Amundsen MIB2 Firmware Update
Hi, SmartLink/Android Auto has recently stopped working with my Pixel 7 Pro. The phone appears under 'Available devices' but then nothing happens. I'd like to try updating it as I gather it's quite old, can anyone help please?
  • Replies 4.7k
  • Views 901k
It's not too old, it can be updated to 0480.  I will fire over a PM in a few moments.
Hello @pab567
Could you please send me the latest update file for the following unit?
PN: 5Q0035864C
Hardware: H41
Software: 0475
NAVDB: 5L0051236BR
1030
ECE AS 2018/19
Sent via PM
There is no update for your unit, you already have the latest firmware.
1 minute ago, gabileata said:
ok thank you!
0480 was release 14th June 2021, and nothing since.
Maybe ask end of 2023
New to the brand..but already looking for upgrades.. 😬
Must be something better/newer to upload?
You can have update to 0480, sent via PM
Thanks, that's fast!
Will try it immediately 🤙🏻
Didn't encounter any problems.
Works like a charm! Great!
Any update for this? a LOT of thanks in advance! 😃🙏
Yes you can update to 0253 version
Hello!
Can someone please send me the latest update file for the following unit?
PN: 5Q0035864C
Hardware: H41
Software: 0468
NAVDB: 5L0051236P
0730
ECE1 2017
7 hours ago, DEOctaviaRS said:
Hello!
PN: 5Q0035864C
Hardware: H41
Software: 0468
NAVDB: 5L0051236P
0730
ECE1 2017
I have sent you a PM
Good morning!
Can anyone send me the latest update file for the following unit please?
Thank you so much
13 minutes ago, david09 said:
Good morning!
Thank you so much
Yes, I can send you 0480 version.
is there anymore update for the map or unit software?
It looks everything is not updating anymore.
Hi all,
im new to this form. Have just bought the Octavia 2019 1.0 and following system info is displayed.
@pab567or others could you let me know if there are any updates for my unit.
any thanks in advance
regards,
Paul
4 minutes ago, Dijkstra88 said:
Hi all,
regards,
Paul
30 minutes ago, Dijkstra88 said:
Hi all,
regards,
Paul
Press and hold down your Menu or Setup key for about 10 seconds to enter the engineering menu and try taking pictures again.
You are looking for Software Train if you can locate it.
Yes found this screen. Is it the correct one?
Yes, there is an update to 0480
Good could you assist how to update it😃. Many thanks in advance
regards,
Paul
regards,
Paul
I will send file by PM, and some destructions.
Go and find an SD Card and you will be fine.
Hello,
can I get the update file
IMG_0598.HEIC
