DCC Slider adjustment option mod
Shame no one is doing this in the UK yet. I'd definitely be interested.
  • Replies 125
  • Views 45.3k
  • Well that was all surprisingly easy...   Flashed the DCC module:   Uploaded the Passat dataset (closest in size, weight and wheelbase to the Octavia):   I alr
  • Ok, with some serious help it's been done!   Here is the overall sequence of events that was encountered and followed: Original gateway was 5Q0. Most examples seem to use the 3
  • Youre in luck, this is what youre after.   https://www.glaskugelservice.de/codierung/dcc-auf-index-c   https://github.com/jilleb/MQB-FPA     The first link is bringi
On 21/02/2025 at 08:31, spen686 said:
Why's that?
Big cost SILTB.
Hi anyone dataset for arteon R shooting brake. Thank lot..
On 21/02/2025 at 19:30, travs said:
I've already tagged Aperture in one thread; he'll get annoyed if I do it again...
I can't risk it I am already bothering on the torch issue ... we need to get someone else to attack 😁
Hi, is it possible to upload FPA to gateway 5Q0 slider DCC. I have DCC flash on type C 0130. But I have gateway 5Q0 I haven't tried uploading dataset so as not to break it. Does anyone have experience whether it will work?
I think the problem in this thread is that there is a lack of communal info to answer. There are a few specialists who’ll know but if they’re not on here then you may have to wait a bit.
You need 3Q0..Q gateway and higher
e.g. I made it for my ...AC gateway
all you need is a buy for example vnci6145 and someone can do it for you remotely. Or even you can do it by yourself
Edited by zacko_O
hi does anyone have the gateway dataset 5Q0907376C for VW Arteon R, i tested version V03935274AH 0001 and V03935317XE 0001. I don't know which version is for R line, I think the V03935274AH version is harder. The V03935274AH version is very wobbly so it probably won't be the R-line Arteon version.So please, who has the data set version for Arten R line. gateway version 5Q0907376C, please share. Thank you.
Edited by Miliskot12
On 16. 8. 2022 at 17:24, ApertureS said:
Hi, which Arteon is the dataset from? Thank you
9 minutes ago, langers2k said:
Quick google...
V03935274AH
Diesel Arteon: https://vagcode.info/en/brands/volkswagen/arteon/3H7/log-462.html
V03935316RN
Diesel Arteon: https://forums.ross-tech.com/index.php?threads/44580/
Petrol Arteon: https://forums.ross-tech.com/index.php?threads/39880/
V03935290WM - labelled as Passat
V03935317XE - labelled as Arteon
Not sure if that helps or not. Please can you upload V03935274AH as I've not seen that file online yet.
Thanks, but I need the DCC arteon version, preferably the R-line version. Does anyone have one to share? The mibsolutions website is not working.
here you have the arteon DCC AH version.
14_OE_5Q0907376C-Arteon.xml
13 minutes ago, langers2k said:
Quick google...
V03935274AH
V03935316RN
I don't know why, but when I loaded version V03935317XE into my Passat b8 R-line 2.0tsi, the car is terribly wobbly...
or please share another version for arteon.
I only have WM and XE (and now AH thanks!). If I see any other versions I'll let you know.
Some of the remote coding services might be able to help if you can provide an Arteon R vin number 🤔
Hi, today I tried replacing the gateway from 5Q0 to 3Q0 and ODIS online gave me an error, CP cannot be unlocked. IKA error - 0x0, do you know how to do it? It was a 3Q0907530AR gateway. I don't know what the problem is, I tried the procedure on this page https://www.drive2.ru/l/677127914847740734/
and without success the data cannot be written when the CP is active.
Maybe faulty gateway
Edited by zacko_O
1 minute ago, zacko_O said:
Máš snímek obrazovky? A popiš postup.
Obvykle se tam vyskytují chyby FAZ***.
I replaced the gateway with a 3Q0, got Safe CP, connected ODIS S online geko, did 0019 gateway CP from the test plan and got the IKA error - 0x0, I also tried to remove each unit separately CP. I only have a photo from one unit when trying to remove CP. I can't find what the error means. I can only think of hacked MIB2 if it doesn't matter or flashed the DCC unit to version C and uploaded the arteon data set. Otherwise I don't know what the problem is. I use ODIS S 3.0.3.I tried to upload a backup via ODIS E from the 5Q0 unit to the 3Q0 unit but without success due to the active CP. I had the 3Q0 unit from the Passat 2023. So I'll try another version from 2019. I had the HW version 3Q0907530G there. It doesn't work in my car, it says this error. Now I ordered the 3Q0907530C version. Maybe this is the problem, otherwise I don't know.
I am attaching a backup via ODIS E complete set of units and coding,another report from the DCC flash unit on version C 0130 for the arteon.
backup VW passat B8.zip
I don't know if ODIS is bothered by hacked MIB2 or flashed DCC unit which is not compatible with the car, you can see from the photo which version I flashed. I will try MIB2 to play the software on the original factory Version 3342 VW G11. but I don't have the software from the original version of the DCC unit to return. Otherwise I don't know. I will try when the 530C gateway version comes. Otherwise SVM coding worked for me for the test, I chose the wrong coding for the air conditioning function Air care and ODIS SVM recoded the function back for me without any problems.so I wouldn't see a problem with the ODIS installation.
10 hours ago, Miliskot12 said:
flashed DCC unit
it's definitely not a reason of this error
Hi, do you know if anyone is capable to do this somewhere in Austria or Hungary, between Vienna and Budapest?
  • 5 months later...
Same question as above, anyone able to do this in Hampshire/Surrey/London areas?
If You have VCP or ODIS-E I can prepare a file with DCC-Slider online
What does the file have to do with the fact that the colleague is looking for someone who can do it for him?
And Odis, vcp are Not the only Tools which can write Dateset
Edited by Cairus
Now I can see that a lot of people has a "china" ODIS, so I believe it will be a lot easier to find a person with this kind of tool, than a person who can and wants to spend time on creating parameters file.
Don't You think?
We can go also on a technical discussion about which software is better - but I believe this isn't necessary and it won't bring anything valuable to discussion about DCC-Slider.
