I need Bolero Update :-)
1 hour ago, gumuskurt22 said:
Hi 5GD 035 280 B multimedya Skoda rapid 2016 spaceback
Is it compatible?
Sorry my list only knows Software Train.
Are you still trying to make mirrorlink on this?
On 02/09/2022 at 07:47, gumuskurt22 said:
Thank you! the update is complete. but nothing changed. He got hopeful when he saw MirrorLink in the update files, but it still doesn't show up in the menu. Is there anything that can be done to enable MirrorLink?
  • Replies 1.2k
  • Views 217.6k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Yes sir
12 minutes ago, gumuskurt22 said:
Yes sir
You will need Developer menu enabling, this needs VCDS or equivalent tool that can login to radio and adapt channel.
After you then can use the "toolkit"
İts work my old unit?
Is it compatible?
Ok, maybe language barrier is issue.
I don't understand your post here.
does it apply to the method? My unit
13 minutes ago, gumuskurt22 said:
Because you can see this screen, you have enabled "Developer Mode"
But have you installed this?
This enables you to enable missing codes.
Im not installed this
And you now wish to install this to modify your car features?
Ve şimdi bunu arabanızın özelliklerini değiştirmek için mi kurmak istiyorsunuz ?
I need carplay and android auto
I shall send you a PM, you will be having to operate on your own choice.
Hi All,
I have just bought a 2015 mk 3 fabia and want to be able to connect my S21 and use apps.
Currently there only appears to be mirrorlink installed which isn't compatible with my phone.
Is it possible to update my firmware/software to allow me to do this?
5 hours ago, MrBoyson31 said:
Hi All,
There is an update to 0138
But this is bug fixes and such, the features are existing in all firmwares usually, but they are turned on and off with codes usually programmed in at factory.
Ah, so no real point updating?
I read further up the thread that there is a way to enable features such as voice the control?
I would worry about the update myself, and won't add any new features I would say.
Hi!
I am also looking for an update.
My car: Skoda Rapid Spaceback 2016/12
Thank you!
1 hour ago, CoLoNeL said:
Hi!
Thank you!
Try to hold down the Menu button for 10 seconds to get the Software Train information, this also has the firmware update button you need.
Hi varooom,
Will the attached images suffice?
My car does not support image transfer via usb cable. Seems like there is no "mirrorlink/Smartlink" features. Can I activate it with an update? Or do I need to install new software?
Available is 0369 update, even the old firmware has the features inside, but they are only enabled via codes!
You can pay some independent workshops or main dealer to active, and there's also a "free" option where you patch the unit to unlock all the codes.
How can I download the 0369 update?
How do I unlock codes? what menu exactly is the free option in?
I can send a link for the firmware, but this won't solve the unlock.
A dealer should be able to provide and input the code, otherwise the free choice needs more work (no such thing as a free lunch)
You need to enable developer engineering mode, and install a toolkit to hack the unit.  You need VCDS or similar to enable this extra hidden menu.
Hi everyone - first time Skoda owner - just signed up...
I'm also looking to do all the updates on my car - I have the 2015 Bolero with Carplay - can someone point me to the firmware update files?
I also have access to an official VCDS cable if that's what required
Cheers
System Information
Device part: 5Q0035842A
Hardware: H24
Software: 0241
Media Coded: 2101.0.0.8
Cheers
System Information
Hardware: H24
Software: 0241
Odds are 0253 is available, but you should hold down menu key for about 10 seconds to enter engineering menu, look for Software Train information and take a picture of that.
Thanks - and is it worth updating, or no real benefit?
haven't had any problems so far with 2 phones and carplay, but i haven't upgraded to iOS 16 yet either
Edited by tyusaf
