Tested and working coding Octavia mk4
does anyone know if obdeleven works on skoda octavia 2025, as author says must i unlock all modules
Edited by Pikov75
  • 4 weeks later...
  • Replies 294
  • Views 125.3k
  • Self moderation is the key to happiness. The best reply is sometimes no reply at all.   we’re all free to do what we want to do with our stuff.   Why would someone buy a brand new
  • @SkOmk4, My answer in line: 1. All the Release Active DTCs will be present only on the SFD locked modules. The reason why the DTC is still present on that module is that you forgot cu SFD Lock the m
  • I think both sides of the argument have some validity.   Perhaps an addition to the first post by the OP stating that you should backup the configs before doing anything, you should understa
Hello, many thanks for posting great codings. I am looking for Lane Assist coding. I am 2020 Octavia owner.
activate lanne assist or memory setting ?
Lane Assist to "Last setting" (asistent jazdného pruhu na "posledné nastavenie" )
EN- driver assistance (module A5) > long coding > Configuration for lane departure warning KI15 > change to "last setting"
sfd2 not available for cars 24or new
Hi, I mean how to activate Lane Assist not the memory setting. Thanks
Edited by onahoz
DRAFT
Hey
Just had a chance to play around with coding a little bit through obdEleven. Most of the information was taken from the current topic. Thanks to everybody for sharing the information!
My summary for now:
item name
instruction used to enable
status
comment
turbocharger pressure
  • Module 17 -> Adaptation -> Charging pressure
torque (nM)
  • Module 17 -> adaptation -> Engine torque
power (kWt)
  • Module 17 -> adaptation -> Engine power
G-meter
  • Module 17 -> adaptation -> G-meter
Does not display anything in my case
steering angle
  • Module 17 -> long coding -> OFFROAD -> Display
An icon appears, angle is displaying correctly, but the turn side is inverted
refuel quantity
  • Module 17 -> long coding -> Volume to be replenished -> yes
An icon appears, but no data, just ---l
oil temperature
  • oneClick App
DSG temperature
  • Module 17 -> adaptation -> Transmission temperature
vRS welcome screen
  • (Module 17 -> long coding -> Start screen -> Version 3)
vRS cockpit screen
  • oneClick App
30 colors ambient light
  • Module 09 -> adaptation -> hmi_ambient_colors_bitmask -> 7fffffff
  • Module 09 -> adaptation -> hmi_contour_colors_bitmask -> 7fffffff
Edited by archi332
Video of the "inverted steering angle" option
Hey @archi332 good to know you've joined the coding club 😁
Your next mission is to work out how to change the colours when you put the background lighting into 'mode' mode.
Instructions on how to do it on a golf are here:
https://www.vwgolfcommunity.com/vb/forum/vw-golf-world/vw-golf-8/interni-ad/1414069-luci-ambientali-preimpostati-come-modificare (Google translate will do the obvious)
But essentially it's module 09 > interior-light-general> mapping_fpa_profile_xx. You need to change the value and see what happens! I've done the attached so far!
Ideally I want the following
Normal - white
ECO - green
Comfort - pale blue
Sport - red
Individual - purple
My current setting is the last entry in the spreadsheet, and it's not ideal!
Have fun!
Mk4 interior lights.xlsx
Edited by mczakk
20 hours ago, archi332 said:
DRAFT
Hey
My summary for now:
item name
status
comment
torque (nM)
power (kWt)
G-meter
steering angle
refuel quantity
oil temperature
  • oneClick App
DSG temperature
vRS welcome screen
vRS cockpit screen
  • oneClick App
on what year and model skoda did you do this
Skoda Octavia mk4 2020
Normal - white
ECO - green
Comfort - pale blue
Sport - red
Individual - purple
Have fun!
Wow, thanks for sharing that!
At very beginning I thought such functionality should exist from box, but did not found how to setup this
Will follow your findings 💪
It was really easy to do on the mk3.5, but seems to be much more complicated on the mk4!
  • 5 weeks later...
Hi, I have problem, I coded everything i wanted but one thing just ****es me off so much, I can’t show RPM on vRS cluster, I tried everything, search whole internet but still nothing. Is there someone who can help me? I have 2023 2.0TDi 85kw Swing
5 hours ago, lucasgajza said:
Hallo, ich habe ein Problem. Ich habe alles programmiert, was ich wollte, aber eine Sache nervt mich total: Ich kann die Drehzahl im vRS-Cluster nicht anzeigen. Ich habe alles versucht und das ganze Internet durchsucht, aber immer noch nichts gefunden. Kann mir jemand helfen? Ich habe einen 2.0TDi 85kw Swing (Baujahr 2023).
