Amundsen MIB2 Firmware Update
1 minute ago, PvD said:
Good afternoon all!
To my ''limited'' knowledge, this is still the most recent firmware version for my system, right? And no plug and play solution for going from 03 to 04 versions, right?
Thanks in advance @pab567 and @varooom
Correct 0369 is latest in the 03xx series.
  • Replies 4.7k
  • Views 906k
Indeed, it is
Thanks!!!!
14 minutes ago, pab567 said:
Indeed, it is
Thanks!
15 hours ago, VenomVrs said:
Hi!
Can someone help me with new update?
I have checked again my millions of files, and this is the available update for your unit.
S00.1000.17.99
release = "MHIG_EU_SK_K1552"
MUVersion = "0411"
S00.1000.17.99
MUVersion = "0411"
Is there a place where i can download it? :)
Also will it change anything or will my headunit be just up do date like updates for phones?
Big thanks to you varooom!
I can send a link via private message.  It should be bug fixes, sadly no change log is ever provided.
Hallo everyone,
I'm new here, there is a way to have last firmeare for my Octavia SW Mib 2?
H41 ver. 0472
Merci beaucoup
Domengo
2 hours ago, Domengo said:
Hallo everyone,
H41 ver. 0472
Merci beaucoup
Domengo
You should hold down your Menu/Setup key for a few moments to enter the hidden menu, it will show a Software Train, and it also has the firmware update button.
Try to report back this value.
Any update for mine?
@varooom
Done, thanks
43 minutes ago, Antimus said:
@varooom
Done, thanks
You shall have a link in under 5 minutes, I was outside scanning a Passat B5.5 (shed with wheels)
Hi, I'm not sure if my device is MIB2 but is there any update available? Thank you!
I don't think there is for that Software Train
can i request an update for this radio?
MEN2_EU_SKGPx_P0080L_MU8755.7z
This is a available, will be able to send a link in 5-10mins
Mine worked great thanks @varooom
Toto je k dispozici, bude možné odeslat odkaz za 5-10 minut
Thank you
Yes to 0480, taking a coffee here, will try to send link over in a few minutes.
is there an Update for MST2_EU_SE_ZR_P0359T?
Thank you
4 minutes ago, Houdini said:
Thank you
Nope
Do you have a newer firmware for my Karoq:
4 minutes ago, RoyOps said:
0480 is available, I can send PM with link soon
Thanks, download worked.
