Amundsen MIB2 Firmware Update
  • Replies 4.6k
  • Views 776.5k
2 minutes ago, banderboy said:
That is the correct file, you need to take a picture of the SD Card when made.
All the files should be in the 'root' of the drive if that makes sense?
57 minutes ago, Rogoscok said:
Hi
can i request an update for this system?
Taking this opportunity, could someone please share a thread on hacking MID2 system. I would like to upload codes that activate hidden functions, such as Smartlink
There's update to 0253 version, I need to go shopping now.
@pab567Are you able to assist this member with update?
@Rogoscok I am back, so will send you the firmware via PM
Meanwhile to hopefully answer your question a little, you need to enable developer menu in radio with something like VCDS.
You then need to install MIB Toolkit, remembering to change the 'CPU' folder so that you don't break it.
Then you can operate the MIB Toolkit from the developer menu to adjust things.
That's about as much help as I can send you, as this is not the forum for these things.
It's worked
Thanks alot
Hi
Thank you
Hello,
Do you have update for
My skoda Octavia 2018 1.4 tsi
Actual version : mst2_eu_sk_zr_p0472t
Hi! Is there any update to my mib?
I got my current SW in this thread some time ago.
I guess now the last version for my car would be 480T, right?
Can I have the link for the latest firmware, please?
Thank you so much for the updates!
15 minutes ago, contruk27 said:
You guessed correctly, 0480 is the latest version.
Will PM you a link now.
So fast! Thanks again!:)
Hello,
Is there a new update of firmware for my car? skoda octavia 2017 model, new facelift.
I was looking on mib-helper and its saying that there is 369.
If yes, can I have a download link please?
thank you!
1 hour ago, AlexeM said:
Hello,
thank you!
I will send you a PM very soon for 0369
Hi @all
is there a new firmware update for my Amundsen?
Partnumber: 5Q0035874C H41 0468
HeadUnit: 5E0919605M H50 8130
I have Connection Problems with my Android Phone.
Many Thanks.
43 minutes ago, Phantomias4711 said:
Hi @all
Many Thanks.
Odds are you can update to 0480
I will PM you a link and you can try.
On 17/11/2022 at 12:28, varooom said:
I can send you 0369, but ideally you should verify your Software Train information first.
Yours should be
MST2_EU_SK_ZR_P0359T
Available
MST2_EU_SK_ZR_P0369T
Sorry for delay!
Today i check the Software Train information (see below Picture).
What is the right update-file?
Thanks in advance,
ThomBrink
24 minutes ago, ThomBrink said:
Sorry for delay!
Thanks in advance,
ThomBrink
I cannot see an update for yours in my collection
MST2_EU_SK_ZR_P0369T is available, but you have
MST2_EU_SK_PQ_P0359T so the update won't load
@varooomHi.  Is there any new update for this?
Yes 0480 is available, I shall PM you a link across
@varooom Hi,
I have the following version installed on my 2017 Octavia
MST2_EU_SK_ZR_P0367T
MU version 0367
is anything later available please?
Just now, GaryBee said:
@varooom Hi,
MU version 0367
0369 is available, a tiny upgrade
Hello,
Is there any update for my SW unit ?!?
Thank you.!!!
