VCDS Adaptation: Enable use of remote while car is running
Winter is coming... :)
Thus I find myself leaving my car running when I have to do a quick errand like refilling my coffe at the service station, or getting some groceries. More often than not my toddlers are in the car. The idea of someone driving off with them while I'm gone is very unpleasant. On my mk2 Octavia I would lock the car manually with the spare key, but the mk3 has the keyhole hidden under a cap, and as such is a hassle to get to.
So in the depths of the internets I found the solution to enable the mk3 to acknowledge radio signals from the second keyfob. Now I can lock (and unlock) the car while it's running with the main key in the ignition, and don't have to worry about someone taking off with my car and cargo while I'm away.
On 09 Central Electronics go to 10 Adaptation and find channel "Access control-Funk bei klemme 15 ein" and change it from "not active" to "active".
Is turning the car off and taking the key with you not a much better and safer option?
It is most likely the safer choice, yes.
But the kids would freeze, so I would have to bring them with me - turning a quick errand into a three man quest :-)
Freeze? How long are you leaving them for, an hour?!?  They won’t freeze with no heating on for 5 minutes.
The OP is from Norway. At the moment with all the snow Reindeer and Elk freeze solid in minutes.................
Get an electric car. Leave people in the car and use app to remotely turn on climate control.
Biggest benefit is no wasted fuel and no pollution. You are not wasting fuel running a machine, originally intended to generate torque, for its by-product: heat.
Norway also have Great EV incentives, much better than here in UK.
Yer don't they have more tesla ownership by population than pretty much anywhere else in the world?
3rd largest market for tesla despite population size :)
https://electrek.co/2017/10/06/tesla-record-norway-registers-lowest-co2-emissions-electric-car/
And if they decide to play around with gears??
It is a bit different when there is -32°C outside. It's not just the freezing, the moisture from exhale is also significant.
However, I use Webasto for this purpose. I don't leave the car running unattended.
A valid concern, indeed. The 2y old is not able to unbuckle himselves (yet) luckily. The 6y old knows that it's very bad to touch anything except interior lighting. She is not able to unbuckle her brother, either.
Also, it's a DSG so even if she knew how I don't think she would be able to put it in drive. (Press brake while pressing the switch on the lever).
Leaving a car idling is illegal here in Norway, too - and very bad for the environment indeed.
Winter Is coming? Bruh where do you live?
It’s chaos in the entire country - and that says a little, we’re pretty used to snow :D
This is a stupid idea.
Why?
Done this for years with no issues.
i've seen it a lot when it gets below -15 or so... without webasto, things get cold *very* quickly at -30.
 - Bret
40 minutes ago, BGB said:
Why?
SWMBO Mini (2017) allows you to walk away with the Key and lock the door with the engine running as Standard.
Or light a small fire in the car....
Get a run lock system fitted.... its basically a relay that fits into the ignition system that once you activate it you can then remove your key from the ignition & lock the doors.
The engine then keeps running but if the handbrake is release or if the brake pedal is pressed the system cuts out & stops the engine.
Most emergency service vehicles are fitted with them so they can be left running while at incidents where they need to keep things powers inside for long periods.
  • 3 years later...
Verry helpful. Thank you, sir!
I think this thread needs to be moderated due to too much offtopic.
