Amundsen MIB2 Firmware Update
20 minutes ago, Rachetz32 said:
Hello ,i install the update but are not all installed ,you know why ?I will try again with sd card ,last time i instaled them from usb ,maybe for that are not instaled all of them !
Are any on your list with Y in the entry?
  • Replies 4.7k
  • Views 942.8k
3 minutes ago, Rachetz32 said:
Ah I see the error in your last picture.
Move that compressed file out of the USB stick.
The take all the files and folders you see listed, and place all into the ROOT of the USB drive, they should not be inside the folder Update Firmware Skoda Superb.
So once your have moved these files and the single metainfo2 text file into the root, you need to delete that folder.
I will try one more time tommorow ,i hope is work ,i will downloaded again the update ,maybe i didn't do corectly!
The download link will probably be expired by tomorrow.
Format the drive
Extract files onto the "root" of the drive only.
Good morning,
Is there available any update for the attached software? Also I couldn't update the navigation card. Thank you!
inbound4363219847102775984.heic
2 hours ago, Costelo0 said:
Good morning,
Update to 0369 is available, I will send a link via PM
Maps updates here (only work on a Skoda/VW/SEAT approved card)
@varooom
can you also check if there is any update available for this unit? Much appreciate it! /cdn-cgi/mirage/08561a9d30d699558c8a7a6c554b1bde87955b65fe82f7d9949597a37d7f1177/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
9 minutes ago, PaulM07 said:
@varooom
Yes, I can send you an update in a few minutes.
Hello there. I have issue with my MIB2 STD clock showing 0:00 and found out that i need software update to fix the problem, is there anyone could help me getting newer software? My head unit is this:
/cdn-cgi/mirage/ca74ccc0c958c90dcfb1f2893c53ba68e43e63c06f0ba81c9f9acb2c1959ac8e/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/4CCB50A7-A0A4-48D2-924E-536F2DE221B0.thumb.jpeg.458ce3040eb4c4b03ecba1aad21040cf.jpeg
Yes I can send in about 30 minutes as I need to package it.
Thank you very much. I hope that it will fix my problem 🙏
@varooom My head unit has EEPROM patch install which restores EEPROM data to original state so i can use it about 8 hours until CP activates then after restart i again have about 8 hours. Do you know is updating will break my patch?
It will either block the firmware update from being installed this patch, or the update will erase your patch.
So best decide if you wish to hack unit, though MIB Toolbox exists to assist (if the firmware is on supported list)
Have you got Developer mode activated in the unit?
Is it already running MIB Toolbox or similar?
It is original firmware without any modification except that EEPROM patch.
I have developer menu activated.
Can you enter the GEM (Green Engineering Menu) and show me a picture of what hack tool you are using.
Feel free to send by Private Message rather than pollute the forum.
Hi there,i have updated the maps with the latest ones,but is there a firmware update for the one i have ? Thank you !
Yes there is an update to 0480 that I can send via PM
@Kodass Your map version reads as "1910" and the latest are "2010"
Find link here...
Are there any updates available for my 2019 Octavia (with virtual cockpit)?
Thank you in advance!
35 minutes ago, Kaiserb_uk said:
I shall PM you a link
Is it possible to have wireless carplay? I know you can get a usb dongle that i had but wasn't very good. I saw somewhere on another forum a member coded it in.
Edited by mattft86
There's an update to 0480 firmware (no it doesn't add features, it's for bug fixes/stability)  What you seek is added in one of two ways, pay a dealer a fair whack of money to enable it, or hack it yourself for free to enable things already baked into the firmware.
Thanks for that. Do you know how i can do it myself or maybe point me in the right direction?
Edited by mattft86
I will PM you a link to the firmware, and let you know what's involved should you wish to try.
Recently Browsing 1
