Amundsen MIB2 Firmware Update
Hey
I recently got an Octavia mk3 facelifted and I am looking for if there is a FW update
348354573_627956799038878_5429748744244623762_n.jpg.68b3c8cfc8b6cf6bce51f7c0252ff1e0.jpg
  • Replies 4.7k
  • Views 898.8k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
9 minutes ago, wondershroom said:
Hey
That's a small picture, but I will send you 0480 version
Sorry new, larger pic36144722_348354573_627956799038878_5429748744244623762_n(1).thumb.jpg.7cca26da0919e42173b68701bbf4a635.jpg
Hi together,
I have a Superb III with a MIB STD2 unit at SW version 0363.
Is this unit updatable to the version 0480, you mentioned in the posts before?
Thanks and best regards,
sqeezer
9 hours ago, sqeezer said:
Hi together,
sqeezer
Officially no, you can update to 0369 version.
Some will force 0480 onto them, but no idea of future stability.  And a few small errors do exist, so I never recommend it at all.
Hello. On my Octavia, the version is MST2_EU_SK_ZR_P0253T. Is this the newest version? Even so, can you provide me with the most up-to-date version?
Because even in cold weather, it turns off due to the temperature warning. Can I get around the problem by reinstalling the software?
*****@*****.tld
*****@*****.tld
You have current version, but you won't be able to re-install if you do not have ability to adjust system and place it into Developer mode.
Even then not sure if it will allow you to operate.
Hey, just picked up a 2013 Skoda Octavia SE TDI 140 model today and just wondering if there is a software update available?
If so what would it add/change?PXL_20230524_183536781_MP.thumb.jpg.5506349782a69ebe375f973f37cf5b82.jpg
There is an update to 0490 version, and I think it will add +83.
They don't give changelogs with firmware updates directly, so you have to read TPI documents for vague clues.
Thanks for replying so quickly I really appreciate it :)
What do you mean it will add +83? Is it something I can download on here?
I'm new here as I only got the car today so is it easy to install?
Thanks varooom for your fast respons to my question! What is the difference between 0363 and 0369? Do you know it? Only stability and fixtures or any new add-ones / options / features?
sqeezer
0490 - 0407 = 83 (a bad joke was made!)
Easy to install, and take 20-40 mins roughly.
sqeezer
That would be 6, anyhow jokes aside there is no changelog provided, so mainly stability and bug fixes are what are applied... usually you don't get new added features with update.
1 hour ago, Umrelllaski said:
MIB1 System, and I will send you link & instructions in a few moments.
Thank you dude, you are the best! ❤️
I've bought meself a new used Skoda Octavia 2018 and am looking to update it where ever possible.
@varooom would you mind sending me the appropriate firmware update as you did previously? Thanks a lot
I can send along 0480 version
Thank you. That was at the speed of light :)
Hello, It is possible to update this unit?
Sometimes I have problems with Smart link, infotainment is freezing, I must restart whole infotainment.
Tank you very much.
Tank you very much.
I have sent you an update to 0480 version to try and stabilise system.
But this could be a cable/phone/unit problem.
Could I kindly also ask for a software update please? Amundsen in Skoda Superb M3
20230529_163034.thumb.jpg.ab7151f69125c3694e24e3f60c8cdcfc.jpg20230529_163034.thumb.jpg.ab7151f69125c3694e24e3f60c8cdcfc.jpg
9 hours ago, varooom said:
V-am trimis o actualizare la versiunea 0480 pentru a încerca să stabilizați sistemul.
Dar aceasta ar putea fi o problemă cu cablu/telefon/unitate.
Salutare tuturor....
As vrea si o actualizare va rog....
Doar daca este posibilă actualizarea
18 minutes ago, varooom said:
@tartanthingVă voi trimite actualizarea la 0253
@adrianferaruVă rugăm să puneți întrebarea în engleză
Hi....is it possible to update this unit?
Just now, adrianferaru said:
Bună... este posibil să actualizezi această unitate?
Only if the update is possible....thank you in advance
