First mot issues
2, 3 get alignment checked, toe probably slightly out. 1 normal. 4 brake harder from time to time when no-one is close behind, should improve appearance of discs.
Alternator
Haynes is not right. 14.3-14.5 when cold, dropping a tenth or two when hot is fine.
Battery Drain
Strong fix!
Genuine Skoda Oil Filter number?
Fling me your VIN in a message.
the truth about electric cars
He knows far less than you do about electronics. I'm lying.
Another one bit the dust
Nope, they're just notoriously unreliable on the 1.6CR engines unfortunately. If you can eyeball the wiring to that injector connection, could be worth checking for wire damage, but I would've thought your mechanic would've spotted any such problem while unplugging/reconnecting.
Drivers one touch window not working
No gun jumping visible from where I'm sitting.
Weird behaviour when using turn signal
Could be a wire broken rather than wires shorted. In some positions the broken ends remain touching, in others they're pulled apart? A wire from the ignition switch, for example, could have widespread effects if intermittent. All speculation, but worth a free look before starting to fire up the parts cannon, I think.
Isn't the obvious thing to look for a wire or wires that are being affected by movement of the indicator stalk? Some disassembly of plastic covers may be needed, possibly only the top one? Someone may have been in there previously and not put a wiring loom back correctly, in a way that means it has now been damaged by mechanical movement.
"This story is too good to check" Spoken by a journalist acquaintance of mine.
Who has replaced a coolant temperature sensor..?
There's a fair amount of choice of video guides for connector unplugging if you've never done one before. The executive summary is "push connector body towards sensor before trying to release latch". Many latches are broken by those who do not realise this simple technique is required. vw connector removal - YouTube
Front window prob
Thought it would be. There's a progressive hardware failure in the electronics that exhibits more at lower temperatures. I can offer repair by post at much lower cost than replacement. https://www.briskoda.net/forums/topic/497084-window-motor-repair-service/
Front window prob
I presume this is a facelift car, with the two-connector window motor module on driver's side?
Cooling fan
It's the 360mm fan you have broken, The part number with suffix CS was superseded by the part number suffix EA, before your car was built, so the EA one would seem to be what you need. Secondhand or aftermarket recommended, as Skoda will ask for a breathtaking £327.44 for that item.
Resetting "Error: start-stop" after battery change.
How many times have you used the car in total since the new Exide battery was fitted? If not many, I still think the car will adapt itself to the new battery in the same way it learnt about the old one. There is/was a member based in Newport with VCDS on the owner's map of this forum, but they haven't been on here for a few years. Nothing to lose by trying to message though: https://www.briskoda.net/forums/profile/158542-greengolf69/
Whereabouts are you @Buttie? I think someone/anyone with VCDS could solve this for you in a short time.
Held in by a single torx screw I believe, but you may well need to remove the metal bracket that screws through the housing next to it (as seen in the close-up photo of the position in the ebay listing linked previously in other thread). How sure are you that it's faulty? My advice would be to disconnect and inspect the connector before anything else, looking for any sign of corrosion on the contacts or damage to the wiring near the cable entry. Do you know the knack of removing these connectors?
vRS ride height increase
Missing a character, a 0 as the third one - I'd expect 5Q0511115AF
Coolant: Check Manual "Ding, Ding Ding - Red symbol"
First image in this ebay listing here shows it close up. My marked-up screenshot of one of the other images shows the big picture. Just below/next to the radiator hose connection where the pink arrow is.
ABS-sensor error, possible to swap wires to troubleshoot?
Sounds like an unusual failure of the cooler. Maybe investigate prices of a secondhand replacement?
Part numbers
1J0 512 109 Not usually fitted in my experience. £4.25 + VAT each from dealers if you do want.
MK3 HEATER MATRIX REPLAEMENT
Yeah, I found that out after they sent me the VIN. I suggested the same strategy of looking at blower motor for any telltale brand label. I didn't know the specifics of access though, so thanks for adding.
SOC Indication is not Showing up !
Not an issue, and I doubt there is such an update available.
I believe it was a feature that was disabled in software. Probably due to customer anxiety about it reading consistently lower than expected (by those who don't understand the planned undercharging).
2017 Skoda Kodiaq Coolant leak through wiring harness to ECU
5 years ago, it seems:
