infotainment update
hi
New on here so not sure where exactly I should post this.
I have Skoda Kodiaq 2019 and I thought I would update the infotainment system.  What will I get if I do. At the moment Android Auto uses a physical cable connection but I know newer versions are wireless... Is this a simple software change or does the hardware need changed for wireless connection?
Either way I'd like to update the version... Can anyone provide the latest update?
Many many thanks in advance. Details attached.
  • Replies 217
  • Views 76.6k
  • @xyboox You shall have update by PM
  • No. And it's probably a good idea to do this on a used car anyway (hopefully the dealer will have done it, but there's no harm in you doing it just in case 😉).
  • @Joncs23yes   @Ievgeniii need to download it from the server for you   @bluemoon2020sent me pm
11 minutes ago, pol77 said:
hi
You will need to hold down the Menu/Setup button for about ten seconds to enter engineering menu with Software Train information.
Post up that image.
20221204_185229.thumb.jpg.843e64cad86efc4ef8a8760f38b73aa0.jpgthanks
I will send you a PM shortly to 0480 version
  • 5 weeks later...
Dear. I have the software version listed. I wonder if there is an update and if I can get it. Greetings
Yes to 0480 version, link via Private Message system
Hello, would there be a firmware upgrade for my system as well? It's a Columbus MIB2 system, but looking slightly different to the other guys' ones above, where mine only have one set of soft buttons on the left side. The software train is also a slightly different format.
Thanks in advance
Thanks in advance
/cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/IMG_5677.thumb.jpeg.7b16570de9e3023d897589a7574bc06c.jpeg
You have the latest version.
MHI2_ER_SKG13_P4526_1440.7z
Perfect thanks. The car was recently in for a fault repair, and I wonder if they upgraded the firmware as well then.
Thanks again!
Thanks again!
It would appear they may have done such a thing ☺️
Could you please send me the new software.
What are the general improvements in it?
There is one bug (I don't know if it is related to the Information software), but it often happens that when I start the car I get a message: "Telephone: System switched off" or "Not available"
  • 4 weeks later...
Moin.
Kann mir bitte jemand die passenden Updates zusenden für mein Oci 2013?
Danke
@Oci I will send you a link to firmware
@Oci please only use English on Briskoda.
Hi, guys.
I wonder is there a firmware update for my unit? Freezing and wrong reactions time to time. Thanks in advance.
10 minutes ago, beglec said:
You will need to press and hold down Menu/Setup button for about 10 seconds to enter engineering menu, look for Software Train information and post back image.
Waiting for your comments...
Yes this one exists... I will send along a PM
MHI2_ER_SKG13_P4526
MU 1440
Update went successfully. No errors during procedure but in the end I received notification: testing main unit, comparing versions, if error will be found, then unit will be rebooted. Test lasting long time, not finished yet. Is it normal? How long it will take?
Honestly mine is a different firmware to yours, and no big testing was needed, it asked to connect to diagnostic equipment to check, but I cancelled.
So I cannot answer how long it will be, can you show image??
It's SEAT, but same process for Skoda
Edited by varooom
Everything is fine. It was only a promt for diagnostics. As you said, I just canceled it and the unit rebooted. In the end works fine. Will keep an eye on unit, in case bugs are still living inside...Thanks.
Hi,
I was also wondering if there is a firmware update for my Kodiaq 2017, thanks in advance.
21 minutes ago, Baker_cz said:
Hi,
SW: MHI2_ER_SKG11_K3343
MU: 1433
Will send PM
