Help! 69 plate 1.0 TSI SE manual clutch gone after 2721 miles!!!!
Bollcat
Hi all,
I'm hoping very much that no one else has had the same issue I'm having but would really value some advice.
On Monday my 1.0 TSI clutch failed. It is leased and I received it on 14th December 2020. At the time the clutch failed it had 2721 miles on the clock. It was towed by the AA to a Skoda dealer under the Skoda Assistance banner. I assumed everything would be taken care of....
This morning I was called by the dealership to say that the clutch plate was 'burned' and that there was no manufacturing error and therefore it was caused by driver error and is not covered under warranty. I was quoted a repair bill of £1,171.48.
I'll be honest I was gobsmacked. In terms of background I am 48 and have been an NHS Paramedic since 1996 and hold advanced driving qualifications (inc. IAM Roadsmart Advanced Driver). My wife (who also drives the car) is also an NHS Paramedic (I won't say how long for.....) and also holds advanced driving qualifications. To put it bluntly - we both know how to drive a car. I explained our background and experience to the Skoda technician who couldn't be less interested. There was no manufacturing fault and it was driver error. I told him I would call back as I was not a happy Skoda bunny and needed some thinking time. So, I thought the situation through.
There were absolutely no signs of any problems at all with the vehicle (indeed I love it) . On Monday I had stopped at a set of lights, put the gear into neutral and put on the manual handbrake. The lights changed and I tried to put it into first gear. It wouldn't go in and when I tried, it made a hideous noise. Instant horn blowing from behind me so I put on the hazards. I tried again to get it into first and it went in with a 'clunk'. I released the brake gave it some gas and... nothing. The engine revved but no movement. After trying again (with more frustrated drivers behind me) the car did move but wouldn't come out of first. I was in a dangerous position at the junction and so drove it for approx 200 yards until I could pull over into a safe space. Called Skoda Assist who sent out the AA. The AA responder could smell the stench and he said the clutch had gone. The car was then towed to the dealership.
I've had the car for less than 6 months, it has 2721 miles on the clock (but it's not covered by the manufacturers warranty) and furthermore it's 'my' fault.
So, I've registered a dispute and engaged a VOSPA accredited independent vehicle inspector to attend the dealership (which has cost me £199) and instructed them not remove any parts or take any further action on the vehicle. Can someone advise me if they think there's any additional action I should do whilst I wait for the report? Is the inspection worth it?
Has anyone else had a similar issue and how did it pan out? I honestly can't get my head round how a) it's not covered given the mileage and length of time I've had it and b) that I'm being blamed for something I haven't done.
I contacted the leasing company and they completely washed their hands of any part in this and have told me it's entirely down to me and Skoda. Is that also right?
I'd be very grateful if anyone could give me some advice or point me in the right direction.
Bollcat
Hi BC, welcome to the forum. Sorry to hear of your problem, certainly not something you would expect so early on.
From your detailed description of the start of the problem, it rather sounds to me as if it started with failure of the clutch-release cylinder - with the clutch plate possibly 'burning out' from resultant damage to clutch diaphragm and slippage afterwards.
Have they actually removed the clutch to make that diagnosis or just sniffed under the bonnet?
You have done absolutely the right thing and I dont think they will have a leg to stand on when its expected, abusing a clutch once will leave a terrible smell and it will slip but the next day when cooled aside from the residual smell it will drive as good as new and go on for hundreds of thousands of miles.
You would have to do the above abuse consistently and regularly before the clutch failed through wear which I'm sure is not your case, indeed you didn't abuse it at all but it sounds like the release mechanism seized.
As the smell was there then there will be a sign of overheating but not excess wear and it will be a consequence of the mechanical or hydraulic problem.
I think you are doing correct thing,
I would remind both parties (dealer and Inspector) that it is your clutch, not theirs, and they are not to dispose of any parts, but are to put them in a plastic bag in your boot.  Your want all evidence preserved until resolved.
