Skoda approved lowering springs for a MK3 VRS?
2 hours ago, BlockABoots said:
So what brand of spacers do people recommend and what size?, a lot seem to have 12mm but im not sure that would be enough and then some say 20mm is too much!?.
Can the spacers be installed yourself or once fitted does the tracking and wheel alignment need to be re-calibrated?
I haven't done it on my Skoda yet but on my previous car I had 25mm spacers installed on the rear and it made the ride quite choppy, but high speed handling was improved a bit. I didn't have to get an alignment done.
  • Replies 106
  • Views 39.5k
  • Both Rieger rieger-tuning.biz
  • I asked the same question many moons ago when I got my Mk3 VRS and there wasnt any, nor was they any springs for the vRS at that time. Whether its changed since Im not sure as it was 4 years ago.
  • JohnnyType2
    JohnnyType2
    got mine done, but im in Ulster so the roads are marginally better, although i thought you had much better surfaces now? anyway heres my vRS with TUV approved H&R springs 40mm over standard a
Is that 25m each side (so 5mm an axel)?
Yeah think id go for 15mm each side (30mm an axel).
Im hoping pushing the wheels out further would close up the gap between my 18" alloys and the wheel arches, there seems to be a fairly large gap
Yeah it was 25mm each side which is pretty big, it was a Falcon Ute with big bulgy guards. I reckon 15mm would look neat on a RSB)
With any size spacers do you need to get longer bolts also or can you get away with the already fitted bolts?
New Bolts, explained elsewhere in another spacer thread. You want to maintain the existing amount of thread engagement in the Hub. Measure an existing Bolt and add the length of the Spacer and get the nearest standard length not forgetting to get the Conical “Head” variant.
with 15/20mm spacers you will need 45mm bolts
Cheers
58 minutes ago, Esseesse200 said:
This is 15mm rear and 12 front
How much has that been lower by?
On 15/08/2018 at 21:29, JohnnyType2 said:
and 19s
JohnnyType2 can you show you rear diffuser? What brand is it? and that wing add on??
twinexit.jpg.a7881b3ecf2d6aecf06ba82a8c1bdcd0.jpgreflectors04.jpg.eff4d387867a73fdb2cc3ab3dee0434e.jpgreflectors07.jpg.7dbf7279fffe511d5ac6ee3bbd3d0efe.jpgreflectors09.jpg.4a5d53769733c75e7121afbf1636e187.jpg
spolier02.jpg.298e9609211ae2c7755dba86546586e5.jpgspolier03.jpg.50dff927ba0ee06b8a1c725ce89a5515.jpgspolier04.jpg.f51fff2e6ed33b6ad3c4ed0e3616bc76.jpgspolier05.jpg.c4dea1dd1024c2eb559d10f4e832b96d.jpgspolier08.jpg.465236d45eefb18dcd8910c262ea7b39.jpg
Edited by JohnnyType2
Thanks! That carbon looks amazing!
yeah the original maxton and rieger carbon look is poor even the 'real' carbon is very poor quality. Dipping gives it a better colour and much glossier and has a better 3D effect.
Thats why I asked About it ahah because from the side photo it looks different. And you dipped the big red reflector
yes didnt like it at all
Guess Will do the same on mine but still buying the dark diffuser, only carbono on the red stripe
Can't find this wing add on anywere...:dry:
Only found this One. Can't see any other pictures to find if its the same shape...
thats it. the very same
Thanks broB)
On 15/08/2018 at 23:17, BlackOctaviaRS said:
I have those 19s...damn it fits just perfect! 40/40 h&r??
Love the side sticker by the way
Hey Johnny
Where did you get those Rear mud flaps??
On 01/10/2018 at 20:27, JohnnyType2 said:
Hey Johnny
from skodaireland
  • 7 months later...
On 01/10/2017 at 08:10, Esseesse200 said:
Yep mine on H&R has been for 60k miles and no problems with the shocks etc. Ride is better than standard.
Hi mate am thinking about lowering my MK3 Skoda Octavia vrs do u remmond it
On 18/09/2018 at 08:46, JohnnyType2 said:
standard vRS is -15mm over stock, this was -40mm over stock front and back.
The side on stripe image is a better representation as the suspension had time to settle after being up on the jacks, it was up on the jacks in the close up.
nope no rubbing at all and i live on very uneven rural roads. it actually handles the bigger potholes with ease feels much safer.
Hi mate is the car better lowered
Hi mate. Mine was on H&R 40mm and it was awesome. Even loaded it was still good. Just go for it
