Amundsen MIB2 Firmware Update
7 minutes ago, Auzman said:
Hi, I'm looking for an update for the infotainment system on my Octavia MKIII (2019).
Attached to this post there's the screenshot took from the service menu.
Is it sufficient?
Thank you very much!
As above, there is 0480 version.
Check private messages in a few moments time.
  • Replies 4.7k
  • Views 902k
@varooom, can you check if there is any update available for my system?
Much appreciate it :)
For sure, there is 0490 available.
I shall send by PM.
The download did not work
They only live for 24hrs
Hello
   Can somebody send me a download link for MST2_EU_SK_ZR_P0480T ?
Thanks in advance!
2 hours ago, T0nyJP said:
Hello
Thanks in advance!
Yes in a few minutes
Great, thanks!
New to the forum. Looking for link to MST2_SK_ZR_P0253T. Current version is 0245(H24) and has a few annoying hickups which hopefully an update might improve. @varooomScreen was cleaned meticulously before picture was taken 😊
I am glad to hear you cleaned the screen, it's a running joke.
0253 should be your update version available, will PM a link over in a few moment.
@varooom Worked perfectly 👍🏽 Update took <10 minutes.
Hi, is there  any update for my Superb available maybe?
Hardware H41, software 0478, part number 565035842
Thank you
Thank you
I suspect you can update to 0480, hold down your Menu/Setup key until you can enter the engineering menu (about 10 seconds) and you can find the Software Train information.
Post back your value.
Cannot edit my previous post, adding photo of next screen
You need 10 posts iirc before you can use the edit, and the edit function only works for 1hr after posting.  If you become a paid member of the forum, then afaik these limits on time do not apply.
I can send you a link to 0480, but it might be your unit has been hacked?
Maybe not you, but someone has perhaps "activated" Apple carplay or Android Auto, which is why your current Software Train appear blank.
Thank you!
As far as I know unit wasn't hacked. Only Skoda Dealer was connecting into the car in the past. Was bought brand new, AA and Car Play  were included as one of the options.
Should I expect 1555 / B201A DTC after upgrade? If yes, which interface will be better (for like one-time use, would like to avoid subscriptions for the whole year). I'm thinking about OBD eleven or carista. Currently I have only old K+CAN and KKL usb cables which re working only with very old VCDS versions
12 minutes ago, Bencjusz said:
Thank you!
The SVM check fault code won't affect the unit, it's stored when it cannot talk to mothership.
Ignore that and enjoy it when it's stored.
Hi All!
Is any update for this Columbus (Superb 2018) system?
Thanks in advance!
10 minutes ago, Ajsi said:
Hi All!
Thanks in advance!
Try and hold down your menu button for 10 seconds to enter engineering menu, look around in those menu's to see if you can find anything mentioning Software Train.
Post back images if you do locate something.
Thx Varooom for quick answer.
Hello @varooom is there any update above this MOI3_RW_SKMQB_P30603P ?
Thanks !
Thanks !
Not at the moment, maybe try in 3 months.
Thanks !
