Infotainment retrofitting
Hi @pab567  !
Sorry to boder you :) but, can you be so kind and advice me about what should i look for?
Thank you for you time an help !
Hello,
I have on my o3 2016 , got my  Amundsen 5Q0034864A with 0253 sw  and i would like update/change  my screen with bigger one at 8 inch.
I have serached here but i not sure what what part nr i should be looking for . can you please be so kind and tell me what part number screen unuit i should be looking to buy ?
I allready have activated smartlink, do i loose it if i change the screen?
Can i aslo update /convert to 0480 i hearred, it's possible?
Thanks !  '''
  • Replies 213
  • Views 79k
  • If you already have sound system by Canton then better change amplifier as each of your speakers is driven separately (active crossover). Columbus can drive 4 channels (doors) via PASSIVE crossover an
  • 5E0919606 8 inch PFL Columbus or 5E0919605M 8 inch FL Amundsen are the screens that will work for you. No coding required, a small mod to a connector is required. SmartLink is about £137 from Skoda.
  • @nori you have Amundsen MIB2 MY16, non-DAB. You can use any of screens you mentioned (3V0919606, 3V0919605D), they are P&P, just note in case of 3V0919605D you will get a little space between the
Update is possible but it requires unit to have swdownload patched first.
Screen display is P&P, it does NOT affect any active features, but with your current SW button APP will not work.
Thank you for your  advice, answer!
Can you advise me the description of the connectors pink and beige, thank you.
5E0 035 840 A unit
Beige = fm antenna
Yellow = usb cable
Pink = screen
  • 6 months later...
I'm quite interested in the 6 channel driven from unit mode, any way of doing this with a simple VCDS?
Thanks mate.
  • 7 months later...
Hello i gave octavia 2015 with old Mib1 5E….. i bought lcd with pn 5E0919605M from newer octavia -glass touch lcd.
Which unit PN should i get to be possible to code it on that screen with dab and navi? I know that 5q0035874 would fit but is there any cheaper solution or anyone has it for sale?
I don't think that screen is compatible with a MIB1 unit - @pab567 can you confirm?
Please post the full part number of your MIB1 unit - DAB and Nav are NOT just coding!
Indeed, 5E0919605M works ONLY with MIB2 units.
Pls share your your VIN so I can check for compatibility issues if any.
Yes i know becouse of resolution. Like i said i already bougt this lcd , now need to buy unit- i just want to know which unit would be compatible with screen, i know it s not just coding bit also CP….etc i have guy who will fix al this and install but just need to know which PN for unit should i search to BUY which would be chepest option(skoda,seat,…)
With navi and dab of course
Thank you
Vin: TMBJK7NE8F0135702
So now you have Amundsen MIB1, with Bluetooth, with DAB, part number 5E0035874A, with USB 5Q0035726B and fortunately you don't have CANTON sound system.
For display unit 5E0919605M you can use either Amundsen MIB2 5Q0035874x / 565035874 or MIB2 Columbus 3V0035020x (without SIM/LTE) or 3V0035021x (with SIM/LTE - in this case you also need to add antennas for LTE).
If you woulkd like to use Apple CarPlay then you also have to replace USB port.
The question is what is your budget and which of listed below features are "must have":
- Video playback from DVD, USB, SD
- CD playback
- displaying OEM maps in Virtual Cluster (Active Info Display).
Both units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. Features that differ them:
- MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
- MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster)
7 hours ago, pab567 said:
Zdaj imate Amundsen MIB1, z Bluetoothom, z DAB, številka dela 5E0035874A, z USB 5Q0035726B in na srečo nimate zvočnega sistema CANTON.
Za prikazovalno enoto 5E0919605M lahko uporabite Amundsen MIB2 5Q0035874x / 565035874 ali MIB2 Columbus 3V0035020x (brez SIM/LTE) ali 3V0035021x (s SIM/LTE - v tem primeru morate dodati tudi antene za LTE).
Če bi radi uporabljali Apple CarPlay, morate zamenjati tudi vrata USB.
