Gaz
Everything posted by Gaz
  1. Mila won't charge properly unless she's plugged in G
  2. I think that's a voice you shouldn't be listening to 😁
  3. I know you're asking Nigel, but twelve years ago I spent $2114 (£1100) having the gearbox fixed on my Saab 9-5, only to write the car off six weeks later 😳 (Gearbox was a joy for the six weeks though). Replacement for the Saab was my first Skoda - every cloud.... Gaz
  4. Gaz replied to Pablo1085's topic in Hellos and Goodbyes
    Welcome Pablo Gaz
  5. If you're handy with a spanner and happy to do so, why not remove the matrix and see if you can get any flow going? I had some success with my Sister's Micra many years ago, with flushing back and forth, tapping and vibrating (chisel setting on a hammer drill - taking it easy as the core's not particularly robust) muck out: Gaz
  6. Hello and welcome Stuart Not mine, but you may well be interested in this - looks a good bit of kit: Gaz
  7. Hello Wb As my dear old Dad used to say 't'is a sad arse that can't rejoice' 😁 Gaz
  8. I generally leave a microfibre wrapped sponge full of warm water over the offending poo for a good while, to allow stuff to soften and some to float away. If it's on a level-ish area (e.g. bonnet or roof) I use an old silicone ring (from an old tupperware type lid) around it to help keep it as wet as possible while soaking. I've found a hand held garden sprayer useful for a localised jet of water on the area. I keep any 'wiping' to a bare minimum as the poo sediment will have grit in it.
  9. Horses for courses IMO. Not much to choose between them. Maybe show us the adverts? I'd suggest you inspect and drive both, then make your mind up from there. Should become apparent which you prefer. Gaz
  10. 1972 Austin 1300 Van Den Plas auto. Specifically, this one: Gaz
  11. Hello Beggi and welcome Very common suspects are dry solder joints in the door lock control module (in the door), or damaged wiring between the 'A' pillar and door. Although for a Passat, this proved useful for when I had a Mk1: https://www.taligentx.com/passat/maintenance/doorlockmechanism/ Gaz
  12. I don't think this is correct. See here: https://www.themotorombudsman.org/knowledge-base/what-are-a-consumers-legal-rights-when-buying-a-car 'If you are now outside of the first 30 days, the seller has one opportunity only to repair or replace the faulty car. You will not be able to ask for rejection at this stage. This does not apply to cars purchased before 1 October 2015. The Sale of Goods Act allows the seller to either repair or replace the car within a reasonable period of time without causing significant inconvenience. If you are complaining about a fault within the first six months of purchase, it is presumed this fault was there at the time of purchase. The seller will need to prove that this fault was not there at point of sale. If you are complaining about a fault outside of the first six months, you will need to prove that fault was there at point of sale. If the seller is unable to repair the fault because the same fault persists or a new inherent fault has developed, or the replacement car has an inherent fault, then you can ask for your money back or a price reduction (partial refund) if you wish to keep the car. Remember, for rejection outside of the first 30 days, the seller is entitled to deduct the mileage you have added onto the car.' And: https://www.autotrader.co.uk/content/advice/how-does-the-consumer-rights-act-protect-you-when-you-buy-a-car 'The Consumer Rights Act stipulates that dealers will only get one chance to repair or replace the product, so dealers can’t make multiple attempts to fix a problem unless otherwise agreed. If they fail to remedy the fault in one attempt or within a reasonable time period, you’ll be entitled to a full or partial refund. Alternatively, you can ask for another attempt at repairing/ replacing or for financial compensation. The law says, in almost every case, there can be no reductions from any refund given in the first six months. However, motor vehicles are the one exception, where the seller can make a β€˜reasonable’ reduction for the amount the car has been used.' Agreed, although it looks like @Whitie needs to allow the seller '..one opportunity only..' to repair or replace it first - 'without causing significant inconvenience'. I think it'd be sensible for Whitie to seek advice from Trading Standards/Consumer Direct at this point Gaz
  13. Gaz replied to JayRuss's topic in Hellos and Goodbyes
    Hello Jay (or Russ) My first Skoda was a Superb, although a 2005 Mk1, back in 2012. That's the car which brought me here. Gaz
  14. That's an Amundsen 1 unit - same as was in my 2015 vRS, so the SD card you're looking for will, I think, be 5EO 051 236. Gaz
  15. That's very impressive indeed πŸ‘ Over 35k miles, my Golf (EA888G3 230 with DQ250) averages about 34mpg. We saw 66mpg over a ten mile stint in Switzerland, but that was once, and then the same coming downhill out of the Dolomites into Italy. Neither to be seen again, and not a chance around my neck of the woods. Gaz
  16. Ooh, Dragon Green 😎 Welcome to our surgery Dr A Gaz
  17. Gaz replied to nsve's topic in Hellos and Goodbyes
    Hello and welcome nsve Gaz
  18. Me too - I thought people loved 5 series estates! Gaz
  19. Looking really good 😎 - alloys definitely suite it. Gaz
  20. No such thing when it comes to cambelts, as you've noted with your company vehicles. Welcome Pardraig Gaz
  21. The single-use hearse - you could be on to something… G
  22. Beachy Head West. Belle Tout (above the Pay Here sign), cliffs in the centre are Seaford Head, white buildings on the horizon are Brighton: Didn't stay long after this as a lovely pleasant moment, listening to skylarks got utterly ruined by Mr Very Important Obnoxious Tw@ (white shirt) who got out of his Maserati and starting pacing between my car and his, dictating business letters and emails to someone who couldn't hear him clearly (Unfortunately I could) πŸ™„πŸ€¬ Gaz
  23. Beachy Head looking mostly landward. Belle Tout, Birling Gap, cliffs at Seaford Head, white buildings just visible on the far horizon are Brighton, village in the middle is East Dean, with Firle Beacon behind. Building towards the right is the Beachy Head Pub: Gaz
