Amundsen MIB2 Firmware Update
1 minute ago, manu73 said:
I tried with sd card and pendrive and it doesn't detect anything, any solution?
Is the format FAT32. Maybe the SD Card is too lage, try a 8GB one.
  • Replies 4.7k
  • Views 897.7k
Use a windows computer or some of the many 'clean my drive' style apps that exist on macOS..
On 17/10/2022 at 10:21, manu73 said:
Checking also you are using this screen to perform the update?
Next is for you to use a Windows PC (friend or family)
I have done it with Windows PC and nothing does not detect pendribe??
USB I have never found anyone who has made it work with MIB1 to MIB2.5
Try once more with SD Card, and you should get it to work.
of 32gb??
4 minutes ago, manu73 said:
of 32gb??
At least 4GB (as far as I remember)
So 4, 8, 16 or 32GB will be fine.
send me download link boi try last time
Hi, could anyone tell me if there is an update available for this? And can i install and run maps on my Navigation?
Sent another link
You should press and hold down your menu/setup button for about 10 seconds or less to enter the engineering menu with the Software Train value in.
Also take a picture of the front of the screen with buttons, if you don't have a NAV key, then odds are no you cannot load maps.
I have NAV key
1 minute ago, Pitu said:
I have NAV key
Very good, you can update firmware to 0253
As for maps, you may need it activated, but you will need to get a Skoda map card as they have an ID embedded that the car has to read, or it will not allow maps to load.  You can pickup these cards on market websites for not too much money.
I didn't get a link
7 minutes ago, manu73 said:
I didn't get a link
You did, it's still in your private messages from 2 hours ago, unread.
I updated the firmware and now the nav is not working..I have the original sd card but the nav won`t start
I updated from 241 to 253555792987_ImmagineWhatsApp2022-10-20ore14_40_21.thumb.jpg.339bd775a638a1f53a22e5c1e24d9bd4.jpg
You should post or translate exactly what you see on the screen when you try to load navigation.
3.thumb.jpg.c492dd51b431e464471f5177b0868065.jpg2.thumb.jpg.ea76d86384ce324f7b29ec92a3767b35.jpg1.thumb.jpg.362a24b1e6433c3d200a8e0d5db1a467.jpg
Might be wise to format and download a copy of the maps again.
Did you update firmware with map card in the car?
no, i used another sd card and i put it on sd1 where usually the maps sd is. ok I will try to format the sd and since i`m there.. i`ll put the newest maps.  hope will work. what is new in this firmware version? or is just faster? Thanks again
Good luck with that.
There's no changelog with a firmware, we can only guess as to what they fix.
Hello guys,
is there any updates for my car ?
Thanks a lot for the work !
23 minutes ago, Willow971 said:
Hello guys,
Press and hold Menu button to bring up engineering menu with Software Train information.
it worked now after formating. Thanks again GBU
Here they are
