Software Update...?
I must say thanks to all , i have all Software kompletet . Also the Radio Database .
Thanks , thanks , thanks
  • 3 months later...
  • Replies 260
  • Views 78k
  • I have sent you a new link, they only live for 24hrs. Since you usually sell the firmwares, please don't ask for more... this is not why I send them.  I hope you understand my "spirit"
  • 308 https://mega.nz/file/dgNAADwQ#h7p60yQb9OmM0pQ2O9nZvIPsi_k9TMnwOm83pBj3hmY 332 https://disk.yandex.ru/d/p21TSZ9mKJcTVQ
  • You should already have a private message.   The release is a 2 in 1 package, so it has 2 stages of update.  First takes you to 0308, after it has rebooted and settled, you will be able to l
Hi everyone, pretty new here. does anyone have the RW 308 version file? can't find it anywhere on the net.
Hi everyone.
This is my first post on this forum. I've read this entire post and I have a question for you. I'm in Australia and trying to update the firmware from version MOI3_RW_SKMQB_P30603P. I've already downloaded versions MOI3_RW_SKMQB_P32400P and MOI3_RW_SKMQB_P33000P. I've looked through the files and see that I need version MOI3_RW_SKMQB_P30803P. Where can I find this version? I'm not even sure if version P30803P exists for RW.
2 hours ago, Cam73 said:
The links on https://www.drive2.ru/l/695736324514133028/ appear to be working currently. Thats where I got the RW 308 and 330 from and have just updated my MIB. I'm in NZ.
Hi man, thanks a ton. It didn't work maybe a week ago.
Just to confirm, I can use this on my Kodiaq my21? I'm in NZ as well, good to know I'm not the only one going through this...
Maybe. I started from this version exactly: 20260517_053843.jpg
I'll give it a go and update here. Did you encounter any issues? I remember I read somewhere that the navigation and map may stop working when you go from version something to version 308, or something like that...
Make sure to check the zip file properties and unblock them first. Format the usb-c or sd card with FAT32 or exFAT. I had to press the update option a couple of times. It will take at least 10 mins each version. I would do one at a time and test each one thoroughly. When each update is finished, use the scroll bar to scroll down then press resume. Navigation may stop working. If so, you would need to also apply the patch. This is where i am up to. For me, nav didn't work when I bought the car. It's an ex police Skoda Superb. Go to the swap codes also in the engineering menu, select one that is already there and check your VCRN before and after upgrade. Mine currently says 1234.
Ok, I got lost at applying the patch. I have to read more to know what I'm doing. I have to find the patch first.
What is the engineering menu and where is it?! What swap codes?! 😅😅😅
I'm very new in this as I bought the car last month!
Instructions are here: https://www.drive2.ru/l/695694817950177190/ mibsolution.one seems to be down at the moment, i found a backup site here: https://mib.plain.gg/MOI3/Preh and the patch you are looking for is called MOI3 Preh Solution - BEWARE - break risk.7z but you need the VCRN before the patch is any good to you. Thats why you may also need a ELM327 and the car scanner android app to find VCRN. To access engineering mode, press and hold menu for about 3 secs. Read this from beginning to end too, all pages, it has helped me so far: https://www.briskoda.net/forums/topic/521024-kamiq-my20-mib3-update/page/8/
I have USB Patch for MOI Preh Unit
