Amundsen MIB2 Firmware Update
Pls post your unit part number and current SW version.
  • Replies 4.7k
  • Views 898k
It's true, sorry.
PM
I'm hoping to solve frequently slow start up, is there an update for this version please?
Can you please check if there is a new version for
Device Partnumber: 5Q0035864C
Hardware: H41
Software: 0475
Thanks.
Hi, can you share latest update for me?
Is there an update for me?
Would be great if I could get a software update as well:
Device ID: 5Q0035874C
Hardware: H41
Software: 0475
Navigation: 5L0051236AH
1030
ECE 2018/19
Shield: Shield 2016-44 (build 309)
Can someone tell me exactly how to update the firmware? Is there a documented process anywhere? What I'm after is someone who has done one before. I have got a 16GB SD card that I've formatted to FAT32 and I know I need to move the update files on to that but what I don't know is if I have to unzip the file or not? I'm going from P0245 to P0253 I'd also like to read the release notes for P0253 so I can find out what was fixed vs P0245.
19 hours ago, Kirky2k2 said:
¿Alguien puede decirme exactamente cómo actualizar el firmware? ¿Hay algún proceso documentado en alguna parte? Lo que busco es alguien que haya hecho uno antes. Tengo una tarjeta SD de 16 GB que he formateado a FAT32 y sé que necesito mover los archivos de actualización a eso, pero lo que no sé es si tengo que hacerlo descomprimir el archivo o no? Voy de P0245 a P0253 También me gustaría leer las notas de la versión para P0253 para poder averiguar qué se solucionó frente a P0245.
Hello, I did it, I saw videos, I read in forums and I did it by myself. Car stopped, insert the sd card, press menu, look for the sd and update. 10 minutes maximum.
Most important: Push the Menu Button for like 10 seconds and extract the content of the zip in the root of the sd card.
Do you have something new for 5q0035874a  ?  Thank you!!
Can anybody help with the update for my system, details below:
Spoiler
Can anyone help with information on any update available for my device pleaase....
Device part number: 5Q0035874C
Hardware: H41
Software: 0472
Thanks in advance
@pab567 - Can you please PM me the latest software version for the following?
Software Train Version: MST2_EU_SK_ZR_P0475T
Part Number: 5Q0035864C
I found version MST2_EU_SK_ZR_P0480T.7z on this site. Is it the latest? And is it safe to use?
All check your PMs.
Spoiler
12 minutes ago, pab567 said:
All check your PMs.
Thank you
On 06/06/2023 at 23:07, varooom said:
Sadly you know the dealers are lying to you, it should in stages be able to update to 0324 (eventually)
But in upgrading from such an old version, it will erase your Sat nav licence iirc.
Took a few visits and allot of repeating myself to look up the TPI but they finally updated it to 324.
Just Android Auto not working wirelessly yet.
Hello, Is there an update for this?
I am having a big issue where AA was working just fine - then out of the blue it now requires a key, wont connect to nav or bluetooth. I am hoping an update will resolve.
Hi pab567,
Please can you provide the latest software update available for my device?
Device Part Number: 5Q0035874C
Hardware: H41
Software: 0472
Navigationsdatenbank: V03959820F1910
ECEDL3 2023
SHIELD: SHIELD 2016-44(build 309)
Thanks in advance!
Hello,
Does anyone have MST2_EU_SK_PQ_3xxT
Any version. I have in Amundsen MST2_EU_SK_PQ_253T
I would like to go higher to 3xx software.
I have also Bolero with MST2_EU_SK_PQ_353T
It is possible to extract it and install to Amundsen?
