VCDS Adaptations. How do I ..........
3 hours ago, 2stroke said:
It is not possible via VCDS to do that.
I have done this on my previous car - Yeti 1.8tsi preFL. And it worked, I had found the coding here in briskoda and I did it with VCDS.
  • Replies 255
  • Views 244.5k
  • I picked up my Yeti this week after a long delivery delay and while waiting I have been amusing mself by pulling a lot of VCDS info into one document for my own use. Well the Yeti came Wednesday and t
  • Needle sweep - absolutely no practical use at all but still makes me smile!
  • How do I enable 'staging'? (needle sweep when ignition is turned on, needs the latest white MFD on newer cars) go to 17- Instruments and click on "Adaptation - 10" On the drop down list find "stagin
2 hours ago, PetrolDave said:
AFAIK only on some Audi RS models is ESP off an option - on the Octavia 3 the options are ESP On & ESP Sport, usually by changing the value in byte 29 of the ABS coding
Controller 03 - ABS
07 - Coding
Byte 29
02 – Stock (for non-vRS) ESC ON / ASR OFF
09 – Stock (for vRS) ESC ON / ASR OFF / ESC SPORT
Thank you I will try this way. Here is video in youtube that shows that this is possible. In our Skoda club there is one the same as mine, bought used from Swiss that is like this - first is ESP sport mode, than with long holding the button is ESP off mode. But the owner don't know how is this done, he bought the car like this...
  • 2 years later...
Good evening all my question is related to a 65 plate 2013 Skoda Supurb. Is there coding that could be tweaked to enable a runlock essentaily leaving the car running but able to lock the doors from outside. My absolute preference would be to be able to remove the ignition key without linking across the switch electrically
  • 4 weeks later...
Amazing amount of information and very useful, I have a Skoda Superb Mk2 2012 Combi. Whilst not recomended in the UK Before I add a module electrically I wondered do you know if there is an adaptation to lock the door with with engine running
  • 1 year later...
i have a fabia 1.6tdi 105hp se , the adaptation of new turbo charger actuator isnt in the list in basic settings on vcds do i have to enter coding to make it appear somehow ? there is an option to test charge air pressure actuator but not adapt it ??
thanks
dave .
Hello,
Recently got a Superb Mk 2 (2015) SE Business and was wondering if it was possible with VCDS to make both the memory displays on the maxidot into "Total Trip Memory"s? Instead of memory 1 being the Single Trip Memory. I'd like to be able to have one as a kind of "all time" counter and one as a "few days but more than one journey" counter, ideally.
