Tail light passenger side issues
Evening all,
Got an issue with my passenger tail light on my Skoda Fabia Monte Carlo 1.2TSI 11 plate I noticed a couple of days ago that my reversing light wasn’t working so went and brought a new bulb replaced it nothing, I checked the fuse and swapped it with another 5 amp and nothing once again.
I’ve been getting an issue when turning the lights on my bulb symbol will appear on the dash and the same passengers tail light isn’t working a quick tap on it and it comes on again. I’m guessing it’s a wiring issue and the best thing is to get a replacement tail light with new bulb holders/wiring loom, I’ve read that the reserving light could be down to the switch in the engine bay but it’s a lot of work to change it if its the light itself.
I’m pushing towards replacing the whole light unit but just wanted to see if anyone has had the same issue before?
cheers
Jamie
I'd start with the connector strip first, then the individual bulb holders. A bit of TLC on all contacts might save you having to replace the whole lot.
image.png.d46a83c1af065306ff02234a606635e7.png Is this the connector to the rear light? Separate, inspect and clean.