Can you help with the update for my system  please
Im gonna jump on the bandwagon aswell and ask if there's an update available for my skoda fabia? And does anyone know if my hardware supports navigation?:d Much appreciated
AIL4fc-T8ANg1vrSbdYFPVk8krxZ2_AHy5m0ok6xRYAvSI41oIwkrzQl0fEs2gj2YexLn6T7kTNKHQNiHO98HqciJI0xSpp_p6Ul7fCCjTBU83y-rjTw1OqYgWP8T-ePOS7qy1dRyv6WB8tsqD2JdBeDCVWRyxUTgPbHt2EnuxE4ioysLIpHm0jqdndAqNeMLHy4H6fkADAPb3z89-VYEsj7xUsSNDdzkFzcYoDxcHPaPxWxDRXfDzg3DrhfHNPSW6S3IuCxBozyuE45L3OwuZCI84lz0NPDnYMrlZEHlkPCe3h9C4bXcb1wmRoIBOQ23E6q0hXniYqunbKGyI6JiwjL0rRRUzlkzHGGQTj7-2truLADQlrB60YoikCAlmRuogj43D08tjxYCxPmsnSp_2RAIiZbo881VHkg1JT4CPs9z2yLBX5I4q-BxEZBEiA5htem7DToRUW7-smaKNFpPa9gJ9zGKWoK5thPypOttRcRb3CcMRP7q9aceasl2OGWQccVsRUp04cTqANIIC8O4ETDbRG-iB9d7qH3EqmC9uo3_n2ttV3CWbGwhxjfdDAulN6VOq7P1QAEjxOIqbcKscxwzyeJWbhyAJGUeCv87s0fucyKAZnJp2XkHNJXImyUx2WPWdlvlANSIoj_x7_LpsUQHiOu9PmJY9WR8HyBfPwysNye-0b79asF8Cg0aKK6sXsIwHCGhFqJ0MfEagx-NOilTtDUbKlXQBq6iQ9nNLrf-S1MXS-ovxJdYSj958Xzqz6z5H--xMcI2oRZWq4NmCREfVLQwxKcWFLCKYmmpM9PWOw8MXr2fFLg3V5ZVCEKNToMNrTrYNq9EPfzpRbG_dcOHUDRo30KH5PW3vrAXWc4Yd5S5PMPh1rPaSa8ZeWzIlEjeTcPnsaziXLhjzfYMUlOYn6L214=w1421-h931-s-no?authuser=0 AIL4fc9jKMSE_QOqwO5VYu6jQd_0P6wkzYs52J13w0DeAj0LS1AVPH0BMrHfsTNcgC9Htndpp1sLhCLj1EgjmmWGtzg7mE2xd7WlDpoqAUyTqGavPlWQ10h8QAwF4cBv50hYxe1wLfVWHoory8xtJEWYLin0RURAEZDeTyu7oT8bYCSIojW_ZylML1SGpypDQijirQtrpi6TuKusFR-XWEM7F5LcVa_QjIOQIBNRhh_sj4OPxyJWJAwomCsEZbZTPcUT6uhbEkxR5JeRiHCqMzirJRnc9NXviCaYNkR_XdZZISRwrom0GSv7BnGb0rz5o0Rd962L8Zc_kvOCTHR5k1vF65SU7Dullh8bvaqWWCnnZ5clhlt4y4lHoZpQBRYKXLx3ObxWBZmk7uDjrKbWueXskj4NJdniX2M16MHQp0HmacDaRaLXlag4A6n6fp6JdDFRxGOdVog4Gadd-x23wRWTtG3S7Tntu9LYZf_3Vi3Ho_tbC_nW8gV3vqXDtJhVser8_eS5VAOvavAfFxPfJ-oP5YRkXCTK3-ESATFWBpK0Wso8piGy2LpvxvB_y-G6wFgj_TdTSMEM9K1JhgDTU2G29SkqwUCv-UU-RgZbCLFkxs_eLiuPuXZKm3V43txto8dQ6bbdWSrWmf3Jhljxr29SjUFbxoTb7NdZ4YMwOuiosZ0c9dpUisWIVSRY34LVPGJ-nPfkWqatEfOoqSH0tGx56YIS16sMnJvaURYULn-HcwSPfbB1g8IFIEMEI748XU9YtClzRGHMAQeucJ-J9naHaSxE9APRmoLuXRGpuyWsy81wQ8AddGNxK2UI0xZnvuZlmUYFIC_k0pjtxCbEyh9f_cosFJNxsScxTna6DQbQfaxchKOAdp_XQ_wxYTfYY5FrIygjPvr3u9pxFc4_zXLo-oyDU84=w1597-h931-s-no?authuser=0
Hi all
  • Can somebody let me know if there is a possibility to have firmware available with this hardware ? I meant to read that the newest version is 254 for this hardware, is this correct ? Where is this available ?
  • Also is it possible to activate Android Auto (and/or MirrorLink) by myself ? I have a working HEX-V2 CAN bus and did a little tweaks but don't know if it's possible to activate.
Thanks in advance.
