VCDS Adaptations. How do I ..........
Not possible through coding on mk2 it should be on mk3 though :-)
Great.. thanks! But I thought my 2013 Yeti is MK1..? ^_^
  • Replies 255
  • Views 244.4k
  • I picked up my Yeti this week after a long delivery delay and while waiting I have been amusing mself by pulling a lot of VCDS info into one document for my own use. Well the Yeti came Wednesday and t
  • Needle sweep - absolutely no practical use at all but still makes me smile!
  • How do I enable 'staging'? (needle sweep when ignition is turned on, needs the latest white MFD on newer cars) go to 17- Instruments and click on "Adaptation - 10" On the drop down list find "stagin
Sorry, didn't see you had a yeti - same outcome though - without manually wiring then up.
My Octy Mk2 FL has xenons and the DRLs stay on with the dipped beam. I've set them to dim to 30% though so I don't look like a ****. Want me to post up pics/VCDS screenshots?
Are we talking LED or halogen DRL's
Mk2 Octavia vRS so I presume they're LEDs?
VRS LED DRL's dim when the headlights come on a std, its part of their function.
In my experience (if i'm talking about the same as you) is that you can code the LED brightness (in DRL function not side light) to any number you like between 1 -124, however there will actually only be 2 brightness outputs.   35 and above will give you full brightness and below will dim them.
The coding for that is high up in the byte numbers (can't remember exactly) somewhere like byte 22-28.
However if you can show us something different I stand to be corrected (or updated?)
By the way, my headlights are not xenons.. they are halogens.. my DRL I've changed them to LEDs. ^_^  and I do not have Maxidot.
Edited by racncarboy
Hi there, does any one know the coding for the passenger and driver side exterior "Ambient Mirror Illumination" coding? thanks for the help..!  :notme:
FL Yeti LED numberplate lights:
Byte17 - tick Bit7
Byte23 - untick Bit6
The Yeti FL now uses W5W numberplate light bulbs, to remove the light unit slide it to the left and manoeuvre it out of the recess.
They need side emitting LED’s, I fitted these
DO NOT be tempted by the 6 LED W5W’s as they are slightly too long for the holders that VAG use for all of their W5W bulbs (footwell, boot, door, mirror etc lights)
andyvee, on 29 December 2013 - 19:14, said:
Post
Enabling both rear fog lights
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
Change the 2 channels listed below - scroll to just over halfway down the long list of adaptation channels to find them. Do them one after the other, and do not come out of the adaptations until you have finished. If you do, you will have to close the controller and go back in and enter the security access code again.
Will this work with the FL Yeti?
Doubt it, as this is for MQB platform cars.
Sent from my HTC One_M8 using Tapatalk
These LED bulbs DO work on FL yet as this is what Gizmo68 has  & has fitted.
I have accidentally bought too many & have some for sale- in the for sale section.
The question was about the coding of the BCM wasn't it? Or have I misunderstood?
  • 5 weeks later...
Can I remap my '13 Rapid 1.6 TDI or change the behaviour of DSG with VCDS? If not what do I need to do so?
I'm sure a DSG map would help
No, you would need separate remaps
How do I silence the seatbelt(s) warning bong? (CANBUS cars with longcoding)
go to 09 - Cent. Elect and click on “Coding - 07”
Apologies if this is a noob query - I've only had my vcds for a few days. I've managed to make all the changes I was after to My Mk3 vRS wagon (boot closing via the key/button with no beeps, disabling mirror dip on reverse, hide AM, etc). But I haven't been able to sort out getting rid of the seatbelt warning bongs. I'm not able to find anything relating to seatbelt warning bongs in 09 - Cent. Elect -> Coding - 07. Any help appreciated! Cheers
It's an adaptation channel I think, and more than likely in Instruments
hi guys, is there any option how to enable both fog lights on Octavia II FL (MY2010) with VCDS? Or it´s possible only with VAS?
Anyone know how I can disable the Sound Generator on the Octy Mk iii?
Found a German entry but it refers to STG A9 which I can't find. Help would be appreciated
Controller A9, go in to adaptations. Fairly obvious from there onwards as there is only one adaptation channel!
Thanks Andyvee for reply but don't have a controller A9 on my 2013 vRS. It's chassis decodes to NE on VCDS but searched high and low and no A9.
Anyone with an NE chassis type coding on VCDS found out how to disable Sound Generator via VCDS?
Many thanks
In which case you don't have a sound generator. Take a full scan with VCDS and PM it to me and I will confirm 100%
Hi guys
Does anyone know if it is possible to enable a headlight warning tone when the headlight switch is left in the on position and the engine swtitched off on a Mk 2 Octavia vRS?
It's fine having them switched off automatically but I keep ending up setting off with them switched on again when it is broad daylight. :doh:
Thanks in advance...
1  how do I activate the rear sidelights to work with the drl's at the front
2  deactivate the seat belt beeps
3  deactivate the Bluetooth bong when trying to connect
all on a '13 yeti mk 1
new to this flying without wires etc  ;-D