IT dont Work at this Car year
On 15/05/2023 at 13:12, djmartzian said:
@Chrisg2021, Here is the coding if you would like to do it by yourself. Bear in mind that beside the dongle you will also need a Pro subscription.
Driver assistance (module A5) > long coding > Configuration for lane departure warning KI15 > change to "last setting"
Standard ACC
Control unit 13
Long coding
Cruise control mode
Set to: Activated
Enabling standard CC does not work/show in my 2020 Skoda Octavia 2.0 TDI.... ODBEleven encounters an error, without explaining what went wrong (App encountered an error")".
Any more details on how to activate this option please?
On 28/07/2022 at 21:37, timster said:
So my Octavia is getting near to me. OBD11 with 2y pro subscription is waiting to arrive perhaps next week.
Could you guys confirm/assist me on the settings i'm planning to do for the RS iV.
  • Headlight washer delay to 2500ms
  • Start/Stop button heartbeat (***)
  • ACC overtaking enable
  • Normal cruise
  • Light assistant memory
  • Daylight rear lights (****)
  • Trunk alarm sound off
  • Foglights on revers (if not alreadl)
  • Keep windows working after shutdown
  • Seatbelt warning disable (*)
  • Lock car when running (*****)
  • Needle sweed (Didnt see it enabled on youtube videos) (**)
  • Disable beeping when opening door when engine on
Are these are doable with OBD11?
I believe the headlight washer delay requires an SFD unlock, which is possible with the Pro?
Can someone confirm that these all are possible and has been done? Can i do all of them with the OBD11? (as much with long coding as possible)
I've got 200 credits, which i can also use. But would not like to spend all at once :)
Listed the ones i found some steps. Are they working?
* Control unit 17 -long coding- seat belt warning version1, version 2 or off- set off to turn off warning
** Control unit 17 -long coding-Staging set yes
*** https://forum.obdeleven.com/thread/7261/engine-button-heartbeat-effect-keyless
**** 1.Module 09 - Electronic control unit 2.Adaptation 3.Daytime running light 4.Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht: - (Change value to On)
***** Control Unit 09 -> Adaptation -> ZV allgemein -> funk bei klemme15- set active
I would love to enable the Engine button heartbeat. However, the highlighted entries below could not be found in ODBeleven for my Skoda Ocatvia IV 2020 when searched with the word "lights" :
Adaptation
_ _ Control unit: B7 Access Startsystem Interface
_ _ Name: DeveloperCoding: Search lights
_ _ Values:
_ _ _ ZATillumination_concept_mybeat_clamp58xt:
_ _ _ _ _ _ Old value: Not activated
_ _ _ _ _ _ New value: activated
_ _ _ ZATillumination_modus_mybeat_clamp58xt:
Please advice?
Edited by SkodaOctaviaIV
Up to which year of make this functionality does work / VR cluster can be enabled?
CC ACC and pACC is SwaP Protection
Or did you mean CC in Unit 13
Edited by Cairus
I would like to have the extra option on the metering display to select the normal CC. How to activate such?
PS: I have ACC in the metering menu present, just not normal CC...
following: unit 13, unlock SFD, Coding, CC To active........ Control unit 17, unlock SFD, adaptation, display longitudinal control coordinator, CC active...... Attention, both depend on HW and SW
I had to add the security code first, next it worked as per your instructions. Thank you!
2 minutes ago, SkodaOctaviaIV said:
Ich musste zuerst den Sicherheitscode eingeben, danach hat es gemäß Ihrer Anleitung funktioniert. Danke!
A thank you for the post would be a nice gesture ☺️
Dear forum users,
To lower the ADD (flipper-handle up/down) 10KM steps back to 5 or 1KM, who can share the coding for this change, please? (Skoda Octavia IV 2020)
No warrenty:
Byte 21
Bit 0-1 pACC_Regulation_on_priority (on off)
Bit 2-3 pACC_Reaction_to_end_of_traffic_jam (with or without speed adaptation)
Bit 4-5 pACC_Learning_to_drivers_offset (on off)
Bit 6-7 pACC_Reaction_to_narrow_places (dynamic_obstables, static and dynamic, off)
8 minutes ago, Cairus said:
No warrenty:
Byte 21
For which request was this reply / instructions meant?
