Reliability/build quality issues?
I'd look at the accessories belt.
  • Replies 288
  • Views 43.4k
  • When I got a similar service from a dealer a couple of years (denying there was a problem even when I demonstrated it to them, no fault because "the computer couldn't find one", waiting 4 weeks for a
  • So... A revelation. The cars being returned and a new one is being sourced. They're not entirely sure what's wrong with it. And they've admitted it too. There's been errors in the airbag and sea
  • Well after about 8 weeks of rattling it's magically stopped so i'm guessing whatever it was has fallen off
It's only when the high power draw message is up I think.
Although it was trying to regenerate at the same time.
Didn't do it on the way back without either. And only when the engines winding down, and when held on the 2500rpm soft limiter, the exhaust feels like a misfire, but that I'm leaning towards the soft limiter cutting fuel.
Car goes in today. Again.
The noise has changed, and literally sounds like something is about to fall off!
Luckily it's doing barely any miles as I'm on holiday at the moment.
Can anyone film their tdi to see if it does the same?
Mechanic thought it was the hpfp clicking but wasn't sure on the whine, it's coming from air box side of engine and he thinks it's the turbo/vnt but couldn't be sure.
  • 4 weeks later...
When purchasing a new skoda or whatever car you as the consumer are not bound to accept repairs. They have an obligation to offer that as it is probably the cheaper option but they are also liable to offer a replacement or refund. Check the legalisation. I know as i am in this process whereby SUK are doing everything in their power to deny my cars problems and avoid rejection. When you are offered a repair (i mean a warranty repair) ensure you receive ample compensation otherwise reject the car outright and request replacement or refund.
This is my second car, replacing the first that had communication errors causing the start stop system to fail. That was apparently fixed after by the dealer with a software update.
This car has the same issues, but manifesting in a different way.
Finally got around to scanning the car.. And it's all a bit odd.
Some of the modules are now unreachable, when they were before, and the error (same as before they fixed it) is now coming up as "unknown".
Monday,22,December,2014,21:31:08:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBBJ7NEXE0217145   License Plate:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 11190012030501090000
   Shop #: WSC 73430 031 00123
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021CP_SE37.rod
   VCID: 79F90B6FF82C89D6D3D-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 60984000000B9E
   Coding: 1A078A91242109730078060441C8245851249000608224F000630070C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 4B9581A7E230CB46311-801E
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 01110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 285F1E2B5306C05EFC3-807D
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831410103497
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000.rod
   VCID: 387FCE6B83A650DE6C3-806D
Address 15: Airbags (J234)       Labels: Redir Fail!
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P7R3KE%
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00123
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7F0DE577E608A7E6ED9-802A
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 604 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000C54B0AF0M
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 504 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U00000013090AF04
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 704 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R41106103000000F
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 704 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526RE9086103000000+
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 800 603 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556VC7861E03000000F
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 17041404400276
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB.rod
   VCID: 75E1075FD434EDB6B75-8020
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 30081410801508
   Coding: 030100040F087300EF000248080F00010001050000000000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_GatewConti 010015
   ROD: N/A
   VCID: 3F8DA577A68867E6AD9-806A
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0266120414
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 0377833103
No ASAM data for: "EV_GatewConti" (SK37)
1 Fault Found:
8531970 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 16477 km
                    Date: 2014.12.21
                    Time: 04:10:01
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000100173670
   Coding: 001000208001040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 428BAC83D57A0A0EC27-8017
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000002382026
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8102
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB.rod
   VCID: 4189A38FD07C1116DBD-8014
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000100258434
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000002372213
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0435
   Serial number: S7E01304143163
   Coding: 03730100FF0000001111120100A800002F0000860100010002
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 2149030F303C3116BBD-8074
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9PK6013QT
End   ---------------------------------------------------------------------
What does that suggest? Poor design and an inability to solve the problems they create.
How quickly did you reject the car after purchase and the fault manifesting?
The car lasted a whole two months, with several major failures.  It's mostly documented in this thread.
Car bought last December, only put 2k miles on it (I do 3-400 a week!) and I was in several loan cars until it was replaced in May.
Fault was noticed immediately and reported to the dealer, and SUK, who did nothing until 6months later, when they investigated and blamed it on the camera I have fitted.
I persevered and they took it in last week, replacing the canbus gateway.
I pointed out while leaving the dealership on Saturday morning, that the status message of high power draw was still displayed, to which the service manager got quite shirty and rude to me and said "they all do that" and tried to claim it was only broken if a light came on, and it had done this while they had it, but couldn't tell me the light nor the error message.
I've got dual complaints going with SUK and VWFS, and I am actively pursuing it.
I've now sent my OWN logs of the vehicle directly to the both of them, bypassing the dealer entirely.
I've also noticed this thread has had over 180 replies, and nearly 15,000 views.  Just to take note if anyone from Skoda, or Vindis Skoda of Cambridge is reading.
Vindis have got annoyed with me in the past over reporting their shortcomings and asked me to "reconsider" what I have written, even though completely factual, they seem to disagree with events!
Protecting their interests most likely!
