water ingress
If you have a sunroof then most likely the drain pipe is blocked and needs cleaning. There is thread covering this in the forum.- Superb FL with Golf 8R engine
CJX is a Gen 3 engine with a IHI IS38 turbo.- New 19” tyres required, which ones
😄 When did I say expensive! Instead of going for bargain budget tyres go for mid range which have tried n tested like Nankang or Kumho ideally in that category i would go for Uniroyals or Hankooks- Superb FL with Golf 8R engine
I'm not saying that it's not possible however it would very rare as here in the UK we usually get shafted on options/spec along with higher prices in comparison with Europe.- Superb FL with Golf 8R engine
Lucky guy! I would say that in the UK it would be a rare case of getting that engine here- Superb FL with Golf 8R engine
I think he's asking if anyone who has a Superb FL can check if it has the E888 Gen 4 engine with the Continental turbo rather the Gen 3, and to share the engine code! Very unlikely in any case to have a Gen4 engine in the FL.- 2018 superb S spec screen upgrade
Is the screen resolution better on the touch screen display (3V0919606D) compared the older button version (3V0919606)?- New 19” tyres required, which ones
Why would you buy cheap tyres when it's the most vital component to keep you in contact with the road, especially in handling and braking!- What have you done to your Superb III today?
LOL only the ebay link works, the Amazon links revert back to this page!- New 19” tyres required, which ones
Im planning on buying some 19's Assy 6 aswell. Currently running on 18s with PIrellis P Zeros so hoepfully wont get worst than this! What tyres did you have before the Goodyears? - Offside front and rear water ingress
