DRL fitting to complement factory poor DRLs
14 hours ago, roynhayley said:
Hi for my twopenneth I have used these; some fleabay items without fault for the last 3 years they are plenty bright and as they are 21w they do not throw any errors. My ones are no longer available from the seller I used  type in  BA15S 50W DRL CREE SMD LED LIGHT CANBUS ERROR FREE 382 P21w WHITE BULB XENON to search for the required items. Good luck, there are some 50w ones too  but they maybe too bright.
Thanks @ronhagley will see what that brings.
On 10/04/2019 at 13:37, gav_is_con said:
@MarkTB can you link me the bulbs and resistors. Maybe that’s the solution that involves no coding changes. I like plug and play, no heat related issues using LED in lights then like some of those H7 bulbs you get ?
apologies for the delay is replying to you, not had chance to search the info out.
The bulbs i fitted are: https://www.ebay.co.uk/itm/321517034780?ul_noapp=true
The in-line resisters are: http://sklep.motohid.pl/pl/p/Adapter-Kasownik-do-LED-DRL-Octavia-2-FL%2C-Superb%2C-Passat-STANDARD/1687
Thanks @MarkTB did you order from the site in Poland looks like they are about £12 for the resistors. I can’t see an English area to the site?
Yes I did, from memory they took about a week to come. :thumbup:
