Actual Adblue usage
I suppose cutting the bottom off does mean there is more risk of spillage though, even if using a funnel?
What would be good would be like an extension hose so that you could fill from outside the boot. I'm pretty careful but that would be better.
I'm coming up to 6k. miles so expecting the warning light any day now. Do fairly lowish miles now so refilling the bottle will do fine for me.
  • Replies 147
  • Views 41.1k
  • Like Jimrod I would like to opt for the 1.4 petrol. It is a pity that it is only available with the L and K which is a bit expensive and not to everyone's taste interior-wise. As I said in another thr
  • Only about 7K, so I guess, from the figures quoted above, I would only have the faff once every 9 months or so. A diesel probably not the best choice for the mileage I do, but I like the way they dri
  • Not quite, if you ignore all the warnings that you are running low then once the adblue runs out the car will fail to start until you fill up with adblue again.   I also asked at a local garage if t
I have looked through the interweb and adblue seems to be around £8.50 per 1.5L,
is this to make up for the current low diesel prices?
Nope... you need to look harder!
Once you have the bottle to fit the Yeti’s filler buy the actual adblue elsewhere.
I have just found 10l Green Chem adblue *with spout* £15.99 free postage Amazon
Apparently the special funnel is priced around £50
Edited by gumdrop
My 2016 Yeti is back at the dealership for the second time in its first 800 miles due the AdBlue system going crazy! It keeps dropping the range from 4000miles to 650 and saying 'no restart', ruined what was a great experience with the 2.0tdi 150ps SE Business model, not sure i want the car back now!
That's expensive. There is no special funnel, I'll be the same one all the 10L comes with.
Draper Expert 23193 Adblue Refractometer Kit
This adblue is getting more expensive!
The special funnel is for Peugot
Why would you need a refractometer?
Also all adblue fillers are the same. The greenchem one only fits the 4L container which is the price you mentioned
It does say; Precision refractometer suitable for measuring Urea concentration in Adblue® diesel exhaust fluid and will also measure anti-freeze strength.
So does adblue vary? as someone said one particular brand gave less miles per litre than other brands.
The 1500 mile warning came on at about 5100 miles, it’s the 2.0 and has been averaging about 49-50 MPG. My son gets a good discount at Halfords nearly 50% off the list price of their 4 L Adblue kit. It comes with the correct nozzle and it unscrews so you could top the bottle up without cutting it.
This link will download a PDF from the "AdBlue4you" website that contains some really interesting and informative information about AdBlue use.
Useful info. there Urrell.
One minor technical error though in saying that Euro 6 engines need SCR with Adblue.
Yes, would have been better if it said that most Euro 6 engines will need it to meet the Euro 6 standard.
Yes I like their wording -
the SCR system and AdBlue will become vital to meet the Euro 6 standards
Ford have managed to get their cars to Euro 6 without Adblue.
Edited by leaky5
As well as Skoda of course with some of their engines.
One would hope that all manufacturers would over time, come up with better technical solutions than keep adding ever more complex "bodges" to their engines, fuel and exhaust systems to meet the regulations.
Not easy I know, and will probably be overtaken by the emerging alternative technologies at some point once the costs have come down to acceptable levels for the general buying public.
It was me who mentioned lower range on car plan.
You don't need a refractometer.  Just put it in and forget about it until the next alert.  You also don't have to panic and fill it as soon as you get the warning.  It's only sub 600 miles you need to really think about it, and as soon as that hits zero it won't restart until the tank is completely refilled.
I've got the 2.0 110PS and at nearly 6k. miles the warning light hasn't come on yet. As per other posts I've had a look in the MFD but mine doesn't have the Adblue box to tick for the remaining mileage like some do. Would be useful/nice to know the remaining mileage rather than just the warning light.
My wife is using the Yeti on Thursday so I've warned her the light might come on but don't worry!
I'll get that kit in readiness - almost looking forward to the first fill now! Have you used the kit yet and if so was the nozzle a good, leak free fit?
The kit was easy to use, the fill point is down in a lttle section of the boot on its own. The nozzle does not open until inserted and once removed I only notice a tiny amount of Adblue right down near the base of the tank tube and as there is a very tight rubber cap up in the boot floor I did not worry about this.
Thanks leaky, that's good to know.
Can you add some ad blue but not fill the tank when it is convenient rather than when forced to? What happens if the tank isn't completely filled?
I only added 4 L to mine, the warning has gone off and I have another 4 L ready for next time it happens.
I suspect topping up before the warning would cause no problems.
But after that (from the manual)
""Checking the level, The AdBlue® level is automatically monitored.
With too little AdBlue® in the tank the distance that can be driven with the remaining
AdBlue® amount is shown in the instrument cluster display.
AdBlue level too low.
At least 4.5 litres of AdBlue® should be replenished, otherwise, after covering
the displayed distance no engine start is possible.""
I was thinking about doing that myself. But I guess it will probably be better to wait and get the whole 4 litres in.
As I said above, it's a pity mine doesn't have the mileage counting down in the MFD like some do. A mini display like the fuel gauge would be good.
Whilst the warning (like the screen wash warning) does the job, if that for the Adblue was faulty it could leave you stranded. A gauge/display would give some comfort but for some reason Skoda have dropped this.
I'm over 6k. miles now and still no warning!
Probably over thinking this! :D
Edited by VAGCF
What was the build date of yours?
I'd have to do some more investigation to find out exactly when (no date on B pillar sticker) it was built but my car came from stock already in the country and was PDI'd on 21 July 2015 so am assuming built around May/June?