Vprašanje je, kakšen je vaš proračun in katere od spodaj naštetih funkcij morate imeti:
- Predvajanje videa z DVD, USB, SD
- predvajanje CD-jev
- prikaz zemljevidov OEM v Virtual Cluster (Active Info Display).
Obe enoti podpirata SmartLink (Android Auto, Apple CarPlay, MirrorLink), vzvratno kamero, glasovno upravljanje. Lastnosti, ki jih razlikujejo:
- MIB2 Amundsen - OEM navigacija, brez pogona CD/DVD, brez predvajanja videa iz SD/USB, podpora za prikaz zemljevidov OEM v aktivnem informacijskem zaslonu (virtualni grozd)
- MIB2 Columbus - OEM navigacija, CD/DVD pogon, predvajanje videa iz SD/USB, ni podpore za prikaz zemljevidov OEM v Active Info Display (Virtual Cluster)
Today i get 5q0035864B and newer USB i know it s without DAB i bought it becouse it was realy good price. So now waiting to put everithing together
10 hours ago, zore89 said:
How do you plan to remove Component Protection?
I have a guy who is working this retrofits for vag
Hi.. I need some help on swapping Swing plus w/ Columbus (picture below). I bought a used Skoda and information about possible Infotainment systems on a MY17 O3 1.6 TDI is as shared. Is it something affordable? How much euros? Can Local (Turkish) Skoda garages help with that? Thx image.png
Hi,the swap is not a straight swap.at the moment you have a display and unit together,if you want to upgrade to colombus or amundsen you need to change the glove box insert to acomodate the new unit,you need a new cable extension and most importantly you will have to deal with component protection and the radio itself can be very expensive,a used unit amundsen coast around 600 euros.plus the insert and work.i would say around 1000 euros for everything.
On 01/06/2021 at 16:27, AlbertoOctavia2014 said:
Hi thank you.
Here is the photos, I want to know if I can just buy the front panel with SatNav or Chinese radio Android with GPS and just plug and play.
What would happen with the information that radio actually give, for example, consumption and that.
I look forward for help.
Just curious if you've come across anything for our system. Mine's the same version: Part number 5E0035842A, Software 13.41.19_H15.10.138_STDPlus_EU. Any luck finding updates or info?
Hi @pab567 @SashaGrace,
I have bought a mib2.5 unit 565035021 and also have a 8 inch 5E0919605 display for my 2016 octavia vrs
Will these work together or will I also need a 9.2inch display?
Also does the display cable need changed as I've noticed cable on car is pink and connector on mib2.5 is grey
Thanks in advance
You need 9.2" display 5E0919606D. Just cut from the pink plug an excessive piecie of plastic that does not allow you to insert it into grey socket.
Hi, I came across a seemingly very good deal on Columbus MIB2.5 565035021C head unit with screen, not sure if its legit yet but before I contact the seller I wanted to be 100% sure it fits my car which is a 2013 (TMBJE7NE6E0060066), also no canton. And if I understand correctly, I would still need a usb port replacement. The seller claims its plug and play, but even if its not, I think 700€ is cheap enough price to get CP removed somewhere else.
Edited by slogaje
Yes,it is plug and play if you already have the unit on the glove box,if not you need an extension from aliexpress,you can also get the USB from aliexpress,maybe 25 euros altogether.i did the same retrofit,i had a swing unit,had to change cables and everything, but it is straightforward.
yes, well, I do need to change both, the display and the head unit in the glove box.
Hi @pab567,
I’ve recently bought a 2014 Octavia Elegance, VIN is TMBKJ7NE7E0194438 and would like to upgrade to get carplay, not sure if I need to do the amp change too
Read through your old posts and believe I’ve got a MIB1 Amundsen, and would like to upgrade to MIB2 Amundsen (or Bolero not too sure on the differences) I know for carplay I also need to upgrade the usb port too
Would you be able to PM me a quote for a plug & play option? Sorry I’m a new user so unable to send myself
Thanks!
On 20/08/2025 at 08:31, slogaje said:
You have to replace both glove box unit and display. Glove box unit must be reworked - patched for Component Protection and activations. It must also have coding and adaptation adjusted to match your car equipment.
If you would like to use Apple CarPlay then you also have to replace USB port.
Edited by pab567