AIL4fc_t_srMPG6xJqMfBiQPtLc41BwHOBlKTc6Y2_lwlrxPLqHDpTF6K3dWpKa1LqSv3MZkpE7WN5eU4IhkUlBh4fMPYWgqc-LAS-r49G4qVCp3nv7Nv5XFgynrxjb0PYmIDJOBn9OJ-AJgfkrE4r_b8pFTzLhw5WD6OtuFfnn38uwmuTdNBp0xunU5vAJC9wXyEZq3hXEgu-pi57sVbKdX9FIhthKxdDizV7tkcHJsVM0qt-96gv4ZUBDcp4NdoUlJwN1JDZX0v49sq43fLYjksLbwHCP-xeyAlekxAtNA1pqxr5rTFC8m7UZPOy5sM5Urx5m8440nbx_FmfS9VV86m8EQVq4muuwdTaRollEIsxWLKHz53S0bNE2WxHolr26xw2-jFgIvFpnJ8Shy4nOoPzNfpuem_m8Wzcs7KJdv2PXbP_jy6LiqCXNgfr02DVMpBKPFCQd8ZyxeenLInILYZdHpzGJ5EDe5Xm3Ay5zICLTdO1wK7flkvwEWZ2tCAyrXcNbn-J4Hck5lz0eXi82JEzOyAwgWpYofZ7SPiJ34Fdd2VAUCr6CKUa0ovncHFwen0Wo6uS9x2zFQYoRM1UbFzYRaZkzUy6PeGxEh-xqTicwsEApJsnhl3Li3V2wqX6zOhMRYOiIIZfHhFMtmPNTqADlLYFoTlt_awc2Pl09y683i_NnGHXqWSHVAWB7M3rjQleqka-hUBQnxtGH6gFi1LYbTlKhoyc3Wm0Yb1kCYVcKAwww3K-ai2Nm5iNYpTxu_oDvySuzbmSR_wdebSBPX72cOqawoCM1zFlOwkbM-iVTKWTp4sw02PsHWMyYBmyJ_rKBYv4SX6eJ-UtRD_guL_cx02AGeh0qb9h6DehZtVYelJSwQ-q0Rf5vmJDllkur06hXi5v-pfydsqfr37efirP3UZvz2pqGssiZbXQvPvLqFDfUKrdNvBpWGZF5kaEsP=w692-h923-s-no?authuser=0
AIL4fc_osx6nXLaDZwnr5zpCePtroYpk4h0VVYY-Utd6ClobrxCt9eI5j8SWN7JkmNsYtt1laH662bSd22YfQ8KhKEY0scmTYnGzRPxVGZXE5REnEz0z8xjsw5SJBeEKUTqBKgVr8yOUGWBHJ3ISVkRQUY7ukWlzBbs-QpqFmULpESNtUDOpLZvNU_x7rwpKfxyzfoepLP00b5wkjj4F5NMBXyZqI4DcM6IFL6fq5P8bLXvy3SZ6rdkmTGwVFDx298NQxanxjYKMK7Ks2WLgflJYp5j2rOqDwsQ7A77xEzHL-V1CE14BN8hJ0F74khEJDiXgfxit9WmfoEiec1Nw_RnaxHjnOiy5K9d9B06IqPu2YzYx4eSx9nh4mAUwoopBcpjdCu7O79_o5vU5-NjoJ9fDRC0GKdI2CJrBgx_fj2X8PxEFMP7GOUGYmTwq7JXVI3pR9BxAhcQovpXTzTGoScCcnjSrR3xPqY7vyailhNlA4MF2mhbZmoLw5S5OdY4pnpB71kit5CGxyGvvhVHC9B4VNEl303pPp8YkQy_c9zGlhno_vhXtL1RL1RbrguK5JBgU4AUbN77OLvbofzC39b5oza-gj9u8-diJYoww555Lx6r3kSapyjPinJrQ-r7AKjQqk_51uN_gvp7ncDjqBY3eDiptHvkEhFvYyrynCZKlRzkieUkgJn9GqQ64EmlFhVWAHgAAKCjLbXoPJLClPuabBkzm1lCUohM_NVPfLVO0fhe7COjNLACQHnfIcPa6z9g1TvIXHRpeUfXoUhGMRpl6o5wHCC51i44c0Le-bPAaXDb__932gNNoraBWUeJJDnIZBBrjm7Qvd3_L3LfG07h8FHc7TLyQip2E6J8wCC-Sxc-rU0IThEgsd2LdGspha1HEwXrC6ZuPIxObGCnU27qu2M9DeqP4TVorD_9U6qvuV9gYkjvwtRpzQF2WCfbUC0I8=w692-h923-s-no?authuser=0
