Tyre/Road Noise advice
Hello all,
I’m about to replace tyres on my SE TSi and currently have Pirelli P1’s, size is 215/55/17.
Looking to replace with a mid range alternative, just looking for any advice out there?
Dont particularly care about wet grip or any performance related metrics, but do care about sourcing a very quiet tyre if possible.
Thanks in advance!
  • Replies 50
  • Views 12.1k
  • Paikesejanku
    Paikesejanku
    Hi   I have done sonud-deadening to my MK2 and also for MK3. For MK2 I made full body isolation like on this link: https://www.drive2.com/l/463932060466151620/ It does not take away roa
  • Paikesejanku
    Paikesejanku
    Made tyre change from Continental ContiPermiumContact5 215/55 R17 W to Goodyear Effcient Grip Performance 215/55 R17 V.   Conclusion: GY has softer edges and is overall softer - Ride
  • by install sound-deadening i got 7 of 10 isolation from outside noises but just 3 of 10 for suspension noises, i have feeling all the body of the car works as one big sub woofer on rough roads
I fitted Continental Max Contact 5 in this size to my SE Business, replacing P7s. They were fantasticaly quiet and had great ride and grip too. Higher rolling resistance though which made it feel a little slower off the line.  Still miss the silence and ride quality as I have an SEL on 18”s now. MASSIVE noise difference from the Pirellis.
thanks for the reply, did you change all 4 tyres of just front 2? Do you remember the approx cost?
Uniroyal ‘Rainsport3’ set just fitted to mine and are noticeably quieter.  Around £100 a corner fitted.
Uniroyal are part of the Continental tyre family so should be OK.  Dual tread pattern design.
Martinib,
was there a big difference in road noise with the Michelin’s?
Had the Uniroyal Rainsport3's on my Audi A6 and they were probably the quietest tyre I've ever used (2nd were Avon something-or-others).
I've got Goodyears on my Superb 2 at the moment, and they are much quieter than the original Pirelli's
How do the noise rating on the tyre label tie in with peoples actual experience?
Is the Rainsport 3 rating different to the P7 ?
For example I just checked on Tyre Shopper & for 225x45x17, load 91, Y rated & the P7 is 71 dB & Rainsport 3  is 71 dB
I think the noise rating is based on a measurement outside the car as it passes.  Obviously, this will be related to the amount of noise that enters the cabin but is not the whole story.  Things like vibration that travel through the suspension, drivetrain etc. that cause noise wouldn't be included.  Some of the car magazines include a measurement inside the car as part of their tests which would be more accurate but still flawed unless you can find a review of the exact size of tyre using a superb as the test vehicle.  I'd go with the opinions of people on here first :)
All 4, £90 each fitted.
For whats its worth - I've always found Pirelli tyres to be louder than alternatives whenever I've had them fitted to a car of mine.
Edited by dchbrown
6 minutes ago, dchbrown said:
For whats its worth - I've always found Pirelli tyres to be more 5hit than alternatives whenever I've had them fitted to a car of mine.
FTFY :biggrin:
Michelins are quieter,
but i still thinking about experiment with insert ~2cm sound deadening foam inside tires
Another thumbs up for the Uniroyal Rainsport 3’s here.  Quiet, comfortable ride and plenty of grip too.
I bought mine in winter and tyres noise was reasonable. I thought it will be better on summer tyres (P7 R18). Boy I was wrong :) .
It is like I'm sitting in a plane now . I do not understand how these youtube reviewers do not mention this.
Should I buy new tyres or switch to  R17 wheels ?
Tyre/road noise is a massive massive disappointment in my new 1.4 SEL. By far noisier than the Fabia ii and Octavia ii we also have. I only hope that when eventually the P7's are changed that things will get better.
When ordering I seriously considered downgrading to the 17" mainly for better ride and cheaper tyres but my inner self couldn't bring myself to do it for no reduction in price from Skoda.
Although it's very much early days for me, I must say all those gushing reviews I read, particularly the videos, do exaggerate the ride quality and no mention of road noise which is immediately obvious on the standard P7 we seem to get in the UK.
I did recently a new Superb in the showroom on 18” Continental Sport Contacts.....and I was jealous/annoyed/sad at seeing that.
I will probably be going to over to either Michelin Crossclimate or Vredestein Quattrac 5 when the P7s wear out (based on experience with our other cars) though that's going to be at least 3 years away.
If I were to advise anyone ordering new, seriously consider the Canton option as this is advertised in the latest brochure as having vehicle noise cancellation. And also the acoustic front windows, but these are not are available in the Uk, no idea why not.
Edited by xman
I'm coming from motorcycling, so the P7's seem pretty quiet to me... As far as Canton noise cancelling goes, that's ad-speak if I ever heard it. I've got Canton. I sounds good, too. But it's noise-masking, not noise-cancelling.
I would try Avon tyres, if they made a 19" – but they don't. Always had a good wet reputation, which makes sense in south Wales. Or London lately.
I do a lot of miles, just put the P7s it came with back on having bust two of the Sottozeros on pot holes, and was due to go back to summers anyway. They ain't noticeably louder than any other tyre or car I've had...
Continental ContiSportContact with their anti puncture techno. Much quieter than the Pirelli's and should last longer. £663 for all four fittend and tracking at Micheldever tyres (their local franchise) last Friday.
I chose the 17" because I had just had the unpleasant experience of low profile tyres on a Focus and was determined not to repeat that.
With all the comments about P7's I'm glad I did. I find the ride good and the noise level acceptable.
It was meant to have super rowi tyres but it came with Continental's which didn't worry me.
Stupid and dangerous and I am sure insurance would be invalidated.
I would be really worried about the shell overheating and no successful test means it’s unlikely to help. I think tyre noise more to do with tread design (oscillation frequency/slap) and the silica content than the internal chamber. I know sound can travel through an air gap, but if it was significant amplification I would expect ultra low profile and run flat models to be quieter.
I think lining the wheel wells (behind the liner?) would give better results. Or a set of really quiet tyres:
https://www.tyreleader.co.uk/car-tyres/yokohama/advan-fleva-v701/215-55-r17-94w-765303