I smypathise with what's happening. I took delivery of brand new octavia September this year. Within a week I noticed external paint issues. To cut a long story short the car will need to be partly dismantled to effect paint repairs. SUK claim the fault is insufficient to warrant rejection, thus i doubt they understand the sale of goods act. Poor show for the brand. The dealer who initially suggested replacement vehicle now tows the corporate line and like parrot fashion can only utter 'warranty repair'.
Last Skoda i purchase. Very poor product indeed though I doubt any other manufacturers are better but I won't entertain Skoda after this one.
Instruments and central electronics can't be reached? I think they've made a right mess of replacing the CAN Gateway
I thought the same.
I thought my VCDS was out of date, then I realised it worked before!
However SUK have forwarded it onto technical. I'll get a reply after Christmas.
The part numbers of the can gateway are different than they were, which I expected.
However the old ones description line called it a "high" and this one calls it a "mid". Odd.
12.12.0 is very out of date, might be worth updating to v14.10.0
Sent from my HTC One_M8 using Tapatalk
Yeah I know, but I can't. I got ripped off with what I thought was a genuine used lead and it was a fake.
Should be getting a new genuine one soon, funds depending.
Problem is that the version you are using was useless a year ago as it didn't have the dataset for the newer controllers back then, I wouldn't trust anything it is telling you on a car that has been manufactured recently.
Find someone with a genuine cable running 14.10.0 and throw the cheap Chinese fake away :)
Skoda flatly won't accept the diagnostic information, as it isn't from a dealer...
Oh joy. Another fight to get my bloody car fixed.
Did you get a genuine cable?
No, not yet. That's unfortunately waiting until February.
It's a long wait for a new toy.
Reading all of the posts here and others concludes to me that these are 'bad' cars. Maybe the rest of the range is poor to but I will never experience this.
All new car models tend to suffer issues but I am genuinely suprised how many issues this site discusses. From electronic issues, knocking noises, poor paint, terrible handling, inconsistent mpgs the list goes on and on. I find it hard to understand how skoda achieves customer loyalty and satisfaction based on what i read from consumers.
It's easy to see the negatives and I would rather not but I was a new skoda customer last year ordered and received my octavia estate. I soon discovered it's faults thus the bumper, bonnet and rear bumper will all need removing in order for a 3rd party paint company to sort out what the factory paint robots and subsequent QA could not do right in the first place. Add this to the centre airvent being replaced as the trim was bent and other pieces of trim that are clearly stuck on with sellotape and the occasional windscreen creak!
Not just an isolated case either. The new vRS loan car I used a few days was not up to scratch either, it appeared to be falling apart from the inside out and for a car of over £20000 it was a well specced as a lada from the 1980s. I don't see where the good value was
Sorry you are having a negative experience but in the interest of balance....on my 4th Skoda. No paint issues. No squeaks. No booming noise from the tailgate. No build quality issues. No DSG problems. Some minor issues but only what is to be expected over 250K odd miles.
Forums tend to accentuate the negatives - its in the nature of the beast. But I think a lot of people may post their issues here as this is normally a helpful and knowledgeable community that can help with problem resolution. It doesn't mean every Skoda is falling to pieces.and that they are all "bad cars".
I'll also add to the positives, as my Octy 3 has never put a beat wrong. Never had any work needing to be done to it except a normal service.
No booming noise, no clonking noise, no blistering paint, no electrical gremlins.
OK so Im not a big fan of the suspension setup, but I believe the cars being built now have a different suspension setup? Multi Link instead of Torsion Beam?
They aren't that bad a cars.
Also, out of all the problems being mentioned, the only regular one that seems to be a major problem is the booming noise.
True but I never wrote in terms of it being a sales pitch for skoda. I have owned a variety of vehicles and motorbikes from Renaults, mazdas, ford's, vauxhalls and porsche. All with their own good and bad points. Some of these have been brand new purchases. The skoda is the first car I have owned to be requiring dismantling within its first 6 months from new to correct problems. No other brand has been as poor as this in my experience.
I'm not personally sorry about the skoda issues as it was purchased as a forgettable family car with zero kudos. The brief for it was hassle free motoring which has so far proven the exact opposite.
I was intending to give the benefit of the doubt but alas no
I'll stick my hand up for 'good car' too.  Yes, there are some bits of my vRS which annoy me, and some which I wish were better quality - but I've got so much more kit and car for my money than I would with pretty much any other marque.  I've not had any problems which weren't user error, and it has coped superbly with absolutely everything that has been chucked at it (and in it) so far.
I've experienced both sides with the O3 - the first one was an absolute dog and spent over 6 weeks with the dealer in 12 months for issues to be rectified. Wiring short behind the dash requiring full dash removal. Numerous bits of trim falling off. Puddle lights staying on for hours. Faulty fuel pump. Bulb warnings for bulbs that are working. Faulty Columbus. Stop Start system errors. TPMS regularly telling me all 4 tyres were flat. Filler flap that popped open every time you closed the boot and a few more issues.
In the end I gave up and traded it in for another - which has been (so far) perfect in the first 2 months and 3000 miles.
I feel sorry for whoever has ended up with my first one!
