Amundsen MIB2 Firmware Update
On 29/10/2026 at 01:26, HBH96 said:
Hi everyone hoping to get some help with my mib unit I am having issues connecting to android auto
On
MST2_EU_SK_ZR_P0245T
5Q0035874A
I have tried everything I'm aware of so far and now I'm thinking it's got to be a software/firmware issue.
I've tried several different OEM cables and 5 different phones (iPhones and Android) I have replaced the usb port with " 5Q0 035 726 E " aswell as a new HSD cable from the head unit in the glovebox to the back of the USB I have also tried 3 different byte 19 codes and checked that android auto and is enabled in 5F module the usb has been set to "full" but after all of that I still cannot get any to be recognised it seems like the usb just isn't sending data I haven't had the car very long maby a month but I have yet to get smartlink to work Bluetooth seems ok however it does drop out from time to time and is around 15/20 seconds delayed I would really like to get Android auto working as I do a lot of motorway miles and I like being able to easily change music to podcasts ect.. if anyone can help or possibly point me in some other direction I would massively appreciate it 🙏
@pab567 hi mate I'm looking to update my system would you be able to point me in the right direction for this am I right in that I have to keep the new update on the 02**t or can I jump directly to the latest 0480t ? Thanks in advance for any help
  • Replies 4.7k
  • Views 942.2k
As I understand you have 5Q0035874A. You can jump directly to 0480 but first unit must be patched for swdownload and metainfo2.txt in 0480 firmware must be modified as well.
Hi everybody, can anyone help with MST2_EU_SK_ZR_P0253T firmware?
I can't find it anywhere..
Thanks!
2 hours ago, satomma said:
Thanks!
I can't find any help about enabling via SD GEM mode.
Any help about that?
Hola. Tengo un Bolero con la versión MST2_EU_SK_ZR_P0359T y me gustaría actualizar el firmware. Me podríais ayudar. ?? Muchas gracias.
Hello. I have a Bolero with version MST2_EU_SK_ZR_P0359T and I would like to update the firmware. Could you help me? Thank you very much
Please use the default language of english when posting to the forums. thank you, Briskoda admin team.
Hola. Alguna actualizacion para mi MST2_EU_SK_ZR_P0359T. Gracias de antemano.
The language of this forum is English please post only in English.
Hello,
Could you please help me to get the latest firmware of this Octavia 2015 infotainment?
Thx, Attila
the admin team has already asked that all posts are made in english.
Consider this an instruction to follow the forum rules you agreed to when you joined and use english or your account may end up being restricted.
there are several translation tools available on the internet, for free, including google translate which works very well even with car related technical language.
hello hope all is well does anyone have the following:
VW Polo 6C 3Q0035874A (MST2_EU_VW_ZR_P0241T) stuck in Emergency Download (Device: cpu Module: cpuboot%1 FileReadError). mibsolution.one is down and MIBVault's P0254T.7z is missing cpu/cpuboot_sec/12/default/Bootloader/init_mibstd2_cpu.dat (SHA1 ad9423fb38ff88c37e3521c58d161785c2ced62e). Can anyone share a working GDrive/MEGA link for MST2_EU_VW_ZR_P0253T.7z / P0252T.7z or that 45KB init_mibstd2_cpu.dat file?
currently stuck in red emergency download. i used this file (3.5gb)MST2_EU_VW_ZR_P0254T.7z
[21/11/2026 21:44] jessreadingx: https://mibsolution.one website is down and doesnt work also
@pab567
@varooom
All check your PMs
Hello, I am looking for firmware mst2_eu_sk_zr_p0253t and MST2_EU_SK_ZR_P0480T I now have MST2_EU_SK_ZR_P0241T (which also would be nice as backup) Thank you in advance