If it does turn out to be faulty release mechanism, then I would say it was a manufacturing fault, therefore covered by warranty, and for misdiagnosing, dealership should cover cost of report (they have clearly saved by not training technician properly on how to inspect)
Surrey John, J.R. ,Warrior193 & Wino - genuine thanks from me for taking the time to post. Some great advice and insight into some mechanical issues I can look up. As a Medic I do 'bodies' but I'm a hopeless mechanic :o
Thanks also for letting me know that the inspection is a good idea.
I'll keep you posted.
Take care all
BC
I have a vague memory of some SEAT Atecas with the 1.0 engine having similar issues a few years ago. Have a search on www.atecaforums.co.uk to see if you can find what happened.
Unfortunately the response from the Skoda dealer is what to expect these days but that certainly doesn't make it right.  They simply want to avoid taking responsibility as it will cost either them or Skoda to fix the problem.  And to charge over £1,000 to replace a clutch is just ludicrous.  Shameful behaviour.  You are wise to get an independent inspection as it will prove invaluable if you have to go down the legal route with this.  Please let us know how you get on.
  • Love it! 1
Hi all,
Sorry I haven't replied for a while but have waited until I received the independent vehicle inspection which came through today. In short it confirms what I knew from the start - there was a manufacturers error with the vehicle from the point of delivery. Here's the verdict:
Conclusion / Opinion: In the engineer's opinion, being based on evidence written, reported, and observed during this assessment of the above defects, the following can be concluded: From the details provided in the report brief, the engineer understands that the vehicle became stuck in first gear whilst stopped at a red traffic light, when the driver could move the vehicle, it was driven to a safe location and recovered into the repairer who have removed the gearbox and clutch components. The engineer can confirm that the clutch friction plate has disintegrated on one side, the debris from the disintegrated friction plate has caused the clutch pressure plate to disengage incorrectly, forcing the clutch release bearing and fork into the gearbox casing locking it to the casing preventing full clutch release and preventing gear change operation. The wear identified on the gearbox casing clearly indicates that the clutch release fork had been fouling against the casing, this would have affected the clutch application and release operation, possibly causing premature clutch slip not controllable by the vehicle operator. From the debris inside of the gearbox bell housing and clutch wear noted on the other side of the clutch friction plate, excessive wear has been occurring for some time. The wear on the gearbox casing and release fork suggests this has been fouling from the vehicles build date, the low recorded vehicle mileage would also confirm the fault was present at the point of sale.
So, I feel good that I stood my ground and got the report done, BUT now I'm lost as what to do next. I've just shared this with Skoda and the Ombudsman so I'm waiting to see what they come back with. I'm not mechanically minded AT ALL and the technical terms are beyond me. My question is what next? To me it reads as though there a substantive problem with vehicle and doesn't sound like an easy fix. Indeed, is it a fix or is it inherently knackered...? What should I reasonably expect from Skoda now? It's been over two weeks since this happened and I've been without a vehicle. I'm a paramedic and have been very fortunate that my neighbour has lent me her car a couple of times and my crewmate has also picked me up (miles out of their way bless them) and I'm still struggling to get to and from work. Is it reasonable to be asking for a courtesy car (at no charge to me) whilst this gets sorted out which will invariably take time...?
Any advice appreciated.
Thanks all
BC
It's good the report is in your favour but I guess you have to hope Skoda don't disregard it but if they did, I'd think you could have a good leg to stand on if you were to take legal action.
No matter how you look at it though, Skoda have been pretty diabolical in the way they have treated a customer and your leasing company not much better.
  • Love it! 1
Sounds like their initial 'it's user error' must have been a blatant and knowing lie, if they had eyeballed things from the inside at that point.
If they do not offer to replace clutch and gearbox (assuming the independent assessment is that that is damaged more than cosmetically?) under warranty, seek legal advice promptly; and yes, they should definitely be supplying a courtesy car.
Edited by Wino
  • Love it! 1
Hi BC, great to hear that your independant engineer has confirmed not user error/abuse, this should have been obvious to the supplying dealer too.
Next step should initially be to go back to dealer with the report to see what they propose to do, escalate to VAG customer services if dealer will not accept liability.
Minimum, loan/free rental car of, at least, same spec as yours for full period and full payment for independant engineers report.
Does you vehicle insurance include legal cover?
