Amundsen MIB2 Firmware Update
6 minutes ago, varooom said:
Yes, and benefit it a bigger number, 0421 --> 0490
Normally they fix bugs you may or may not be aware of, like system speed and Bluetooth stability etc
Where can I get the update?
Thanks!
1 hour ago, Joskodan said:
Dear @varooom,
I have the following system. Is there a software update available? Does it matter that it is in Swedish? I would very much appreciate if you could help me.
Regards
It doesn't matter that it's in Swedish (other than me not being able to read it)
The firmware is EU, so has languages for Europe.
Only a small bump to 0480 is available, will send via PM.
Many thanks!
17 minutes ago, Joco776 said:
Hi is there any update for this unit? Thank you in advance .
Press and hold down the Menu or Setup button for 10 seconds to enter the Engineering menu, locate page where Software Train is found (hopefully!)
16 minutes ago, Joco776 said:
I read that BOSE may not work after the update and it must be parameterized using VCP or ODIS. What is the truth?
I don't think the VAG would release an update that could break their own radios, could be wrong.
I can send the file and you can do more research to see if you need to muck about with parameter files.
  • Thanks 1
Hi!
I've recently got a Karoq, 2018 model and I was wondering if there's an update for the infotainment system.
Installed SW train version: MST2_EU_SK_ZR_P0472T
Installed SW MU version: 0472
Part number: 5Q0035874C
Software version: H29.319.51_STD2Nav_EU
Hardware: H41
Software: 0472
Navigation database: 5L0051236AH  1030  ECE1 2018/19
SHIELD: SHIELD 2016-44 (build 309) 4104.0.0.0
Bluetooth version: C300
SmartLink: 4101.438.1.5
Radio database version: 1.9.4
USB surfstick version: 4101.438.1.4
Thanks!
41 minutes ago, MrSecretPotato said:
Hi!
Hardware: H41
Software: 0472
Thanks!
I will send you link to download 0480 version.
Even if you don't use, you can update maps here... https://www.briskoda.net/forums/topic/512842-amundsen-mib2-map-updates-2024/
That way you have a backup to Google maps/Waze etc
On 04/05/2023 at 10:38, varooom said:
They are OK AFAIK.
But the site is slow like ancient dialup Internet.
I successfully upgraded from 472 to 480 without any troubles ! Installed mib2toolbox and have patched the CID Lock. Now I'm able to use any SD Card for the navigation system !
Is there any update available for this?
Also - I'm planning to see if I can unlock Android Auto - any one with any advice would be appreciated :)
Thank you! :D
1 hour ago, theandywaite said:
Thank you! :D
There is update to 0253 version
As for unlocking features, you have 2x choices, one you can contact a dealer or independant and get a code to unlock (kerrching)
Or you can get the radio modified via a "toolkit" which is best discussed in PM.
2 hours ago, petercheco said:
Dear @varooom,
I have the following system. Is there a software update available? I would very much appreciate if you could help me.
Regards
I can send you update to 8755 version
Dear @varooom,
Could you please help me with FW upgrade?
I have the following system, see picture bellow.
Spoiler
Regards
Tomas
1 hour ago, TomasF said:
Dear @varooom,
  Hide contents
Regards
Tomas
I can send you link to 0480
