Do i have to program new driver window moduler?
What year is the car? Mk2 Fabia had at least three different types of window motor depending on year. None of them can be coded. The window switches work by shorting the inputs of the module to earth, mostly via resistors, but directly in one position, so I can't see how you would do damage. Was/is the one you've swapped in identical in appearance and part number? What is or isn't currently working?
2010 CR170 Mystery Current Consumption! Flat Battery
Engine bay fuse 9, I suspect. Seems you do have the telephone preparation package, according to car data. "Telephone/telematics 9ZG - preperation [sic] for mobile phone with hands-free system" Not sure how you'd go about uninstalling/deleting that, but you could try simply removing that fuse and seeing if that causes anything else to stay awake. "Whack-a-mole" springs to mind. 😆
What fuse number is this 5 Amp 'phone' fuse? Glad they sorted a fully working alt for you. 🙂
Map sensor fault 2.0 cr
Hi Loek. I can't really add anything that I haven't said above; circuit section is shown below, T4bl is described as "4-pin connector, in the holder on the gearbox (black)".
- Skoda Fabia Elegance
OK, a 1.4 16V petrol. Yours probably has a combined engine cover/air filter rather than the silly cone filter in this image, and it may be easier to see where you need to if you remove that engine cover, but that may not be necessary. Look vertically downward, preferably with a torch, in the area where the orange ring is, trying to see something similar to the image I posted above, possibly with a wire floating around loose.
- ABS Wheel Speed Sensor
Washer fluid level warning
It might be that there is a setting somewhere that has accidentally been switched to 'don't display washer reservoir low level warning'? I know in some much earlier Skodas you can change the coding (with VCDS) of the instrument cluster to include/exclude such warning info. That sort of software switching is presumably possible via user interface on current models?
I don't see anything in the PR code list that really gives a clue one way or the other, although it does say without headlight washers, which might be one reason for omission. Parts list suggests 5E3 955 448 A for the reservoir bottle, which appears to include the level sensor as standard. Pics in an ebay listing for that PN show it just to the right of the washer pump motor connector on the rear-facing side. Taking a few screws out of the front part of the NSF wheel arch liner may give enough visibilty to check presence/absence. Example listing/pics: https://www.ebay.co.uk/itm/376100484562
@andypollard, if you let me know your VIN I may be able to find out if your car was built with this level sensing or not.
Skoda Superb Mk2 - CBBB Coolant Leak/EGR Advice
Given that a new genuine cooler is lots of cash, and even a pattern part is over a hundred, I'd be tempted to raid scrapyards/ebay for a 2nd hand 03L131512B and try your luck. Probably DIY fit-able? Then do a coolant drain and flush and see if that clears stuff out.
Sorry, think I've misunderstood that. You mean the heater matrix seems clogged?
I guess the soot is coming from the leaking cooler, out of the now open coolant connections? Maybe good to get a replacement on there soonish to eliminate that. Trying to think of a safe way of blanking them off, but hot exhaust gases will need something metallic and robust.
If that's what you've bypassed and it's now OK, then you've done a good diagnostic test with a good outcome. No problem driving the car like it is until you can get a new cooler on there, I believe.
@VanhireBoys it does have a cooler. Shown as item 7 here: https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/1/131/131080
Need help finding the right front wishbone arms for my Fabia II Combi
Replied with gen numbers. Image of genuine item here, not like what @Murdockman is describing. They were only used in very early mk2s up to some time in 2008 I seem to remember. Front left wishbone Fabia Ibiza Roomster 6R0407151E New genuine Skoda part | Deutsche Parts
If you share the VIN or reg with me, I can look up the genuine part number(s). Alternatively, ringing either of those suppliers with VIN or reg to hand will probably yield the same or better results (because genuine part number doesn't necessarily lead you to the correct ECP/GSF part number). Their screens have a better look-up than the public websites, I understand.
Stripped threads caliper slide helicoil size
Guide pin thread is M9 x 1.25mm pitch I think.
Lots of stuff to move out of the way to create an exit/entry path, presumably?
Private message sent. 🙂
The wire going to the strip fuse goes only to the alternator output stud, I would expect. Let me know reg or VIN and I can look up the circuit diagram if you wish. The two other wires are excitation (blue usually) and field monitor. First helps the alternator 'boot up' when first rotated by supplying a small current to the brushes. Second is a signal telling the engine ECU how much of its capability the alt is supplying, moment by moment.
Doesn't matter at all without a BMM, although a slight safety gain by making last connection of jumpleads away from battery and any hydrogen it may have emitted.
