Amundsen MIB2 Firmware Update
@pab567 can you help me bro?
Some instructions how to do it also?
  • Replies 4.6k
  • Views 773.3k
On 17/06/2020 at 16:15, TheWanderer said:
This is what I have on my system.
If you can advise me if there is an newer version I would be most grateful.
This is map version, not unit software...
All others check your PMs
28 minutes ago, pab567 said:
Todos los demás verifican sus PM
Gracias por su información
Atentamente
Pepe
I'm trying to find it, but I can't get the hardware and software details to appear on the screen.
Can you tell me how to find them please.
TIA. 🙂
@TheWanderer
On my Amundsen MIB2:
Press the menu button - scroll to settings - scroll down to system information. Alternatively, if I press and hold the menu button in for a few seconds it goes into the service menu and lists all the specific softwares. I would imagine all the devices are similar.
Edited by bigade1
Thanks bigade. Spot on. Info retrieved.
Here we go. The relevant information about my cars Infotainment system.
Hello
Over the last week or so, every restart 'wipes' the memory of my fuel consumption figures. This applies to all readings, 'since start', 'since refuel' and 'long term'. In the scheme of things, it's not a major problem, but it is annoying me more than a little. I think the 'long term' driving consumption is a good indication of both my driving style and car performance.
Do you think a software upgrade could solve the problem?
Amunsden
Radio database version: Hardware H41 Software 0475
Navigation Database : 5L0051236BF
Honestly speaking - I don't think so... but give it a try, you got link on PM
Many thanks Pab. Your help is greatly appreciated👍
Thanks.
Good Morning folks,
my new (used) Octavia have trouble with connecting over Android Auto.
The Software tries frequently to connect the S8+ over Mirrorlink. But Mirrorlink doesnt work. Is there an option to update the radio software or to disable the option Mirorlink?
Thanks a lot for you support!
Hi guys, is there a more recent update available for my system? (see pic) Thank you in adavnce
Just remind me and tell me if I've got this right, because I'll do this on a run to work which is around about 25'.
1. Format a SD card to FAT32.
2. Extract the contents of the file that I have to the SD card.
3. Remove ALL cards from the controller in the glovebox
4. Insert the card containing the firmware update into Slot 1
5. Go into the menu, find and activate the update function
6. Let it get on with it, do not stop the engine or turn off the ignition during the process. Or stop it once started.
7. Once complete, let it reboot and stabilize and it's complete.
Yes?
Hi
Recieved my used 2016/12 skoda octavia today...and i am very happy with it. But please @pab567, can you check if there is an firmware update available for my installed radio. Here are my versions: (I know the nav DB is old too..havent updated it yet)
Thanks in advance!!!
IMG_20200626_203321.thumb.jpg.49fc83869f335df491e97804a2a767a3.jpgIMG_20200626_203716.thumb.jpg.571f656ac6cec8bc0a82ffa0188b4525.jpg
Hi pab567,
I have Problem with my mib std2 with boot
Firmware ist 0138T
Did U have 0138T Firmware to flash IT again
Or Any other solution
Radio is
5C00035680A
Thx
@karg you can disable MirrorLink in adaptations, change channel ENG109862-ENG138662-Vehicle_configuration-Mirror_link to OFF
Yes?
This will work, 5 - go to Service menu (long press MENU button)
All check you PM
I have a 2015 Octavia.  I'm having problems with my bluetooth mic, will any available update to my system likely fix that?  No one can hear me during a call and the voice control doesn't hear me.  I assume there is an update available?  Am I in the right thread for my system?  I am assuming it is MIB2???  If so can someone send it to me with some instructions please
Current system information attached.
If anyone can point me to a thread on fixing Octavia bluetooth microphones that would be great too
Hie all,
I'm quite new on this wonderful forum. I've an Octavia 3 Combi purchased by the end of 2019. You can find the software and hardware details on the provided picture. I've a lot of issues with WLAN connectivity and also bluetooth connection stability... 😞
Is there a firmware update available for my MIB ? Thanks a lot in advance to all of you for your help !
Thank you everything is fine
All check your PMs
Recently Browsing 2
