AMD's 2 litre 304bhp 162mph Fabia Monte Carlo TDi *6 speed conversion*
Just now, AMD87 said:
Hamilton
Ahhhh very local then! I’ll be sure to keep an eye out
  • Replies 636
  • Views 98.1k
  • Thread cleaned again. did some this am but rushing for a meeting.   please keep the bickering to a minimum.   if you don’t agree that’s fine, but as per the guidelines, please be nice
  • Noticed i didn't update this after street weekend. Was eventful.   On the cover   Made it to pod and in line first day was just to get a number on the board don't want to break
  • This is going to be a long post!   Finally got to splitting the 5 Speed box to finally see what the damage was and there was nothing left of 4th gear
youll hear it before you see it
Wow bent rods! The upgrade sounds like it might be fun, will be good to see it at Donnington later on in the year.
19 hours ago, AMD87 said:
Email from darkside today the fabia is done!
Few changes to the car since last time. Having made the most powerful 1.6 cayc that was properly documented (having seen some of the spec lists and info from the ones in turkey it didn’t make sense they were making the claimed power so really uncharted territory.
It was abit of a monster then one day it seemed to struggle on power. Got the car back to darkside and was down on compression which we thought was a valve or a piston ring but then noticed some marks on the bore.
Darkside stripped the engine down and we discovered rods 3 and 4 were bent (tdi reliability yo). Looks as if it might have been bearing failure. Hunt started to find a replacement 1.6 block although in talking to darkside we decided to go a different route and swap in a 2 litre CR140.
As the 2 litre is effectively a stroker kit on a 1.6 and we could swap the cams over and other parts so I bought the 23k 2 litre out of the 4WD caddy van they built and we upgraded the turbo to a GTB2260VK (was offered the engine less than what a 1.6 block would cost)
Fine tuned over the weekend and it’s now 274bhp getting up to 282 on meth.
Should be good for a couple of years then will get bigger injectors and a bigger turbo again 😂
They also made me a stool from the old engine 😂
Was it a big job putting in a 2l? Are you still using the stock 5 speed? That is a serious leap forward in terms of power especially since a 2l might hold a better chance of taking the power reliably.
Still using the 5 speed as it does have an upgraded diff in it and yeah. More than I think they thought.
Wiring was the main thing that caused issues but it effectively future proofs any more upgrades I do as I can get upgraded rods etc for the 2 litre.
So can we say that 240 or so hp is the limit for a stock bottom end? Its still impressive for a 1.6 that should only make 105 hp to go to 263 hp even if only for a while.
I would say so, Bobby is 252 on meth but I have about 40k more miles on my engine plus mine got abused way more than his. Loads more track time and drag time.
first proper mechanical issue with the engine too 😂
304bhp now 🤯
Wow 304bhp, what are you hoping to get, more?
Nah that’s us done for power just now 🤣
Gie's a go....!  😇
19 minutes ago, Schtum said:
Gie's a go....!  😇
I’ve not even had a go yet 🤣
I'm no' pushy. I'll happily go second or third....at a push. 😆
I've just been watching their video of the black Mk1 Fabia with 400+ bhp on nitrous.
They finished editing the video for this today so hopefully that will be up in the next couple of weeks.
Well picked it up today and its crazy.
Took it easy to the petrol station then on the way after it was warmed up i thought coming into a NSL i would put my foot down abit in 3rd, car didnt seem to go anywhere and thought i had broke it again looked down and seen the traction control light going crazy. It was trying to spin up the wheels in 3rd at 45mph! once it gets going it really really goes and doesn't seem to want to stop.
I was worried that it would be too loud but cruising on the motorway home on the cruise control it was no louder than it was with the CR170 turbo and managed 53mpg and no smoke.
Changes that  were done.
2.0 CR140 engine
GTB2260VK Turbo
Race cams
Headbolts
CP3 Fuel Pump
Stage 2 Injectors
W/M injection
2.0 Radiator
new oil and intercoolers
videos up
Reyt then.
I just can't get enough of the tahn accent
Watched  the vid and it seems like a lot of work.
When is the 6 speed going in?
Glad your happy with it, it certainly sounded a beast.
Not sure I’m happy with the 5 speed but Ryan really wants me to fit a 6 speed.
I probably would have did it if the wavetrac fitted but I would have had to buy another and I wanted to try and reuse as much parts as I could from the 1.6 build.
Some money spent on this Fabia fair play glad it’s pushed the 300bhp mark
 Looks like its in need for a good cleaning under the bonnet! I did my fabia the other night and it came up a treat. Also, i'd remove the plastic piece where the intake hose would have connected to the grille. Its just 2 torx screws and it comes off.
I’m not a fan of the clean look prefer it looking like it actually gets used 😂
Any reason why not using a bigger air intake using cold feed other than battery being in way ( which could be moved) or maybe turned sideways
Edited by Kobayashi
To be honest i didnt notice it wasnt there till the video went up then i looked at my pictures lol ill probably just get another for the sake of £14
