Installing Speed Cameras on The Amundsen MIB2 - Free Database and Quite Simple to Do!
Hei, i got two questions.
1. Do this work with an Amundsen+ nav?
2. Do anyone knows how to get speedcam-pois for norway?
Thx
Kenny
  • Replies 493
  • Views 139.8k
  • Latest Updated Speedcams - December, 2022.   It's been a long while but at last here's the latest update of my customised version of EUR Speedcams ( December, 2022). They consist of the full
  • Latest Updated Speedcams - November, 2021.   Here's the latest update of my customised version of EUR Speedcams ( November, 2021). They consist of the full EUROPE speed cameras which I've sp
  • At last and after a long break - here's the latest update of my customised version of EUR Speedcams ( February, 2021). They consist of the full EUROPE speed cameras which I've split up into four conso
Thx
Kenny
1. Sorry, but I wouldn't think so - Amundsen+ is an earlier system ( RNS315 ) so it requires a different format.
2. Sorry - I don't know the answer to that one.
Edited by bigade1
Ok, thanx. I just got this Octavia new (2020 mod). Strange it came with an old satnav
If you have a 2020 Octavia then you don't have an Amundsen+, you have a MIB2 Amundsen.
If you have a 2021 Octavia (new shape) then you have the latest (MIB3?) AMundsen.
Might be a good idea to post a picture of your Amundsen...
Googled pictures and my Amundsen is an mib2
3 hours ago, BionicJohn said:
 https://www.scdb.info/en/karte/ may have speed camera info for Skoda/Norway.  You will need to subscribe. 😕
Seems like they covers norway. 10 EUR for 1y seems ok if the cams is somewhat updated.
Thx for the tip
If that's the case then my speedcams should work for your device and my latest ones are indeed the SCDB ones for Europe so therefore Norway is included.
Thx alot, will try when home from vacation
Thanks bigade1
Thanks Bigade1 worked first time on my Columbus 😃
CJL
Thanks Bigade1
Worked a treat on my 2016 Columbus, thanks. 👍
working here on my Rapid Spaceback 2017, many thanks
Many thanx for your effort 👍
Excellent work - now I've got a Skoda with a satnav this perfect.  Much appreciated!
Hello Skoda users!
I do not know what means Amundsen "MIB2". I just know that I have Amundsen NAV and this POI import didn't work. I get reply that it founds nothing.
If I go to update from SD card, I lead to all folders on SD cards and it founds nothing to import.
Any idea?
Thank you!
Are your maps read directly from an SD card? Yes = Amunsen, no =Columbus
What year is your Octavia 3?
2014 or earlier = MIB1
2015 = MIB1 until May build, MIB2 after
2016 = MIB2
Does EU speed cams include UK safety cameras as well?
Hi bigade1!
Thank you! I did successfully imported Speedcams, but it seems strange that when I checked cams available locally, system has found 10-20 cams, but nevertheless I did not see any on map. So I couldn't check really if I would see one if there was one and if I would be alerted.
Am I missing something?
Thank you!
@kolma
Check your navigation menu settings. Under the " Map " menu ensure that the " Show POIs "setting is ticked then enter the " Select categories for POIs " menu and scroll to the bottom to see the newly added speedcam categories. Then tick each speedcam category to display them on your map. If the speedcams have been correctly installed and activated you should then see the cameras by using your fingers on the touchscreen to zoom in and out of different areas of the map. Also check the settings in " Nav. announcements " if you want to enable an audible alert.
I've seen this thread a few times now (assuming it pops back up the top when there's an update) but I've just put this onto my second SD card, put it into my Columbus MIB2 and it appears to have accepted them. I've searched the thread, but I've not found a definite yes or no if they do indeed work on the Columbus.
I'll be off the gym in the morning and I know I'll be driving past at least 2 cameras (a red light and a normal speed camera).
I've set them to appear on my POI's and hopefully I've set them to 'ping' when I'm in their vicinity, so fingers crossed all looks good to go. I'll report back tomorrow.
