Amundsen MIB2 Firmware Update
Hello pab567.
So today I finally updated my skoda unit H30 from 0367 to 0478 and friend's seat unit H24 from 0245 to 0515. It was long way, but finally it's done. Thanks.
  • Replies 4.7k
  • Views 897.4k
wlado93 wrote he succesfully updated H24 0245 to 0515. Not sure if I'm right but I have Bolero 5Q0035840A hardware H25 software 0252 (updated almost 2 years ago from 0245). Would 0515 work in my hardware? IF so any changes or differences comparing to 0252?
@msemafor 515 is for SEAT only, for SKODA is latest 0478 or 0479. From 02xx to 04xx you have to patch unit.
Amundsen is Bolero with navigation, so FW is the same I think. But on Bolero is this process complicated, because you cannot use SD to patch unit.
Wow, I can't see button to edit post... Is possible that there is no button ?
@msemafor And changes are new grid menu and some animations. Probably coding, but I not tested yet. And as was written here, new 478 version support virtual cockpit, if you would liked  to do retrofit.
You can only edit a post within the first 60 minutes unless you have one of the Freedom membership upgrades. :thumbup:
I've the following in my 2017 Seat Leon FR - do these updates also work on these? Android Auto has been playing up since i got the car (on various phones) and the dealer are blaming the phones/cables!?
Device part number: 5QA035858B
Hardware: H41
Software: 0468
Many thanks!
Hi Moppa I have from pab567 for my Leon MY18 but my multimedia is H41 product number 5qa035858b latest version 479T.  If pab567 confirms that it works for you, I can send it.
That's great, thank you 👍
All check your PMs - if you have no message that means I have no newer version for your unit.
Is there any where you can read about the update?
I saw somewhere that the ambilight gets more colors? Is that correct?
@pab567 your a busy person ;) can I ask the same, is there an update? Been having a lot of BT issues but that may be my phone...
Brilliant, thanks @pab567
Thanks mate!
@RichBrown what you have is the most recent sw I know...
Hi pab567 and All,
Would you be able to tell me if there's an upgrade available for my system please?
Missing NAV is because I've took my sdcard for update.
Thanks in advance.
Thanks!
Hello,
I am new in here.
I own a Skoda Octavia SEL 17 plate facelift. My system have touchscreen. I don't know where to check what kind of Amundsen I have. I believe its MIB2 by reading the comments in here and comparing with what I have. It there any Update for it please? I took a photo of the system info.
Hi there,
maybe this is the right place for my problem:
I am wondering two things:
1. Where can I get a firmware update for my Amundsen system?
2. Can I activate the Smartlink feature somehow?
Thanks in advance and best regards
Olli
Hello
First off, thank you for your work with replying to everyone here.
Second; can you see if there is a update for my system?
Device number: 5Q0035874C
Hardware: H41
Software: 0475
Navigation database: 5L0051236BR
1430
ECE AS 20/21
Shield: Shield 2016-44 (build 309)
Thank you in advanced
7 minutes ago, DonJayDk said:
Hello
Hardware: H41
Software: 0475
1430
ECE AS 20/21
As I know I have the same one and there should be 0478 available. Let’s see what pab has to say
Hi, can I update my Amundsen ? Thanks
Hello pab567 and everybody.  Could I ask You for a newer soft for my radio?  Thanks in advance
Hello,
I have a lot of Bluetooth issues, so hopely someone can help me with a update of Amundsen.
Part No. 5Q0035874C
Hardware H41
Software 0456
Bluetooth Version C200
Lets sit here and talk about Skoda until he comes back ;)
Hello Pab567,
Sorry to add to an already busy thread, if you get the opportunity to check my version (Late 2018 Karoq) I would be very grateful. (sorry about the dusty bits, you don't realise how dusty it is until you take a picture in the sunlight !).
Thank you for your time..
