Everything posted by Gaz
Long time lurker, now a hello
Greetings Jez Luckily, my mind's not in the gutter, and I see nothing wrong with having apertures looked after and warmed 😇 Gaz
Hello from Yorkshire
Hello F4y I really like Phoenix Orange 😎 Gaz
Any one from New Zealand here?
Slightly better odds for outrunning them in a vRS 👍😇 G
- Massive coolant leak into passenger floor carpet
Inside wear on one front tyre
Hello Stuart So having the tracking corrected is going to increase tyre wear?? 🙄 I think you need to go to a different garage (without knowing any mitigating factors that validate this opinion). IMO four wheel tracking (Hunter perhaps) is not a waste of money, and you'll likely get a better report and indication of what's going on. It's odd that only one tyre is affected. Could it be this tyre is a left over from when tracking was previously out, and has since been corrected? Gaz
Octavia VRS Wagon in Primer
Hello C_B I had my 2015 220TSI remapped to north of 300bhp (Probably around the 310 mark in reality) on a Revo stage one. It was a fair bit more sprightly I found it quite aggressive mid range, but that was just something to get used to, and more of a quirk than an issue. Overall I enjoyed the maps outcome 👍 (and I secretly hoped mine was one of the cars the ST owners didn't like ). Gaz
E-bike
My e-bike's charger has just died. Checked the fuse, which is okay and the extent of my skill level Can't really complain as it's been used probably three times a week over the last eight years. I don't suppose we've got an e-bike charger specialist on the forum (you never know!). Gaz Edit: Well would you Adam and Eve it. As it was dead I decided to perform an autopsy (undid four screws and pulled the two casing sides apart). Saw nothing exciting, exploded or burned. Put it back together, not before losing one screw down the kitchen sink, plugged it in, and lo' and behold it came on and charged the battery as per normal 😁 Maybe that fact I'd found a cheaper (E6002) charger online gave it a reality check as to its future and being replaced by a younger model - threats and jealousy having the desired effect?
What's your Vehicle Score?
Approved Used SE First Edition : Problems
My first Skoda was a Mk1 Superb V6TDI. It was advertised as having a FSSH, but the paper trail showed a missing cam belts change. I nearly rejected it, but they took the car back and had the belts done. I'm very glad I didn't follow the rejection through because it turned out to be a brilliant car 😎 I wouldn't agree to the rear vent surround if I was the garage - just sayin'. It's not part of the concerns you raised. Gaz
That'll do, won't it? Provided that's the outcome, and you've got it in writing. Bloody palaver, but reasonable if it makes things all good. Gaz
Check the brakes using the 'Elsa Pro tool' (Item 87) - Proper pro tool that is then! Shoddy and incompetent. It'll be interesting to hear their explanations. 'It was alright when I looked, honest guv!' 🙄 If it's all fixed and tickety boo, then it might be you'll be minded to accept the car. I would, if it was the car I wanted, but otherwise I'd walk away. See how they respond and if it doesn't sit well, perhaps have a chat with Consumer Direct/Trading Standards. Very poor service 👎 Gaz
Vehicles wot I have owned
Oh my goodness yes, 'sheer pace'. Place in my heart was my (allegedly stock) Saab 9-5 HOT Aero. I had no real idea until owning one, but I have an endearing memory of taking my Dad out in it and showing him the midrange performance. A simply outstanding treasure in my memory 😎 Talking of memory: (in order) 1978 Honda Camino 50cc (Reg: THC 1S - if only I knew!), 1972 Austin 1300 Van Den Plas, 1973 Renault 16TL, 1976 Ford Cortina Mk3 XL, 1979 FIAT 132 2.0, 1981 FIAT 132 2.0, 1982 Opel Ascona 1.6, 1981 FIAT 132 2.0, 1982 FIAT 132 2.0, 1984 Nissan Bluebird 2.0SGL, 1990 Honda Civic 1.4, 1995 Honda Accord 2.0, 1999 VW Passat Estate 1.9TDI, 1989 Mk2 Golf GTI 16v, 1992 Honda CRX Del Sol 1.6 (UK), 2001 Saab 9-5 2.3 HOT Aero, Honda CRX Del Sol 1.5 (JDM - sold on Brisky), 2005 Skoda Superb 2.5V6TDI, 2015 Skoda vRS TSI Estate, 2018 VW Golf GTI (current car). There'll be others I've momentarily forgotten Gaz
EV real world range and cost to charge
My modest solar array hasn't been installed for a year yet, so I'm still learning. At this point in the year, my battery and immersion are at 100% by 10:30am. After that I'm exporting 3.4-3.6kwh if sunny/bright (1.4 on a dull day). I've scope to increase the array and/or my battery. I've of course got the RoI to factor in. But as we consider coming down to one car (from two), it's getting to a point where I'm thinking it's daft not to come down to one ICE car (i.e. my GTI), but then also have a cheap EV for the local stuff, as our first foray into the world of EV. I need to look into whether it's better to export the leccy, or put it into an EV. I'm still habitually checking the gas boiler because it's not coming on. It's fine, just the immersion tank doesn't need it, so there's a gas saving too. Gaz
Welcome Henry Our Rob might be from your neck of the woods: Is the Aisin AT more economical than a DSG? Like for like I'd be surprised (not the first time!), but between a 1.4 and a 2.0 I could understand it, although that's comparing pears and apples. Sadly, I agree with Rooted that there seems to be a growing number of reports about problems with the DQ381 and its associated bits. Gaz
Eight years ago now, my then vRS had to have new brake discs at under 18k miles. It happens, frustrating as that may be. You're still in a position where you should end up with a very good car, that you'll be very happy with 👍 Gaz
I think you're right in your considerations. Perhaps give them a chance to remedy the issues, but certainly make your dissatisfaction known. You won't be the first, nor last, to put faith in the Approved used flag of 'trust us-it's great'. Surely not! I can see brake shudder not showing itself on a short test drive. Hopefully it'll be acknowledged, and remedial work undertaken. I personally wouldn't stand any messing around though - keep rejection in mind. Gaz
Hi from Lincolnshire..
Hello and welcome Chris Oh dear, sorry to hear about the reaction. Might I suggest E45 topically, regular beer intake and a hot toddy - should get you over it in no time! Gaz
Greetings from the South of France
Hello Milo I had a 1999 110TDI VW Passat estate, so very similar, which I passed on to a friend. I wish I could go back to 2011, give myself a clip around the ear, tell my younger(ish) self to not be a dimwit and to hang on to what was a bloody good car! 🙄 My Son did a stint with PGL, here in the UK. It didn't last very long. Being enthusiastic, and then sustaining it, wasn't his strongest trait. C'est la vie. Gaz
Hello from sunny Yorkshire
Morning Chef Welcome to the Brisky kitchen. Gaz
Photography Thread
Hey
Greetings Cyko, welcome to the village Gaz
Hello there
Hello and welcome BelegEthel Gaz
- Hello
- Hey!
