Brake servo vaccum hose part number. 1.2HTP or equivalent pipe.
Part number is written in white all along the hard plastic section. 6Q2 612 041 and then a couple of crucial letters. The letters are the only difference between a bunch of different types for different engines.
Radiator fan query
As an alternative, if you have a multimeter, you could measure the volts between pins of the connector that comes out of the big fan towards the little fan, to see if there's 12V there when the big fan is running. Just be careful fingers etc don't get involved with the big fan.
Radiator fan query
Looks like the fan control module is integrated into the main fan, with the smaller fan powered from it, so not quite as clear-cut as if I'd found a circuit showing the fans wired directly in parallel, like many of the earlier versions are. I still think they should probably run together, so maybe try powering the small fan directly with 12V, to see if that makes it run (disconnected from its big brother/sister).
Radiator fan query
Can you please share the reg plate or VIN with me so that I can look up the relevant schematics and parts info. I think the two fans should probably operate together, but need to check.
how do i open erwin downloaded documents and sheets?
They don't lead to the same place. You can see everything that's available in "individual vehicle info" without paying the flat rate, so have a look first and note which files you want. Only after you pay the flat rate do the download buttons appear for each pdf. The tab you were in is a subset of the other, showing only the info specific to your car/VIN. The place with the pdfs covers every car of each model, so the documents are much bigger, more general and require a bit more effort with 'ctrl-f' to find stuff specific to your car. No idea about your last question, I haven't tried it.
Skoda Fabia 1.4 TDI 2008 model (RightSide Steering)not starting, No crank, Glow plug light blinking.
If you did not find a broken wire in the location I described then my idea is not correct. Engine ECUs are incredibly reliable in recent cars. Very, very unlikely to be that.
- how do i open erwin downloaded documents and sheets?
Were the files that you downloaded in pdf form? I've never had trouble. Once you're in and paid up for your hour, just go to "Individual vehicle information" tab, then pick "repair info" for workshop documents or "training items" for the Self Study Programmes, then drill down the various menu levels 'til you find what you want, and download the pdfs.
- Manual Gearbox Oil
Window motor repair service
Hi Teddy, thanks for posting. It used to be a bit easier, as newly signed-up people could send private messages, but that seems to have gone with the recent forum software update. Now you have to make a number of posts before PM'ing becomes possible. I see you managed to track down my email address that lurks in my profile; well done. I'm probably going to become a forum sponsor in the very near future, which will allow me to advertise my services and contact details more obviously. 🙂
Look for a broken wire just outside cable entry of starter solenoid connector.
Licence plate lights not working
There's a strong possibility that the relevant wire has broken, in the bellows where the wiring enters the tailgate.
Damaged wiring on driver side door
All of the thinner wires are 0.5mm sq. cross sectional area or less. The largest pair are 1.5mm sq. I think. Complete removal of door is surprisingly easy to greatly improve access. Needs an assistant to help lifting off and refitting though. Having said all that, the wiring between window switch and window motor probably goes direct, within the main bit of the door loom, rather than going to the 28-way connector at A-pillar. What colours are the broken wires? Photo?
Fabia 2 bcm replacement
@26DIPP the BCM is somewhat involved with electric windows on a 2013 car, I think. I believe it has LIN bus connectivity with them, and may even be the LIN master controller, not sure. Pre-March 2010 mk2s didn't have that LIN connection, only between the two or four window motors themselves.
Fabia mk2 bts engine specs please?
All relevant ETKA parts diagrams can be found here by seeking out the pages with BTS in the titles: Car Parts Catalog - LLLParts How bad is the leak? Photos? How many miles has the engine done? It's a pretty grim job to remove the cam carrier and re-seal it (RTV sealant not a gasket), I think. Cams come away with it, which means you have to take timing chain off first, which is a big job with locking tools and removal of timing case cover. If DIYing it'll challenge you unless you are very well tooled up and experienced. If thinking of getting a garage involved, expect a hefty bill. Consider checking/replacing some of the ancillaries that might be resulting in higher crankcase pressure than designed, such as the PCV valve and oil separator, both mounted in the top of the timing cover. If either of those is definitely not working well, the leak might be reduced considerably by sorting those instead of taking the engine almost completely apart.
Mileage
@AGFalco^ makes me want one just like that. If circumstances change and you want to sell, please let me know. 😁
list of issues
From underside, unplug the big 4-way connector from the fan control module (hanging off bracket on nearside chassis leg). Link smaller contacts of loom connector to test (just) fan's low speed function. Link wider connections to test high speed.
2006 mk1 estate rear axle compatibility
Yes. Or reg number. Tomorrow though.
- 1.2 HTP 60hp emissions problems
Which oxygen sensor did the fault code indicate, and which did you change? Both are bank 1, there's bank 1 sensor 1 and bank 1 sensor 2? Top of cat or after? Do you have a record of that fault code somewhere? Have the spark plugs been looked at or changed since purchase? Does the car have a coolant temperature gauge?
list of issues
The radiator thermoswitches almost never fail on A/C cars, cos they're only carrying relay coil current of the fan control module's relays, not fan current, so I think that would be wasted cash. Check for broken wires near to its connector though, and test fan itself via this linking of loom connector:
Fabia 4 Start/Stop battery
See the 17 words I typed a few posts above here, which will answer your question, if you wish. 🙂
