Amundsen MIB2 Firmware Update
Hi there. By any chance, is there any update for my Octavia 2014?
Tahnk you.
  • Replies 4.6k
  • Views 781k
Tahnk you.
Yes there is update to 0490 version
Would greatly appreciate an update and instructions please. Tia.
Thanks varooom for 480. Posting here in case it helps others. When upgr5ade attempted using SD card with exploded 480 I get:
Sorry, had a busy day and you fell through the cracks.
Will send you update to 0253.
On 20/06/2023 at 20:15, boardtc said:
Thanks varooom for 480. Posting here in case it helps others. When upgrade attempted using SD card with exploded 480 I get:
Does this mean mine can't be upgraded for some reason or any tips to get aorund this please?
Hi guys I updated to 480 thanks to varooom so far 2 little problems. When I connect my phone by Bluetooth it shows me no network signal but working without any problems.when I make a call it shows me signal, and when I finish it disappeared after couple minutes. Really strange. Second one more annoying is from time to time on dashboard i have message infotainment system switched off, when on .I just have to switch radio off than on and is fine but it  is annoying.
I think you should do a VCDS scan or similar tool
Have you tried to hold down the Menu button for 10 seconds to see what software train is already installed?
No errors when scanning vcds
Is that the whole car scan?
Yes , maybe there is a bug in software or something not sure
I will do again for incase I'll let you know
I have the factory version installed and then you gave me the latest appicable is my understanding.
Please, is this the latest version ?
On 15/06/2023 at 15:56, boardtc said:
Hi there! After driving Passats for 20 years I bought an Octavia yesterday!
I accessed the firnware info and it's not been updated since factory install. I found the update firmware instructions posted. The warnings about using an external power source are a little eye brow raising, I don't have anything like that, but was planning on doing after a decent drive.
I found the latest, MST2_EU_SK_ZR_P0480T.7Z, at EU - MIB Solution. 3.6 GB DL is challening over http, is there fto access anywhere to DL perhaps?
Feel free to direct me to a FAQ (post) that may answer these noob questions.
Aha, this is your first post where you mentioned about trying to download 0480, without a screenshot if your existing Software Train.
So I supplied 0480, when you needed 0369 as seen from your latest posting.
I will send the correct firmware now, and you will be able to load.
28 minutes ago, jaydoo said:
Yes for 04xx versions
Thanks, And is there any difference in this, or for this radio is this the latest version?
Show a Software Train value
@varooom
The previous post was my. That is, if this is what I should have sent. But I understand already that I have the last version. Thank you very much.
1 hour ago, jaydoo said:
29 minutes ago, jaydoo said:
@varooom
MST2_EU_SK_ZR_P0480T is the current 04xx version.
Have a good day
I did another scan no errors at all
I'm out of ideas
I'm in a whole bunch of trouble guys, I hope someone can help?
I unzipped the provided download to my scard and started the upgrade process.
When I shut the car off the emergency screen is still showing, what do I do now? My battery will be killed.
The red emergency download screen says:
Device: cpuplus Module: cpuboot %1
Error occured: FileReadError no file
I am unable to press any of the bottom 3 buttons
You have errors on your media.
You need to get a new SD Card and try again.
The red emergency download screen is still showing, it won;t turn off. I can control switching between the button with the right knob and then get another red emergency download message: Error occurred. no suitable update found. Please insert valid update container". I put back in my brand new sdcard with 0369 exploded but it comes back to the first emergency download screen. It looks like I have lost the factory install system which had been working fine. I can get the system to turn off after the 2nd emergency download screen but then after 10 seconds in restarts and shows the first red emergency download screen. I don;t know how long that will show before my battery is dead.
I just bought this sd card. How can I get the system to turn off?
2 things
Start engine, run 2-3mins to put back more than enough charge
Then whilst doing this, find fuse to pull for radio.
