Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Help on rear coil springs uk
Severe engine judder at 1500RPM
Glad you got there in the end. And good on you for closing out the thread with the relevant info.
Did you adapt the ECU to the new EGR (either time)?
Engine mount bolts
It's far from obvious to me looking at this diagram, but maybe you can match up what you need with the real bits and pieces in front of you to look at: https://skoda.7zap.com/en/cz/octavia/oct/2002-252/1/199-199020/
Felicia coughed up a spark plug
Breezy_Pete replied to Another_Felicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanLooking at the fracture points, right by where the electrodes are welded to the rest of the metalwork, I'd say they have fractured in response to impacts possibly during the final stages of its 'escape' from threaded attachment.
256mm to 312mm brake upgrade
Only thing to bear in mind with companies like onlinecarparts.co.uk/autodoc.co.uk/buycarparts.co.uk is that despite the .co.uk web addresses, they're all operating and shipping out of Berlin, Germany. May well all be the same company, pretty sure the first two are, at least. Fine when everything goes well, but less handy if anything is wrongly supplied etc. and needs to be sent back. Delivery times may also reflect the distances involved.
Front wishbone -MOT fail
According to info @Tech1e posted once upon a time, these bushes are the same as used on a mk2 Golf (and probably a host of other applications, PN 357 407 182. £15 each genuine according to this site (which I by no means recommend except for price-checking, as they let me down badly recently, and very unapologetically) https://www.allcarpartsfast.co.uk/vw-audi-seat-skoda/vw-audi-seat-skoda-357407182-rubb-mount/ So when you can buy a whole wishbone for twenty-odd, just not worth the grief at all. BTW, seeking out the cheapest garage for these jobs isn't always he best strategy long-term, cos if they're doing it for next-to-nothing, they'll surely re-use the long bolts that go into the consoles, stitching up the next person who tries to undo them as they'll likely gall up and rip the thread out of the aluminium or just jam up solid. That's why they're single use, nothing to do with stretching, IMO, all about corrosion.
Felicia voltage gauge
Breezy_Pete replied to Another_Felicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWell worth measuring, I don't believe those numbers at all.
Breezy_Pete replied to Another_Felicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHave you actually measured the current it draws @Another_Felicia? I think it may be a little more than you expect. I have an LCD voltmeter module plumbed into my car, which has the disadvantage of not being visible in the dark (without light pointing at it), but the advantage of drawing only 0.5mA.
Yorkie2
Hi. A great starting point would be to tell us which engine type your car has. Age of car and mileage too would be good. What makes you think something needs cleaning?
What are the OEM spark plugs on a BBY engine?
According to ETKA, it's the first or third 'item 11' depending on whether manual or automatic transmission. https://skoda.7zap.com/en/cz/fabia/fab/2004-225/9/905-905000/ So NGK BKUR 6 ET-10 for manual gearbox, or NGK PZFR5D-1 for automatics. Economy versions also available.
Karog Stop start not working
Yep, poor design.
How to replace thermostat on 1.9 SDI
M7 thread I think, awkwardly. Will look up part number and length shortly.
Rev and pull issue
Clutch slipping? Which engine does your Fabia have, and how many miles on the clock?
Cooling fan trouble
Check fuse 24 in the E-box under the hood.
Does my 1,4tdi BMS engine have a single or doublemass flywheel ?
Flywheel part number is on here, if that helps at all? https://skoda.7zap.com/en/cz/fabia/fab/2010-608/1/105-105010/ 045 105 269
Octavia MK1 - Door Lock Failed & Deadlocked!
RHD car? If so it looks to me like the last listed item 1 here https://skoda.7zap.com/en/cz/octavia/oct/2005-252/8/837-837000/ 3B2837016T Are you sure it's not just the lock barrel needing refurb? Various youtube vids and kits of bits available.
Which torque wrench do I need?
I don't see any obvious need for a torque wrench for this. What you will need is a bit of the correct style and size for the screw heads. If the ones on your car are the same as what was pictured on the thread you linked, they are XZN/triple-square type, not Torx as someone on there posted.
Joining 'Freedom' for £10/yr opens up unlimited editing and photo posting. https://www.briskoda.net/forums/subscriptions/ To position photos within posts, put your cursor where you want the image, then click on the + symbol on the LHS of the preview of the upload. If you do go down the route of buying new bearing carriers and bearings, make sure whoever fits the bearings is equipped with the appropriate (GEN2) tooling and knows how to use it. If the bearings are not fitted correctly by this method, they'll be damaged during fitment, and you'll be back and forth trying to fix things, with the garage blaming your bearings and all sorts of grief. There still seem to be a lot of garages out there who'll just cheerfully press them in by the drive flange, which either causes immediate problems, or ones that appear later.
Cooling fan trouble
I'm rather unfamiliar with the type of fan control that I think your car has, but I did find a couple of snippets of info online last time I tried to understand it. A couple of posts of mine about halfway down this page: https://www.briskoda.net/forums/topic/470840-aircon-puzzle-intermittent-cold-output/ I think subsequent to that thread I did suggest to one owner of a car with this arrangement and a 'fan coming on when ignition switched off' problem that his fault might be the result of water ingress into the connector that goes to the fan control unit on the main fan, and I vaguely remember that something was found, so maybe worth a look in there?
- 256mm to 312mm brake upgrade
09/18 will mean week 9 2018, so early March, I guess.
How to prove Windscreen is leaking ?
The other thing to do is to look at each door opening after rain, checking for water on the horizontal bit of each inner seal. If you find little puddles on any of them, that door is leaking. Here's a picture of the offside rear door of ours with some water showing where I mean.
Help, Skoda Fabia MKII all interior lights not working but its not the fuse
Monitor your battery voltage for a while (e.g. once a week for a few weeks, looking for any downward trend)) to make sure you haven't just introduced extra parasitic current. This seems to happen sometimes when people change incandescent bulbs to LEDs in interior lighting. For reasons I've not figured out, they sometimes seem to make some circuits not shut down correctly when the car is dormant.
Check that there is 12V on both sides of fuse 23, with it in place.
Hmm, that's the one.