Edited by Warrior193
Typo
Hi Warrior193, Wino and motr1912,
Thanks all for your advice. I sent the report to the dealership and Skoda customer services asking for a courtesy car as a start point and they haven’t even acknowledged the email (I put a delivery and read receipt confirmation).
Unfortunately I didn’t take the legal cover option when I got my car insurance but I do have a very good friend who is a solicitor who will act on my behalf if it gets that far but I sincerely hope it doesn’t.
BC
Simply don't let Skoda or the dealer get away with this.  They have behaved shamefully and simply want to avoid their responsibilities.  Be firm with them but not over argumentative.  You should not be out of pocket at all and ideally deserve some sort of recompense for your inconvenience.  Take this as far as you can including a loan car at no cost to you, refund of your specialist engineer's costs, repair or replacement of the car to full specification, again at no cost to you and something for your trouble.  Good luck with all of this.  Don't be reluctant to involve your solicitor friend early.  If nothing else, it will show Skoda you are serious.
  • Love it! 1
Hi BC, if the dealer continues to ignore your case, I'd strongly consider filing with the County Court, that should get their attention pretty quickly.
Not sure if you got this sorted. Having been through similar crap Skoda service with a brand new lease.
If it’s a lease car you should ignore Skoda and raise the issue direct with the lease company (not the broker. The actual underwriters). Don’t let them fob you off (they did the same to me). It’s their responsibility and raise it in writing. You’ve reported it within 6 months. They have one chance to repair it without causing you significant inconvenience. Otherwise pursue rejecting the vehicle is your right under the CRA act. Especially since it’s a pretty major fault as it’s currently not driveable and your new car doesn’t only need a new clutch it’s now got casing damage caused by the fault. The fact it’s a wear and tear item is their only defence but at 2k miles and less than 6 months plus an expert paid diagnostics they don’t have a leg to stand on.
Skoda won’t budge until the lease company pressures them and they will only do that if you exercise for your legal rights with them. At which point you’ll start getting emails from Skoda fleet customer services most likely.
Try to avoid phone calls. If you do get one request they summarise with an email. If you don’t receive it within the hour send them an email politely summarising all the key points in the call. That way there’s a simple trail of events in writing.
Good luck. Remember Skoda know your not the owner of the car. If it ends up in court your just going to get it thrown out because they don’t have to legally do anything for you. Leasing isn’t the same as financing a car.
Hope something in this post helps.
  • Like 2
  • Love it! 1
What an utter shambles of a dealership. I have used two skoda dealerships in my time owning skodas and both were great at the simple things and woeful at other things like fixing things and fitting things.
The fact on top of your experience of the dealer and their inability to provide you with a service that isn't anything above effing crap, your lease company also appeared to sold you down the river too from your original post.
I have to ask, have you been in touch with the lease company since? Also, are you still paying them?
If you are, I would be pressing for skoda to cover any costs for your lease payments whilst still trying to get their head out of their arse.
Should add that I have a leased kamiq (just over a week now) and I just hope I don't experience anything bad.
My heart goes out to you for having to deal with these idiots.
  • Love it! 1
I suggest contacting the manager again and give them 7 days to, at the very least, refund all your out of pocket expenses - failing which you will start legal proceedings. Lets see how keen they are to have the bailiffs around emptying out their showroom or workshop.
That horrible clutch smell can hang around for ages, a bit like the smell of death from a decaying rodent in my roofspace you become hypersensitized to it, it can appear to have gone away but one day perhaps the wind is blowing in the right direction and you get a tiny whiff of it which your sensory system amplifies massively probably recognising it as a threat.
If it isn't smelling through operation, reverse hill start, reversing a trailer etc then I would not be too concerned.
I am usually very good at deciphering and making senses google translations from one language to another but this part of the tech webinar is causing me some problems, can anyone suggest what it might be saying? the rest makes sense:
Technical background/Cause  Due to anticorrosion protection applied to the flywheel and the clutch, the friction value increase is much more slowly. This may lead to premature clutch failures.  Despite optimizing measures (plate lining of the clutch S308, the diaphragm spring of the pressure plate with temperature stability and decreased rpm in the transport mode), the premature heat overload of the clutch still sporadically occurs.
