Huge play in steering
@fiftythreethirtynine - You may have learnt someplace different to me, but I was always told that the "steering arm" (sometimes steering or track rod) is the piece of straight bar that the inner (rack) and outer rod ends are both screwed onto.
I've always recieved conflcting information and the nomenclature seems a hazy area. I'm going to do a visual double check this afternoon before ordering parts.
It's the inner knuckles on the arms, the TRE's bolt on the other end, not a difficult job if you have access I am not sure but you should be able to do them in situ after taking the TRE's off, I thought this is what it was from the video.
Just unscrew the inners and replace. you will have a mark on the TRE end where you screw those off so screw them on the new ones the same and you shouldn't have much realignment to be done or if you are fitting new TRE's just take the whole arm off and TRE and match the length.
Edited by T2000
Thanks for the confirmation.
Got a quote for alignment for around £35 so I'm happy to pay that to make sure it's right.
I did this on one side last winter. Was easy enough but you got to make sure you have the right one! ECP sold me the one for the wrong rack. despite the right selection on the site! I'm not sure about length but there are two different types (possibly more) with different diameter rack end threads. (assuming one is for koyo and the other TRW)
A crows foot spanner or the specific socket like tool is pretty damn useful
The boot from mine did not sit on the replacement inner tie rod properly. Different diameter to the original to the point i couldn't really seal it properly.
The one i got was some random brand from the local motor factor, you may have better luck with OEM or a better brand
Thanks for the edit w/ image. Do you have a part number?
I was lucky as it was a Polo and they only ever had TRW steering systems, though the diameter on the TRW rod supplied by ECP was slightly bigger than the TRW original fit to that car, I think that I sealed it using two nylon cable ties with the locking ends 180 degrees apart. Though I think I eventually bought Constant Tension Hose Clips to suit the bigger diameter - and fitted them to complete that job properly - an ebay purchase.
Yup, that'll do it.
All fixed now and driving great (just waiting on tracking, booked tomorrow)
Thanks all for the advice.
Oh, that sounds a bit loose!
Yes that joint was definitely toast :biggrin:
