Audi Throttle Response
Gizmo modified my car when I was in the UK last week, including activating the Audi throttle response and an accompanying VCDS option which apparently optimises this (apologies, I forget the name of it). There seems to be a variety of opinion on the benefits of this mod, so I thought I would add my two penn'orth for anyone thinking of doing it.
As you can see from my profile, I have a 150 DSG. IMHO the mod makes a significant difference to this engine/transmission. I still occasionally notice a little lag, but it doesn't really bother me. The main reason I wanted the mod was for cornering (there are a lot of windy roads around here). Prior to the mod, even if I started to put pressure on the accelerator before entering a corner (obviously not advisable normally) it wouldn't usually kick in until well after exiting the bend, thereby losing some traction. Now it behaves more or less how my old manual used to behave.
I ruled out getting a Pedal Box due to our French insurer. I understand that this is even better. However, I'm very happy with the Audi throttle and I'm not sure I would bother with the Pedal Box even if insurance was not an issue.
I'm more ambiguous about the other VCDS mod that affects the operation of the car - auto locking when leaving the car. The problem is that it locks whenever you shut a door. So if you get out and close the door but need to get something from the back seat area, you have to re-open it again via the handle or key fob. This can be inconvenient - though it's partly a matter of getting used to it and anticipating, which I am getting better at. OTOH I like the fact that a. I can just walk away from the car when I'm say briefly going into a shop; and b. I know that the car is locked (if with no alarm) even if I forget to touch the front door handle when parking up properly.
Other mods, which were mostly more minor or aesthetic (DRLs), I'm very happy with. I do like the fact that the clock now changes automatically to reflect the current time where I am.
Many thanks once again to you Gizmo for being so generous with your time and equipment. Hope you enjoyed the Jupiler.
  • Replies 54
  • Views 33.7k
  • Go to adaptations (under 44 - steering Assist) and search ‘driving' Under “Driving profile switchover’ as std it will be: “Incremental: controlled over time”     Change this
  • GnurkeGnurk
    GnurkeGnurk
    44 module (steering assist)   Security access: 19249   Adaptations   Select channel: 'Driving profile switchover'   Change from 'Incremental: controlled over ti
  • varaderoguy
    varaderoguy
    I wanted to add in my experience about the Module 44 mod.   It would be no small thing to say that this change to the accelerator pedal profile - has transformed our small fleet of cars.
I wonder if the Audi throttle mod favours DSG cars (?)  I applied it to my manual 150 TDI and noticed no difference.
I applied the mod to my 220 DSG L&K and noticed no difference. So I fitted a DTUK pedal box and the difference was day and night.
This is totally random and extremely off topic but I wondered if this photo reminded you of home(ish)?
Was down there on Saturday John999boy to watch a film at a cinema a few hundred metres from where you took the picture.:biggrin:
Back on topic - I'm surprised you noticed no difference with your DSG TerryMcK. It really is appreciable in my car. Could the fact that yours is petrol make a difference? Perhaps the lag is worse with diesels. With a manual such as yours Penguin17 I would be less surprised if the change is less dramatic. Another factor might be the second connected mod that Gizmo made to my car - this apparently improves the Audi response, though if I understood correctly more to the smoothness of the response rather than the immediacy.
Yes I think the petrol engine may be the difference. Anyway fitting of the pedal box worked for me.
The "Audi mod" works perfect on the 1.4 TSI DSG as well!
I wasn't aware of another, associated mod...any further info please?
Sorry, as I said above I forgot the name of the mod which Gizmo had told me. When he did the mods a couple of weeks ago, he said he'd be describing it on the forum in due course.
Thanks.  @Gizmo please do tell :biggrin:
Sorry. The photo? Is that Annecy by any chance?
44 - driver profile switchover
Change this to:
“Direct: controlled over threshold value”
44 direct contolled
What you will now have is more ‘normal’ throttle pedal.
I have tried the Audi mod and this one combined with my pedal box turned off, yes it is better but still not as good as the pedal box, HOWEVER once the ‘Driving profile’ has been changed it improved the pedal box even more!.
Yes it is. :thumbup:
I also didn't really notice a difference with the Audi mod - 150 DSG.
I wonder if the driving profile mod can be carried out with OBD eleven?
Pretty town. We had three nights there on our ill-fated motorcycle trip to The Dolomites. Annecy has definitely seen a tourist or two!
We're in Aachen at the moment. Driving in Germany on the Autobahn is a whole 'nuther world. I've got the DTUK Pedal Box fitted and have had to increase the setting from City plus two to City plus three to keep out of everybody's way. Cruising at 3K RPM in top is a wondrous thing in my Sportline, but the downside is accidents like the on we saw on the A1 yesterday near Cologne. There was an articulated lorry sideways across the motorway and a single car carrier lorry on its side. We couldn't see over the barrier to see how many other vehicles were involved, but the traffic was stopped, and stopped for miles and miles – people standing outside their cars.  A dozen emergency vehicles with lights flashing were stuck in the mix, unable to get to the crash scene.
The police had the A1 blocked at the next exit and diverting traffic off the road, but that too was at a stand still for miles and miles. Sheesh.
Just made the change with OBD11
Use first code for adaption.
Seems like it does something with the dampers and steering also (DCC chassis). Might be imagination but it feels more "active" in adjusting dampers and steering.
Got no facts to back this up - just a feeling :)
The Audi mod? Or above?
The "above".
Did Audi mod before and I think I felt a change. This added to that feeling + damper thingy feeling more active.
41 minutes ago, Baverhanne said:
The "above".
Hmm interesting, tempted to try ^^
I'll let my colleague who has a superb with exactly the same spec and age take a test drive with mine for comparison. Always easier to test back to back
I applied mod and got to say I feel huge difference. But could be brain thing hehe. I have engine set to Skoda not Audi. I feel all different. Pedal, dcc and steering. But as said could be just feeling
Any images available of the vcds screens for the Audi throttle mod itself ?.  The images on the forums show web hosting disabled
Hi @Baverhanne
Care to share the adaptations / coding for the Audi and driving mode changes under OBDeleven? Haven't been brave enough to try any coding on mine yet. Thanks.
19 hours ago, BriskodaJeff said:
On 18/04/2018 at 17:00, Baverhanne said:
Hi @Baverhanne
+ 1. I’ve been back and forth between the Audi /Skoda pedal. I’d be interested in this further mod.
Also, updated my OBDeleven software last week and I can only get long coding details rather than the easier way of checking and unchecking boxes to make Skoda to Audi throttle change. Have clearly not set this up correctly and I’m afraid to do anything now.
Hi @Ashmount. I wasn't aware there was ever an app for the Audi throttle mod on OBDeleven. Don't suppose you remember which one it was / what it was called?
