Parking Distance Control + Stereo
Hi, gang,
Recently, my stereo has carried on playing at normal volume when I engage reverse with PDC.  It used to cut out so that you could hear the beeps of the PDC for as long as the car was in reverse.
I don't think I've altered anything and I can't find a clue to the solution, either on Columbus or the maxidot.  I haven't been near it with VCDS for nearly a year.
Any clues?
Cheers,
Ned.
liquid spilled in the switch by the gear knob, or switch failed in the on position.
Pressing it cancels the visual and audio indications.
I recall there being a setting on the Columbus. Is that box still ticked? Can't quite remember where it is, so if you can't find it, I'll pop out and have a look.
Found the setting in Tone-Volume Settings-PDC volume control
Sent from my iPad using Tapatalk HD
Mine does that every now & then seemingly at random (which it is).
It does reset it self. Usually.
Usually.
Mine always leaves stereo/phone call volume on when reversing, so I assume it must be adjustable as stated above.
Mine always goes silent when either the front or back sensors are active.
There are 4 settings that refer to the level of volume dipping when the sensors are activated.
I think whether you have the option on the Columbus depends on the parking sensor module you have.  When I upgraded my parking sensor module to give optical parking display, the setting appeared in the Columbus.
  • 4 months later...
Oftopic
My car is Superb 3T 2010 2.0TDi DSG
Hi ppl does anyone know why this screen whit a long beep comes up???but only when is cold outside or when it rains..The vag test showd no PDC Errors!
Tnx
Posted Image
I had a similar message and beep on mine when the wiring to my reverse switch on my Octavia had a loose connection. My reverse lights were also intermittent at the time. Luckily it was very near the switch itself, so easily found, and that fixed the issue.
