Amundsen MIB2 Firmware Update
@matbeva thank you, it's very nice of you :)
@MrHiggs1 I sent you download link in PM.
  • Replies 4.7k
  • Views 885.9k
Thank you so much @pab567 for sending me the update and all the information needed. Much appreciated.
I have version MST2_EU_SK_ZR_P0478T do you know I can download the latest soft 480T for my Skoda Kodiaq 2019? mibsolution.one not working :-(
@pab567 Thanks very much for your help. You are providing a fantastic service to everyone. Much appreciated.
Thank you :)
@ceper80 check your PM
Hello!! I'd like to update the radio in my 2018 Skoda Superb. I'm currently using version MST2_EU_SK_ZR_P0471T. I understand the latest version should be MST2_EU_SK_ZR_P0480T. Does anyone have it or can send it to me? mibsolution.one not working.... Thank you very much in advance. Best regards!
Edited by Miguelix
4 hours ago, pab567 said:
Thank you :)
Thank you ,very much!!
@Miguelix check your PM
Thanks! @pab567 any instructions on how to perform the update procedure?
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Hello guys, who can help me with MST2_EU_SK_ZR_P0480T, Unfortunately, mibsolution.one doesnt work
On 17/05/2025 at 16:48, pab567 said:
I sent you link to MST2_EU_VW_PQ_P0254T, just use it.
All pls check your PMs.
Hi Pab567, cna you send me this file?
Download link for MST2_EU_VW_PQ_P0254T sent in PM
I try to update MST2_EU_SK_ZR_P0245T to MST2_EU_SK_ZR_P0480T but i have error (cant use update container. the current Software download aplication is too old)
I also updated Toolbox, but i dont know which is next step. Who can help me with info..
Hi guys,
after updating multimedia software to newest MST2_EU_SK_ZR_P0245T to MST2_EU_SK_ZR_P0480T my VCDS found this fault:
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [00001001] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 192185 km
Date: 2025.10.24
Time: 10:29:51
Voltage terminal 30: 14.8 V
Status_Software_Version_Management-module_name:
Does anyone know what to do ?
8 minutes ago, IvanMaihaus said:
Hi guys,
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 192185 km
Date: 2025.10.24
Time: 10:29:51
Hello Ivan
How did you updated from MST2_EU_SK_ZR_P0245T to MST2_EU_SK_ZR_P0480T?
3 minutes ago, meeleniumeye said:
Hello Ivan
Hello ,
I updated from 0478T. Does it make any difference?
Hello,
After check informations with MIB-HELPER.COM it seems that a newer version of my software exists.
But...
MIBSOLUTION.ONE is down.
Can someone help me with a link to download the MST2_EU_SK_PQ_P0353T software ?
Thanks.
Christophe
You can Not Update direct To Firmware 353T
hello, can anyone share a link to download the MST2_EU_SK_ZR_P0480T ? In my existing archive obviously some files are missing, e.g. the metainfo2.txt.
Hello
Wonder if you can help with updating firmware for skoda yeti 2016 headunit
Device part number : 5L0035680C
Hardware: H22
Software : 0245
Navigation Database
5L0051236BH
0521
ECE 2016
Media Codec:
2101.0.0.10
Thank you in advance.
Hello guys, who can help me with MST2_EU_SK_ZR_P0480T, Unfortunately, mibsolution.one doesnt work. Thank you.
4 hours ago, ulli0824 said:
Hallo Leute, wer kann mir mit MST2_EU_SK_ZR_P0480T helfen? Leider funktioniert mibsolution.one nicht. Danke.
Was the website https://mibsolution.one/ actually banned?
Hi!
Is there an update available for my headunit? It's an Octavia Scout 2016 pre-FL.
Installed SW train version: MST2_EU_SK_ZR_P0359T
Installed SW MU version: 0359
Part number: 5Q0035840B
Software version: H28.28.133_STD2Plus_EU
Thanks in advance.
Hello,
the latest official firmware update for your headunit is: Latest official firmware update: MST2_EU_SK_ZR_P0369T.
You can check this yourself on the website: https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0359T.
Unfortunately, I can only help you with the information, as I don't have access to the firmware. The download website https://mibsolution.one/ has been closed.
Perhaps someone else here can help you download the firmware.
Best regards
