Amundsen MIB2 Firmware Update
On 17/05/2025 at 16:48, pab567 said:
I sent you link to MST2_EU_VW_PQ_P0254T, just use it.
All pls check your PMs.
will you please send it to me aswell? the mibsolutionone site wont let me access the download file...
  • Replies 4.7k
  • Views 935.9k
What is your current SW version?
0240
Hello,
i just bought an used Kodiaq Sportline 2019, with the Bolero System i guess (No Navigation), and i have Canton sound System.
Is there any update available for my system ?
Thanks !
Is there an update available?
Hello everybody,
@pab567can you send me link for download latest version for MIB2 on my 2016 Octavia Scout?
I've already patched the unit and I've the green menu installed, it's a problem if I update the MIB?
I'm trying to activate Mirror link with OBD11 with VAG PRO plan that I've just purchased but I can't find a site with FEC code generator.
Thank you in advance for tour kind reply.
On 12/07/2025 at 11:25, kehansen said:
0240
Full train pls or picture
All check PMs
Hey everyone,
I'm looking for the latest FW for my skoda. According to https://mib-helper.com/ I'm looking for MST2_EU_SK_ZR_P0480T. I've tried downloading from his server but the download keeps timing out. Can anyone share this file maybe?
Thank you!
Matej
Hi @pab567 unfortunately I can’t update the MIB because “the current software download is too old”..
What can I do?
Thank you!
Have you patched your unit?
Yes, I have the green menu active
14 hours ago, molj said:
Hallo zusammen,
Ich suche die neueste Firmware für meinen Skoda. Laut https://mib-helper.com/ suche ich nach MST2_EU_SK_ZR_P0480T. Ich habe versucht, die Datei von seinem Server herunterzuladen, aber der Download läuft immer wieder ab. Kann jemand diese Datei vielleicht teilen?
Danke schön!
Matej
Password, send me an PM
https://mega.nz/#P!AgGWtzUFoIP4pguwu7Bh2bhWtG8XiisFKZVDNk8n3ZSTbcmIhTo6VEiYkN8TXsA1Rdgg9bZrDg7uZAIVtm6yKuo1kPk-MEShhLYpAN_grJHGH3-sIMnCGM1SY4KtOlkTuCVhsO1pnAs
@Cairus thank you but I can't send PMs yet as I'm a new member, can you message me please?
Edited by molj
Hi friends, could you send me the original MST2_EU_SK_ZR_P0245T firmware? I have P0253 installed and I can't activate anything, not even with the obdeleven or the green menu. I want to try to downgrade to 245. Thanks in advance.
Hi @pab567 please give me some advice: I have MIB2 5Q0035864A on a 2016 Octavia Scout. I updated to FW MST2_EU_SK_ZR_P0253T, patched with GEM 4.11 and installed Toolbox v1.4.2, unlocked Smartlink and performance monitor with OBD11 but I can't update to any firmware version 03xx or 04xx.
I've read several guides but with all the available FWs I always get the error message "Can't use Update Container, The Current Software Download application is too old."
I would like to know if there's a way to prepare an SD card with the firmware that does everything or if I have to interact with Telnet to patch SWDL and other.
Thank you.
You have to patch swdownload. After patching it still may require to modify metainfo2.txt file.
Meta is To Change
Hi all
Looking to see if anyone can help me with the following firmware?
MTSD_EU_SK_P6230 MU:0490
Thanks in advance for any help!
21 minutes ago, Model500 said:
Hi all
It's the MIB 1 version I'm looking for
Hi there,
I have also issues with my Amundsen Radio. The touch display sometimes does not response. So I searched for a solution.
Is it true, that an firmware update solves this problem? What firmware do I need? Can someone please send me the files.
My current software is shown on the picture.
Thanks for helping
You need only the Screen from Touch, without LCD Screen
the remote also does'nt work. Only the volume knob at the amundsen and at the steering wheel responds. If I restart the radio it works qiet a while and suddenly the problem is back.
I've read that a update solves these problems.
Update Firmware To 0359
Can you please send me the Firmware.
Thanks a lot
