Amundsen MIB2 Firmware Update
I don't know why they don't offer it on a download which you unzip to USB stick.
Afterall they allow you to do it for maps.
Unzip the file, insert the USB stick and press update, what's so difficult?
  • Replies 4.7k
  • Views 929.8k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
could you please have a look, if there is an update available for me?
MST2_EU_ PQ_P0138T
5L0 035 680
Thx
Hello @pab567. Do you have a newer version for my Amundsen? I'm trying to solve an issue with bluetooth connection dropping when streaming audio.
Thanks in advance.
Updating the maps is "safe" i.e. if it goes wrong the unit will still work.
Updating the firmware carries a risk of turning the unit into an expensive brick.
MST2_EU_ PQ_P0138T
5L0 035 680
Thx
Unfortunately I have no newer firmware for your unit.
All others pls check your PM.
Edited by pab567
Hello,
Can I get an update for Amundsen to PM :)?
Current version is:
<a href="https://ibb.co/G5qNjjq"><img src="https://i.ibb.co/W2Lj11L/20200518-075527.jpg" alt="20200518-075527" border="0"></a>
Maybe this is better. Sorry for previous post.
PM
Thanks ;)
Hi,
could you take a look if there is a newer version for this one?
Thank you!
That's a poorly designed upgrade process.
True, but in over 40years developing hardware and software I never came across a flawless upgrade process - for example I currently have a Windows 10 tablet that is stuck in a permanent reboot loop after a failed upgrade, getting out of it requires a keyboard and a USB stick to be inserted into the only USB socket (hubs not supported).
I have Karoq with following Amundsen:
Can you provide me with latest 0478 firmware, please? Or point out to where to find/ask Karoq version of it (no FE thread in Karoq section and no-one knows of it)? (I don't know if there are specific vers per car model or it is the same for Karoq as for Octavia and rest)
Hello @pab567 do you have an update for this thanks
Check your PMs.
36 minutes ago, pab567 said:
Check your PMs.
On 08/05/2020 at 08:40, Sava159 said:
I successfully updated my Amundsen thanks to pab567.
The only difference I see is the that the temperature font in the upper right corner is slightly bigger since it was pretty tiny before.
It would be good if someone notices anything else so we can make a list of changes.
Hi how long did it take to do thanks and was it easy
My Amundsen unit version is:
Device Part Number: 5L0035680C
Hardware: H22
Software: 0245
Navigation Database: 5L0051236BJ
1310
ECE AS 2020
I have been having issues where part of the touchscreen is not responsive, where the screen is seemingly registering presses at several points with no user input and also losing the auto turn screen off setting. I'm hoping to try updating the firmware of the unit before changing the screen. @pab567 please can you advise if there is any newer firmware for my unit and send me a link to it? If you include your email address, I'll paypal you some beer money :)
Thanks,
Jon
Hi Guys !
Can you help me with an update firmware for my Octavia 3 Amundsen?
Device part number : 5Q0035874A
Hardware: H24
Software : 0241
Navigation Database
5L0051236BA
1115
ECE AS 19/20
Thank you in advance.
Hi Pab567,
I Change my  RNS510 with Mib std2 PQ Nav
In MY Skoda Superb2
Problem is that No Audio Output and Steering wheel dsnt Work.
Do i need to Change Something with VCDS?
Or need Something else
Hi guys,
could you please check if there is an update available for my Amundsen?
Thanks!
@JonnyFun I sent you download link via PM but according to my experience SW upgrade will NOT help in your case - this is rtaher HW issue, front panel is faulty and requires exchange.
@Dasi75 what is modle number and SW version of your MIB STD2 PQ unit?
All others - check you PMs for dwonload link
Hi All,
This is all the information I know about my system.
Software MST2_EU_SK_ZR_P0478T
Device part No 565035874
Hardware H41
Software 0478
Navigation database  5L0051236BJ (GEN2 MIB2)
1310
ECE AS 2020
Shield: Shield 2016-44-(Build 309)
Media code 4101.0.0.0
Bluetooth Ver C300
Smartlink 4101.438.1.5
Radio database ver 1.10.10
USB surfstick ver 4101.438.1.5
Thanks for your help.
Thanks again @pab567. I'll still apply the update (I'm waiting to get a suitable trickle charger before attempting) as I want to try to solve the issue of the unit losing its setting (screen auto off) and the screen additionally selecting other channels (may be linked to child / damp from other posts).
I've seen the links to the replacement screens on another post and that will be my next port of call.
No need for charger - update can be done with ignition off and takes approx. 20 minutes.
As I already wrote: I don't expect SW update to solve your issue.
Beside the screen you currenlty have you can also use 5E0919606, 5E0919605M, 5E0919605N (trhis one has no NAVI button so you enter navigation from screen touch menu).
