Technical Bulletin about parasitic current draw measurement
Breezy_Pete
Recommended Posts
Thanks for that, document now safely saved for future use, this is still a subject causing me issues with daughter's late 2009 Ibiza SC, though now that I've found "mouse attack" under the bonnet (chewing foam blanking pieces, no doubt for nest building), I've been diverted from my "is it or is it not going to discharge its battery" - so far, while being instrumented, it has not suffered from higher than normal parasitic current draw, or discharged its battery!! Though CTEK battery charger/tester now says "battery not good" when cranking with a fully charged battery!
Edited by rum4mo
  • Like 1
Link to comment
Share on other sites
I tried the first bit of this test (overall current draw from battery) on my Polo earlier, and initially made a bit of a schoolboy error.
Before locking the car, it was taking about 100mA, and I thought "that's only gonna go down as things go to sleep", so put the meter probes and dial in the 200mA-range position  to try to get a nice accurate reading. Used some long leads so I could still see the meter with everything including bonnet shut.
Guess what happened to the meter fuse when I flicked the remote button to lock up and set the alarm?  :notme:
Yep, the doorlocks all take a little surge as they do their thing, and the indicators all flash simultaneously. I can confirm that the current in that moment is ample to blow a 315mA quick-blow fuse in the multimeter.  :blush:  :giggle:
Switching to the 20A range I found that the current settled down to somewhere between 10 and 20 mA sometime during the next couple of hours, good news.
Link to comment
that's really useful  cheers :sun:    I'v taken to using a cheep (thirty bob) and voltmeter from fleabay  (china)  which plugs into  the lighter socket(always live)  and can be easily read from outside the car, they seem to be surprisingly accurate too    +_  .2volt
Link to comment
  • 2 years later...
  • 3 months later...
On 06/04/2018 at 08:52, erindad said:
Those flea bay cheeps are quite expensive at thirty bob , is that for one or a bag of   ?   :D
Thirty bob (£1.50, to those who can't remember real money), IS cheap. Mind, coming from a Bonny Scot! Ill let you draw your own conclusions. :sweat:
I would expect the battery to be quite weak by now, though! That'll be a lot more then thirty bob!
Edited by mrgf
Link to comment
  • 6 months later...
I have saved that usefull technical info guide and noticed while reading it that the photo of the fusebox shows the meter probes being connected to 2 different fuses.
Or it could be that I need to go to Specsavers!
Link to comment
  • 2 months later...
Looking at the print of the statement, it means that we'll need even more exotic test gear, such as a DVM with a recording facility to record voltage over a time. Or a DVM with a separate output to drive a portable recorder. That and plenty of time. But I'm a bit sceptic as VAG love any excuse to get the labour bill up  to pelican level. ( Ed China comment).
Link to comment
  • 1 year later...
Hi
The link to Bently publihers is no longer working, has anyone saved the document mentioned (voltage drop accross fuses due to current draw) if so could you send me a coppy?
many thanks in anticiption Michael
Link to comment
  • 7 months later...
(Really, this isn't in the right place, there is a more up to date thread where it should have gone: https://www.briskoda.net/forums/topic/489055-how-deactivate-door-open-sensor-octavia-2011/)
I doubt it will help anyone, but just in case,here are a couple of things to consider:
If you've got a clamp-on current meter (for this kind of thing, it is helpful, I keep meaning to look in to one, but the need hasn't yet arisen) you can monitor more than one line at once.
Anywhere you can find a cable/big bundle of cables, you can put your clamp around. If you find a bundle that is taking current, you can start a 'binary division' approach with that bunch - divide it in to two, and keep dividing 'till you get to a single wire.
Err, while not what VW recommend, I'd even start on the cables, say, after five minutes, to get a 'short list' of wires that are most likely to need further attention.
One further point, at one stage (late 90's/early 2000s?) VW did have a problem with something slightly weird like Marmoset attacks in Austria taking out ignition cables, and causing cars not to start/misfire (I don't remember the exact details).
Hence, or otherwise (as they used to say in exam papers), I would have a look around the area of the mouse attack, just in case the mouse fancied something more substantial to go with the foam.
Edited by Camlobe
post in to old thread; see link
Link to comment
I know this topic is over a year old but I thought I'd post what I'd found. Not having used the car much lately I had the problem of the battery going flat. The first time was after about five weeks so fair enough, but has also gone flat within two weeks. The battery is only a couple of years old so hopefully OK. I did some measurements of the battery current and found that after about five minutes it would drop to either 400mA or 170mA - on subsequent tests with the same conditions This was with the car unlocked. If I locked the car it would drop to about 40mA with a slight pulsing, which I think is correct. I do have a habit of forgetting to lock the car as it is kept behind locked gates. I know I should wait longer  during the tests but I wondered if anyone else has noticed this?
Link to comment
When the car is unlocked many of the electronic modules stay awake only going to sleep when the car is locked, so to minimise current drain the car should always be locked when left unused for a long(ish) time.
  • Like 1
Link to comment
Thanks, that makes sense. The other thing during these investigations I found the alarm had failed, presumably due to the battery. I wonder if periodically the system tries to charge this battery, but of course it never achieves it, thereby draining more current from the main battery. I did my tests both with the alarm fuse in and out, with no difference, but I probably didn't do the test for long enough to observe it trying to charge the alarm battery. I'll leave the fuse out until I've fixed the alarm.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
