Everything posted by skomaz
Windows 11
If they don't there'll be a lot of people switching to Linux or other non windows OS...
VW Group vehicles: Auto Hold. Do the rear brakes lights come on?
As posted elsewhere. 2018 Kodiaq and brake lights on with autohold but going to double check other situations
- I hope you are all being sensible about THE PETROL SHORTAGE!!
Code out brake lights on autohold?
Hmm. Will have to double check again. Given the convenience of the autohold it would be nice to code out if poss, say after a few seconds of being stationary but it seems it's not possible
Indeed... But on the kodiaq its electronic and seems to retain the brake lights on if the autohold engaged when you stopped...
As above does anyone know if the brake lights staying on when the autohold is on can be coded out? I've noticed that the brake lights stay on when stopped and autohold is active, even if I don't have the brake pedal pressed. Its one of my pet hates and is blinding when sat behind others that do it so don't really want to inflict it on the people behind me myself...
Windows 11
Whilst I now use 10 regularly I still reckon XP was the most logical and easy to use... I just hope 11 isn't another 8... Remember that? It was total ****e (and still is on the one laptop we have that still has it on...
Motorway 'furniture' - what is this?
Pretty certain it's a stopped vehicle detection radar... Probably at about 500m intervals??
London Colour HID upgrade kit Install guide.
If you want a set I've took a set out of our 2007 Octavia 4x4 a couple of months back. They were working fine when I removed them so would be happy to pass them on for a few quid and postage as I won't be fitting them to the Kodiaq (think I even have some spare burners somewhere). I think these were the ones: XENON HID CONVERSION KIT H1 H3 H7 H8 H9 H11 HB3 9005 HB4 9006 | eBay
PR codes - what is "1G8 Breakdown Kit"?
Thanks for the info re codes - mines a 2018 with no service book (just an online record) so that may explain why I can't find the sticker in the boot and no book with the sticker in like our old Octavia had. I've tried a few online links to check things but no joy as yet... I guess I'll keep trying!
Quick question - where di you find the PR codes? I can't seem to find my sticker with them on that usually resides in the boot etc.
Disappointed in off road performance
I would suggest you check with them what they will do as part of the Haldex 'service'. If it is just an oil change, as per the Skoda recommendation, then I'd go elsewhere, or take it to a VAG, or even a Volvo Specialist who knows what they are doing. It really needs the pump removing, the filter cleaning and the oil changing as well as, possibly, a pump relearn. (see the link from Teir above). We had an Octavia 4x4 for 14 years, made sure all of the above was carried out regularly and never had a Haldex problem but, as you and others have found out, they can fail for lack of being looked after properly.
As the Dukes would say - Sell, sell, sell.
Had a look on Autotrader last night for a laugh... we picked up a low mileage second hand Kodiaq 4x4 in May this year and for something similar now your looking at £6k more than we paid 4 months ago - truly mad!
Diesel pump keeps clicking when fuelling at petrol station
Try angling the nozzle a bit as well. We found with our bold Octavia 4x4 that we occasionally had the same problem as you but usually managed to find an angle that worked. Also the breather as you called it is just a water drain tube that runs to the wheelarch.
Remote fob not working after battery change
In my experience most 'new' CR batteries push out about 3.4v and kessy fobs stop working as kessy fobs at around 3v.
I need Bolero Update :-)
Just out of interest and for reference, how often are updates issued? We updated our 2018 Kodiaq bolero a few months ago courtesy of this thread but might there be another update in the future?
- Kodiaq Style MY21 (New Zealand) - no personalisation option?
WASHER FLUID MOTOR
It may be that the valve element (effectively a disc with a silicon seal arrangement, has also moved and 'rotated' within the drum of the valve preventing you getting it pushed back together. may be worth pulling it apart completely and checking / trying again.
ACCESSING WASHER PUMP
turn the steering full to the right, then you should be able to access the inner wheel arch and it's screws /fixings sufficiently to remove enough and fold the liner back/ up a bit to gain access to the washer bottle and pump. The fixings shoudl all be easy to work out and identify.
WASHER FLUID MOTOR
yes - that's the diverter valve (the motor spins one way for front and the other for back screen and the valve blocks the pipe to the relevant other screen). In theory you should be able to pop that back in but it might not last... so a new pump and motor might be on the cards
Yes I have seen he deals and I do get that it works for certain people.., you for example if your dar has problems. Its just not for me as I run my cars differently to most I guess...
OK - I reckon I am in for another Kodiaq - Likely Sportline - but diesel again or a switch to petrol?
Not quite true... some of us live on hills in higher areas (eg the Pennines in my case) and often get bad weather / snow / slush and torrential rain - so whilst I very rarely venture off-tarmac, 4x4, combined with all season or winter tyres, is effectively a 'must' for us to be able to get out and about during winter. Having drive FWD and 4x4's regularly the 4x4 also brings with it a huge amount of additional stability in bad weather.
Having test-drive both DSG and manual, before buying a 1.4 manual, I thought the throttle control seemed much easier on the manual, as did my wife... You could always try the 'linear' throttle response change in VCDS to see if that helps??
Fitting A 12V Power Socket
Or buy one of these... https://www.amazon.co.uk/s?k=12v+extension+lead&crid=2FIMR47OPKRCE&ref=nb_sb_ss_ts-doa-p_1_2
